[Geoserver-users] Problem regarding WFS-T
Hi again,
According to the source code, the block of code in which it fails is:
if (!response.getTransactionResults().getAction().isEmpty()) {
            //since we do atomic transactions, an action failure means all we rolled back
            // spec says to throw exception
            ActionType action = (ActionType) response.getTransactionResults().getAction().iterator()
                                                     .next();
            throw new WFSException(action.getMessage(), action.getCode(), action.getLocator());
So I assume the reason why is throwing the exception is because response.getTransactionResults().getAction() is not empty. What's exactly returning? What are the possible values? What implications have each on?
I've been looking at some logs in DB but it looks like if the request is not reaching to the server.
Any ideas?
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda@anonymised.com | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
-----Mensaje original-----
De: David Alda Fernandez de Lezea [mailto:dalda@anonymised.com]
Enviado el: jueves, 11 de diciembre de 2014 8:27
Para: Rahkonen Jukka (Tike); geoserver-users@lists.sourceforge.net
Asunto: Re: [Geoserver-users] Problem regarding WFS-T
Hi again,
Jukka I don't think it's something that has to do with GWC. In the development machine I get the following once the insertion has been done successfully:
2014-12-09 15:23:08,704 INFO [org.geoserver.gwc.GWCCleanser] - Deleting GWC cache for IKT:GestforeRodalesEtrs89_wfst
2014-12-09 15:23:08,704 TRACE [org.geotools.core] - ENTRY -12,345
2014-12-09 15:23:08,704 DEBUG [org.geotools.jdbc] - SELECT GID,PLAN,TH,MUN,POL,PAR,SUB,UA,UI,TOPONIMO,GEOMETRY as GEOMETRY FROM USRGESTFORE.GT_GESTFORE_RODALES_ET89 WHERE 0 = 1
2014-12-09 15:23:08,735 INFO [org.geoserver.gwc.GWCCleanser] - GWC cache for IKT:GestforeRodalesEtrs89_wfst deleted successfully
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting PLAN to XX-0005
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 0 to XX-0005
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting TH to 48
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 1 to 48
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting MUN to 003
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 2 to 003
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting POL to 018
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 3 to 018
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting PAR to 00009
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 4 to 00009
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting SUB to -
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 5 to -
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting UA to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 6 to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting UI to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 7 to 1
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting TOPONIMO to null
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 8 to null
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting GEOMETRY to POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))
2014-12-09 15:23:08,751 DEBUG [org.geotools.jdbc] - Setting 9 to POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))
2014-12-09 15:23:08,766 DEBUG [org.geotools.jdbc] - Getting next FID: SELECT MAX(GID) + 1 FROM USRGESTFORE.GT_GESTFORE_RODALES_ET89
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - Inserting new feature with ps: INSERT INTO USRGESTFORE.GT_GESTFORE_RODALES_ET89 ( PLAN,TH,MUN,POL,PAR,SUB,UA,UI,TOPONIMO,GEOMETRY,GID ) VALUES ( ?,?,?,?,?,?,?,?,?,?,?)
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 1 = XX-0005
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 2 = 48
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 3 = 003
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 4 = 018
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 5 = 00009
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 6 = -
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 7 = 1
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 8 = 1
2014-12-09 15:23:08,782 DEBUG [org.geotools.jdbc] - 9 = null
2014-12-09 15:23:08,829 TRACE [org.geotools.data.oracle.sdo] - ordinates D:2
2014-12-09 15:23:08,829 TRACE [org.geotools.data.oracle.sdo] - ordinates L:0
2014-12-09 15:23:08,844 DEBUG [org.geotools.data.oracle.sdo] - Using layer SRID: 83030
2014-12-09 15:23:08,844 DEBUG [org.geotools.jdbc] - Setting parameter 10 as MDSYS.SDO_GEOMETRY(2003,83030,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY(525606.08,4783263.96,525589.3,4783276.48,525566.37,4783296.21,525563.51,4783277.65,525541.23,4783251.04,525527.57,4783236.84,525496.35,4783214.86,525463.17,4783193.49,525429.83,4783174.87,525402.88,4783161.04,525389.51,4783153.02,525397.12,4783143.75,525406.69,4783127.91,525417.53,4783113.09,525429.44,4783099.06,525441.08,4783086.42,525454.19,4783077.35,525461.65,4783071.64,525480.96,4783079.46,525506.32,4783090.58,525522.28,4783097.25,525526.81,4783099.27,525532.84,4783101.96,525539.58,4783115.26,525553.11,4783141.93,525574.8,4783182.69,525591.19,4783217.62,525598.52,4783240.12,525599.12,4783241.97,525601.45,4783252.26,525606.08,4783263.96))
