[Geoserver-users] Problem installing SQL server extension SQL Azure
We have tried following the guide to install SQL server extension for
Geoserver
http://docs.geoserver.org/stable/en/user/data/database/sqlserver.html
But once the server is restarted it does NOT show the SQL server data source
option when adding a new Datastore. the install was done and the additional
files was unzipped under the lib folder.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-SQL-server-extension-SQL-Azure-tp5310514.html
did you also add the SQL driver from Microsoft?
Ian
Geoserver
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Thanks
we did it all from the start and restarted the server and now it worked.
Dont know what we did different from first try but now its working
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-SQL-server-extension-SQL-Azure-tp5310514p5310532.html
