[Geoserver-users] Problem installing gsconfig for python
I am trying to install python gsconfig for use with geoserver REST and got
errors. I tried both the user command pip and githup for developer. Not
sure what was wrong:
git clone git://github.com/opengeo/gsconfig.git && cd gsconfig && python
setup.py develop
remote: Reusing existing pack: 1704, done.
remote: Total 1704 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (1704/1704), 865.95 KiB | 220 KiB/s, done.
Resolving deltas: 100% (837/837), done.
  File "setup.py", line 8
    except IOError,e:
SyntaxError: invalid syntax
pip install gsconfig
Got the following errors in pip.log
Downloading/unpacking gsconfig
  Getting page https://pypi.python.org/simple/gsconfig/
  URLs to search for versions for gsconfig:
  * https://pypi.python.org/simple/gsconfig/
  Analyzing links from page https://pypi.python.org/simple/gsconfig/
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.5.1.tar.gz#md5=775c970fa81de213a455399a5e8ee13a
(from https://pypi.python.org/simple/gsconfig/), version: 0.5.1
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.5.2.tar.gz#md5=f2091547f713a7ff2559520aa55df046
(from https://pypi.python.org/simple/gsconfig/), version: 0.5.2
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.5.3.tar.gz#md5=f4b2a204fd582db06f6d623779ac00d6
(from https://pypi.python.org/simple/gsconfig/), version: 0.5.3
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.5.4.tar.gz#md5=4090fc5d9de0ddbcc2d3f2adf727a53f
(from https://pypi.python.org/simple/gsconfig/), version: 0.5.4
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.5.5.tar.gz#md5=a9fcb47304c61323faf689c528a61771
(from https://pypi.python.org/simple/gsconfig/), version: 0.5.5
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.5.tar.gz#md5=344ac6e00c5ca2a3779605eb42fa6974
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.0.tar.gz#md5=2614a7b57f87636618068b4a07c98c1f
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.0
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.1.tar.gz#md5=7b7b4ccba473de0b0c9ec893c9fa4d86
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.1
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.2.zip#md5=016ceddaa3d296f5408b94ce91381417
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.2
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.3.tar.gz#md5=6f598bc4b9036ff2add99262bbeb7059
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.3
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.4.tar.gz#md5=f73b03848d84039d8cb1e00ccadf805f
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.4
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.5.tar.gz#md5=501ffa6cbc158902fa318073f3fd22b4
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.5
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.6.tar.gz#md5=149b6d9e0cb701a737444c76eddc44bb
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.6
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.7.tar.gz#md5=ac56650ef27c327eff829ebc95e1c65a
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.7
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.8.tar.gz#md5=8125ce97133a92d49ec88afb0ff38988
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.8
    Found link
https://pypi.python.org/packages/source/g/gsconfig/gsconfig-0.6.9.tar.gz#md5=c8216337621305f7f275f59234b6f5bf
(from https://pypi.python.org/simple/gsconfig/), version: 0.6.9
  Using version 0.6.9 (newest of versions: 0.6.9, 0.6.8, 0.6.7, 0.6.6,
0.6.5, 0.6.4, 0.6.3, 0.6.2, 0.6.1, 0.6.0, 0.5.5, 0.5.4, 0.5.3, 0.5.2, 0.5.1,
0.5)
  Downloading gsconfig-0.6.9.tar.gz
  Downloading from URL
  Running setup.py (path:/tmp/pip_build_vriuser/gsconfig/setup.py) egg_info
for package gsconfig
      File "<string>", line 17, in <module>
      File "/tmp/pip_build_vriuser/gsconfig/setup.py", line 8
        except IOError,e:
    Complete output from command python setup.py egg_info:
    except IOError,e:
Cleaning up...
  Removing temporary dir /tmp/pip_build_vriuser...
Command python setup.py egg_info failed with error code 1 in
Exception information:
  File
"/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/basecommand.py",
line 122, in main
    status = self.run(options, args)
  File
"/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/commands/install.py",
line 278, in run
    requirement_set.prepare_files(finder, force_root_egg_info=self.bundle,
bundle=self.bundle)
  File
"/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/req.py",
line 1229, in prepare_files
    req_to_install.run_egg_info()
  File
line 325, in run_egg_info
    command_desc='python setup.py egg_info')
  File
"/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/util.py",
line 697, in call_subprocess
    % (command_desc, proc.returncode, cwd))
pip.exceptions.InstallationError: Command python setup.py egg_info failed
with error code 1 in /tmp/pip_build_vriuser/gsconfig
I am using python 3.3.5
Machine: Linux CentOS 6.2
Can someone tell me what is wrong with my machine configuration.
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-gsconfig-for-python-tp5148883.html
Hi Tam,
I am not sure but I don’t believe gsconfig runs on python 3. I would try running on a recent Python 2.7.
-Justin
setup.py develop
File “setup.py”, line 8
except IOError,e:
File “”, line 17, in
File “/tmp/pip_build_vriuser/gsconfig/setup.py”, line 8
except IOError,e:
Cleaning up…
Removing temporary dir /tmp/pip_build_vriuser…
File
“/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/basecommand.py”,
line 122, in main
File
“/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/commands/install.py”,
line 278, in run
bundle=self.bundle)
File
“/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/req.py”,
File
command_desc=‘python setup.py egg_info’)
File
“/usr/local/lib/python3.3/site-packages/pip-1.5.6-py3.3.egg/pip/util.py”,
Tam
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
Geoserver-users mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
