[Geoserver-users] Problem regarding WFS-T
Hi again,
Jukka I don't think it's something that has to do with GWC. In the development machine I get the following once the insertion has been done successfully:
2014-12-09 15:23:08,704 INFO [org.geoserver.gwc.GWCCleanser] - Deleting GWC cache for IKT:GestforeRodalesEtrs89_wfst
2014-12-09 15:23:08,704 TRACE [org.geotools.core] - ENTRY -12,345
2014-12-09 15:23:08,704 DEBUG [org.geotools.jdbc] - SELECT GID,PLAN,TH,MUN,POL,PAR,SUB,UA,UI,TOPONIMO,GEOMETRY as GEOMETRY FROM USRGESTFORE.GT_GESTFORE_RODALES_ET89 WHERE 0 = 1
2014-12-09 15:23:08,735 INFO [org.geoserver.gwc.GWCCleanser] - GWC cache for IKT:GestforeRodalesEtrs89_wfst deleted successfully
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting PLAN to XX-0005
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 0 to XX-0005
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting TH to 48
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 1 to 48
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting MUN to 003
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 2 to 003
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting POL to 018
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 3 to 018
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting PAR to 00009
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 4 to 00009
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting SUB to -
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 5 to -
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting UA to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 6 to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting UI to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 7 to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting TOPONIMO to null
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 8 to null
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting GEOMETRY to POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 9 to POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))
2014-12-09 15:23:08,766 DEBUG [org.geotools.jdbc] - Getting next FID: SELECT MAX(GID) + 1 FROM USRGESTFORE.GT_GESTFORE_RODALES_ET89
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - Inserting new feature with ps: INSERT INTO USRGESTFORE.GT_GESTFORE_RODALES_ET89 ( PLAN,TH,MUN,POL,PAR,SUB,UA,UI,TOPONIMO,GEOMETRY,GID ) VALUES ( ?,?,?,?,?,?,?,?,?,?,?)
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 1 = XX-0005
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 2 = 48
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 3 = 003
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 4 = 018
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 5 = 00009
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 6 = -
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 7 = 1
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 8 = 1
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 9 = null
2014-12-09 15:23:08,829 TRACE [org.geotools.data.oracle.sdo] - ordinates D:2
2014-12-09 15:23:08,829 TRACE [org.geotools.data.oracle.sdo] - ordinates L:0
2014-12-09 15:23:08,844 DEBUG [org.geotools.data.oracle.sdo] - Using layer SRID: 83030
2014-12-09 15:23:08,844 DEBUG [org.geotools.jdbc] - Setting parameter 10 as MDSYS.SDO_GEOMETRY(2003,83030,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY(525606.08,4783263.96,525589.3,4783276.48,525566.37,4783296.21,525563.51,4783277.65,525541.23,4783251.04,525527.57,4783236.84,525496.35,4783214.86,525463.17,4783193.49,525429.83,4783174.87,525402.88,4783161.04,525389.51,4783153.02,525397.12,4783143.75,525406.69,4783127.91,525417.53,4783113.09,525429.44,4783099.06,525441.08,4783086.42,525454.19,4783077.35,525461.65,4783071.64,525480.96,4783079.46,525506.32,4783090.58,525522.28,4783097.25,525526.81,4783099.27,525532.84,4783101.96,525539.58,4783115.26,525553.11,4783141.93,525574.8,4783182.69,525591.19,4783217.62,525598.52,4783240.12,525599.12,4783241.97,525601.45,4783252.26,525606.08,4783263.96))
2014-12-09 15:23:08,844 DEBUG [org.geotools.jdbc] - 10 = POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))
2014-12-09 15:23:08,844 DEBUG [org.geotools.jdbc] - 12 = 501371
2014-12-09 15:23:09,376 INFO [org.geoserver.wfs] -
Request: transaction
  handle = null
  service = WFS
  version = 1.1.0
  baseUrl = http://192.168.3.15:80/geoserver/
  providedVersion = null
  lockId = null
  group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com... (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  update =
  delete =
  native =
  releaseAction = ALL
2014-12-09 15:23:09,376 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-12-09 15:23:09,423 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
And in the production environment machine I get this
2014-12-10 14:54:52,782 INFO [org.geoserver.gwc.GWCCleanser] - Deleting GWC cache for IKT:GestforeRodalesEtrs89_wfst
2014-12-10 14:54:52,782 ERROR [org.geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Error performing insert
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:204)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:334)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:109)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:163)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy19.transaction(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:599)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:230)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:879)
  at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
  at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
  at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
  at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
  at org.geoserver.gwc.GWCTransactionListener.dataStoreChange(GWCTransactionListener.java:61)
  at org.geoserver.wfs.Transaction$TransactionListenerMux.dataStoreChange(Transaction.java:624)
  at org.geoserver.wfs.Transaction$TransactionListenerMux.dataStoreChange(Transaction.java:631)
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:172)
  ... 70 more
2014-12-10 14:54:52,782 INFO [org.geoserver.wfs] -
  handle = null
  service = WFS
  version = 1.1.0
  baseUrl = http://geo.ikt.es:80/geoserver/
  lockId = null
  group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com... (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GID<GID id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GID<GID id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  update =
  delete =
  native =
  releaseAction = ALL
2014-12-10 14:54:52,782 INFO [org.geoserver.gwc.GWCCleanser] - GWC cache for IKT:GestforeRodalesEtrs89_wfst deleted successfully
2014-12-10 14:54:52,782 ERROR [org.geoserver.ows] -
org.geoserver.wfs.WFSException: Error performing insert
  at org.geoserver.wfs.response.TransactionResponse.v_1_1(TransactionResponse.java:197)
  at org.geoserver.wfs.response.TransactionResponse.write(TransactionResponse.java:67)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:726)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
2014-12-10 14:54:56,000 DEBUG [org.geoserver.filters] - filtering http://geo.ikt.es/geoserver/web/
2014-12-10 14:56:54,028 DEBUG [org.geoserver.filters] - filtering http://geo.ikt.es/geoserver/wms
Indeed, the fact that the same layer linked from the development environment is working, it totally baffles me.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda@anonymised.com | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