2014-12-09 15:23:08,844 DEBUG [org.geotools.jdbc] - 10 = POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))
2014-12-09 15:23:08,844 DEBUG [org.geotools.jdbc] - 12 = 501371
2014-12-09 15:23:09,376 INFO [org.geoserver.wfs] -
Request: transaction
  handle = null
  service = WFS
  version = 1.1.0
  baseUrl = http://192.168.3.15:80/geoserver/
  providedVersion = null
  lockId = null
  group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com... (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  update =
  delete =
  native =
  releaseAction = ALL
2014-12-09 15:23:09,376 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-12-09 15:23:09,423 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
And in the production environment machine I get this
2014-12-10 14:54:52,782 INFO [org.geoserver.gwc.GWCCleanser] - Deleting GWC cache for IKT:GestforeRodalesEtrs89_wfst
2014-12-10 14:54:52,782 ERROR [org.geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Error performing insert
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:204)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:334)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:109)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:163)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy19.transaction(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:599)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:230)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:879)
  at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
  at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
  at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
  at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
  at org.geoserver.gwc.GWCTransactionListener.dataStoreChange(GWCTransactionListener.java:61)
  at org.geoserver.wfs.Transaction$TransactionListenerMux.dataStoreChange(Transaction.java:624)
  at org.geoserver.wfs.Transaction$TransactionListenerMux.dataStoreChange(Transaction.java:631)
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:172)
  ... 70 more
2014-12-10 14:54:52,782 INFO [org.geoserver.wfs] -
  handle = null
  service = WFS
  version = 1.1.0
  baseUrl = http://geo.ikt.es:80/geoserver/
  lockId = null
  group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com... (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GID<GID id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [SimpleFeatureImpl:GestforeRodalesEtrs89_wfst=[SimpleFeatureImpl.Attribute: PLAN<PLAN id=F0>=XX-0005, SimpleFeatureImpl.Attribute: TH<TH id=F0>=48, SimpleFeatureImpl.Attribute: MUN<MUN id=F0>=003, SimpleFeatureImpl.Attribute: POL<POL id=F0>=018, SimpleFeatureImpl.Attribute: PAR<PAR id=F0>=00009, SimpleFeatureImpl.Attribute: SUB<SUB id=F0>=-, SimpleFeatureImpl.Attribute: UA<UA id=F0>=1, SimpleFeatureImpl.Attribute: UI<UI id=F0>=1, SimpleFeatureImpl.Attribute: TOPONIMO<TOPONIMO id=F0>=null, SimpleFeatureImpl.Attribute: GID<GID id=F0>=null, SimpleFeatureImpl.Attribute: GEOMETRY<GEOMETRY id=F0>=POLYGON ((525606.08 4783263.96, 525601.45 4783252.26, 525599.12 4783241.97, 525598.52 4783240.12, 525591.19 4783217.62, 525574.8 4783182.69, 525553.11 4783141.93, 525539.58 4783115.26, 525532.84 4783101.96, 525526.81 4783099.27, 525522.28 4783097.25, 525506.32 4783090.58, 525480.96 4783079.46, 525461.65 4783071.64, 525454.19 4783077.35, 525441.08 4783086.42, 525429.44 4783099.06, 525417.53 4783113.09, 525406.69 4783127.91, 525397.12 4783143.75, 525389.51 4783153.02, 525402.88 4783161.04, 525429.83 4783174.87, 525463.17 4783193.49, 525496.35 4783214.86, 525527.57 4783236.84, 525541.23 4783251.04, 525563.51 4783277.65, 525566.37 4783296.21, 525589.3 4783276.48, 525606.08 4783263.96))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  update =
  delete =
  native =
  releaseAction = ALL
2014-12-10 14:54:52,782 INFO [org.geoserver.gwc.GWCCleanser] - GWC cache for IKT:GestforeRodalesEtrs89_wfst deleted successfully
2014-12-10 14:54:52,782 ERROR [org.geoserver.ows] -
org.geoserver.wfs.WFSException: Error performing insert
  at org.geoserver.wfs.response.TransactionResponse.v_1_1(TransactionResponse.java:197)
  at org.geoserver.wfs.response.TransactionResponse.write(TransactionResponse.java:67)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:726)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
2014-12-10 14:54:56,000 DEBUG [org.geoserver.filters] - filtering http://geo.ikt.es/geoserver/web/
2014-12-10 14:56:54,028 DEBUG [org.geoserver.filters] - filtering http://geo.ikt.es/geoserver/wms
Indeed, the fact that the same layer linked from the development environment is working, it totally baffles me.
Agur bero bat,
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
More tests.... I've managed to delete some features, so the comunication is OK, but the insertion of data still fails....
I've been thinking about the possible problems. How about workspace and namespaces? I've recently created two new workspaces with their own datastores(shapefiles) . Could there be some misunderstanding in Geoserver?
