[Geoserver-users] Problem mapping ELF Addresses schema
I had successfuly mapped ELF GeographicalNames schema, but now I want to map
ELF Addresses schema (
http://www.locationframework.eu/schemas/Addresses/0.1/Addresses.xsd ). There
are no elements in schema, so basically it is the same as INSPIRE Addresses.
But I have problems creating correct mapping files.
My datastore.xml
/<dataStore>
  <id>elf_Address_datastore</id>
  <name>elf_Address</name>
  <enabled>true</enabled>
  <workspace>
    <id>elf_addr_workspace_id</id>
  </workspace>
  <connectionParameters>
    <entry key="dbtype">app-schema</entry>
    <entry
key="url">file:workspaces/elf_addr/elf_Address/elf_Address.xml</entry>
    <entry
key="namespace">http://www.locationframework.eu/schemas/Addresses/0.1&lt;/entry&gt;
  </connectionParameters>
  <__default>false</__default>
</dataStore>/
my namespace.xml
/<namespace>
  <id>elf_addr_namespace_id</id>
  <prefix>elf_addr</prefix>
  <uri>http://www.locationframework.eu/schemas/Addresses/0.1&lt;/uri&gt;
</namespace>/
my elf_Address.xml (I left out irrelevant information)
<Namespace>
  <prefix>inspire_addr</prefix>
   <uri>urn:x-inspire:specification:gmlas:Addresses:3.0</uri>
</Namespace>
<Namespace>
</Namespace>
    <targetTypes>
        <FeatureType>
<schemaUri>http://www.locationframework.eu/schemas/Addresses/0.1/Addresses.xsd&lt;/schemaUri&gt;
        </FeatureType>
    </targetTypes>
    <typeMappings>
        <FeatureTypeMapping>
            <sourceDataStore>datasource</sourceDataStore>
            <sourceType>INS_AD</sourceType>
            <targetElement>inspire_addr:Address</targetElement>
            <isDenormalised>false</isDenormalised>
            <attributeMappings>
                <AttributeMapping>
                    <targetAttribute>
                    </targetAttribute>
                    <idExpression>
                        <OCQL>strConcat('SI.GURS.RPE.AD.', ID)</OCQL>
                    </idExpression>
                </AttributeMapping>
When I run geoserver I get this error, even though
urn:x-inspire:specification:gmlas:Addresses:3.0 should had top element
Addresss:
/31 jul 13:20:42 WARN [data.complex] - No top level element found in
schemas: {urn:x-inspire:specification:gmlas:Addresses:3.0}Address
31 jul 13:20:42 WARN [complex.config] - Error creating app-schema data store
for 'inspire_addr:Address', caused by: No top level element found in
31 jul 13:20:42 WARN [org.geoserver] - Error connecting to 'elf_Address'.
Disabling./
Somebody has a solution how to correctly map this schema?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-mapping-ELF-Addresses-schema-tp5217968.html
Thank you for your answer.
I know that if I change everything to inspire, then it is working, but I am wondering if then it is still elf schema or is only inspire schema?
2015-07-31 20:07 GMT+02:00 Stefano Costa <stefano.costa@anonymised.com>:
if you point straight to the INSPIRE schema at:
http://inspire.ec.europa.eu/schemas/ad/3.0/Addresses.xsd
it works: probably the empty schema with just one tag inside is
giving the schema parsing machinery a hard time… but I didn’t have the
time to debug this more deeply.
Please find attached a working skeleton configuration.
Hope this helps,
Stefano
Il giorno ven, 31/07/2015 alle 04.25 -0700, amacar ha scritto:
My datastore.xml
elf_Address
true
app-schema
my namespace.xml
elf_addr
inspire_addr
elf_addr
datasource
INS_AD
false
strConcat(‘SI.GURS.RPE.AD.’, ID)
Addresss:
for ‘inspire_addr:Address’, caused by: No top level element found in
31 jul 13:20:42 WARN [org.geoserver] - Error connecting to ‘elf_Address’.
Disabling./
Geoserver-users mailing list
Best regards,
Stefano Costa
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
sorry for the (very) late reply.
On Fri, Jul 31, 2015 at 8:16 PM, Amadej Pevec <amadej.pevec@anonymised.com> wrote:
The element you’re mapping is “{urn:x-inspire:specification:gmlas:Addresses:3.0}Address” regardless of what schema you are pointing at in the configuration. In your case, I can see no substantial reason to prefer http://www.locationframework.eu/schemas/Addresses/0.1/Addresses.xsd over http://inspire.ec.europa.eu/schemas/ad/3.0/Addresses.xsd.
Anyway, I also had issues trying to build a mapping with a schema containing no elements, just imports (in my case it was GeoSciML 3.2), so I investigated a bit and opened a JIRA ticket:
https://osgeo-org.atlassian.net/browse/GEOT-5194
Keep an eye on the ticket if you’re interested in seeing this fixed.
Hope this helps,
Stefano
My datastore.xml
elf_Address
true
app-schema
my namespace.xml
elf_addr
inspire_addr
elf_addr
datasource
INS_AD
false
Addresss:
Disabling./
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
I don’t know if you’re still interested, but the issue you reported has been resolved: you will find the fix in the upcoming GeoServer 2.8 release (the beta is out already and it includes the fix as well).
It would be great if you could confirm that the mapping you were trying to define now works correctly.
On Sun, Aug 23, 2015 at 12:14 AM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Hope this helps,
Stefano
My datastore.xml
elf_Address
true
app-schema
my namespace.xml
elf_addr
inspire_addr
elf_addr
datasource
INS_AD
false
Addresss:
Disabling./
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Yes I was checking opened ticket every day and I am glad that it is resolved
now. Thank you!
But we are using geoserver 2.5.2 so we will need to port this fix. We
already tried and error from OP was resolved, but now I get another when I
am trying to get features from geoserver.
<ows:Exception exceptionCode="OperationProcessingFailed"
locator="GetFeature">
<ows:ExceptionText>Error occurred getting features
http://www.locationframework.eu/schemas/Addresses/0.1:Address not found.
Available:
[urn:x-inspire:specification:gmlas:Addresses:3.0:Address]</ows:ExceptionText>
</ows:Exception>
My mapping is still the same as in OP. Now I don't know if it is problem in
my mapping or anywhere else.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-mapping-ELF-Addresses-schema-tp5217968p5222031.html
that’s because you defined a namespace with prefix elf_addr and URI http://www.locationframework.eu/schemas/Addresses/0.1, so when asking for feature type elf_addr:Address, you’re actually asking for {http://www.locationframework.eu/schemas/Addresses/0.1}:Address, which does not exist in your schema.
You should change the namespace URI in both namespace.xml and datastore.xml to **urn:x-inspire:specification:gmlas:Addresses:**3.0.
Hope this helps.
On Tue, Sep 1, 2015 at 10:43 AM, amacar <amadej.pevec@anonymised.com> wrote:
now. Thank you!
<ows:Exception exceptionCode=“OperationProcessingFailed”
locator=“GetFeature”>
ows:ExceptionTextError occurred getting features
Available:
</ows:Exception>
My mapping is still the same as in OP. Now I don’t know if it is problem in
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Looks like that when one problem is solved another one appeares
Because I already have inspire address mapping in same workspace folder on
geoserver, I get this error:
01 sep 14:30:20 WARN [org.geoserver] - Failed to load namespace for
'inspire_addr'
java.lang.IllegalArgumentException: Namespace with URI
'urn:x-inspire:specification:gmlas:Addresses:3.0' already exists.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-mapping-ELF-Addresses-schema-tp5217968p5222089.html
