[Geoserver-users] Problem painting gifs in SLDs
I´m using GeoServer 1.5.3 on Tomcat5.5.23 with Java 1.5.0_05-b05.
I´ve declared some SLDs for several featuretype on an Oracle Spatial Datastore. They have a gif for every filter in the SLD.
The problem is that sometimes some SLDs are correctly loaded, and some of them not. The SLDs failing are not always the same. All of them have worked fine at any time, but never all together.
The message I obtain when one fails is:
85002 [GRAVE] org.geotools.renderer.lite
.StyledShapePainter - ShapePaniter has been asked to paint a null style!!
Thank you in advance,
Patrick
On Thu, November 8, 2007 3:30 pm, Patrick O'Brian wrote:
85002 [GRAVE] org.geotools.renderer.lite.StyledShapePainter - ShapePaniter
This may be an issue we solved recently. Can you try GeoServer 1.6.0-beta4
and see if it works for you?