Thanks.
Agur bero bat,
Enviado el: viernes, 12 de diciembre de 2014 11:23
Para: geoserver-users@lists.sourceforge.net
Hi again,
                                                     .next();
Any ideas?
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290 Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER ***************************** Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Ha again,
Still looking for a solution. If I made an update transaction I get this error:
org.geoserver.wfs.WFSException: java.lang.NullPointerException
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:115)
  at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:219)
  ... 68 more
Agur bero bat,
Enviado el: viernes, 12 de diciembre de 2014 13:13
Asunto: [Geoserver-users] RV: Problem regarding WFS-T
Thanks.
Agur bero bat,
De: David Alda Fernandez de Lezea [mailto:dalda@anonymised.com] Enviado el: viernes, 12 de diciembre de 2014 11:23
Hi again,
                                                     .next();
Any ideas?
Agur bero bat,
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server from Actuate! Instantly Supercharge Your Business Reports and Dashboards with Interactivity, Sharing, Native Excel Exports, App Integration & more Get technology previously reserved for billion-dollar corporations, FREE http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Hi list,
I'm really stuck with this... I've tried to edit features using QGIS and it fails as well... Any ideas? As I mentioned before the code seems to stop at
So..
What's exactly returning? What are the possible values? What implications have each one?
Any help is much appreciated.
Thanks in advance
Agur bero bat,
Enviado el: lunes, 15 de diciembre de 2014 8:48
Asunto: [Geoserver-users] RV: RV: Problem regarding WFS-T
Ha again,
  at java.lang.Thread.run(Unknown Source) Caused by: java.lang.NullPointerException
  ... 68 more
Agur bero bat,
De: David Alda Fernandez de Lezea [mailto:dalda@anonymised.com] Enviado el: viernes, 12 de diciembre de 2014 13:13
Thanks.
Agur bero bat,
Hi again,
                                                     .next();
Any ideas?
Agur bero bat,
It looks like from the code snippet that a WFSException is thrown with the details of the failed action. So the exception returned should provide some information…
Are you able to run in a debugger and use a breakpoint to inspect those variables?
On 12 December 2014 at 04:12, David Alda Fernandez de Lezea <dalda@anonymised.com> wrote:
More tests… I’ve managed to delete some features, so the comunication is OK, but the insertion of data still fails…
I’ve been thinking about the possible problems. How about workspace and namespaces? I’ve recently created two new workspaces with their own datastores(shapefiles) . Could there be some misunderstanding in Geoserver?
Thanks.
Agur bero bat,
Hi again,
.next();
So I assume the reason why is throwing the exception is because response.getTransactionResults().getAction() is not empty. What’s exactly returning? What are the possible values? What implications have each on?
I’ve been looking at some logs in DB but it looks like if the request is not reaching to the server.
Any ideas?
Agur bero bat,
Jody Garnett
Hi Jody,
I’m trying to set the Project up into eclipse following these instructions https://svn.codehaus.org/geoserver/branches/2.0.x/src/README.txt but without success. I can’t build the project as I get many errors….
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:/Datos/Proyectos/35_geoserver/geoserver-2.0.2/2.0.x/src/ows/src/main/java/org/
geoserver/ows/util/EMFLogger.java:[9,29] package org.eclipse.emf.ecore does not
exist
geoserver/ows/util/EMFLogger.java:[10,29] package org.eclipse.emf.ecore does not
exist
geoserver/ows/util/EMFLogger.java:[57,13] cannot find symbol
symbol : class EObject
geoserver/ows/KvpRequestReader.java:[8,25] cannot find symbol
symbol : class Converters
geoserver/ows/xml/v1_0/OWSSchemaLocationResolver.java:[7,23] package org.eclipse
.xsd does not exist
geoserver/ows/xml/v1_0/OWSSchemaLocationResolver.java:[8,28] package org.eclipse
.xsd.util does not exist
geoserver/ows/xml/v1_0/OWSSchemaLocationResolver.java:[11,50] cannot find symbol
symbol: class XSDSchemaLocationResolver
public class OWSSchemaLocationResolver implements XSDSchemaLocationResolver {
geoserver/ows/xml/v1_0/OWSSchemaLocationResolver.java:[12,40] cannot find symbol
symbol : class XSDSchema
location: class org.geoserver.ows.xml.v1_0.OWSSchemaLocationResolver
geoserver/ows/kvp/EMFKvpRequestReader.java:[11,29] package org.eclipse.emf.ecore
does not exist
geoserver/ows/kvp/EMFKvpRequestReader.java:[12,29] package org.eclipse.emf.ecore
does not exist
geoserver/ows/kvp/EMFKvpRequestReader.java:[32,14] cannot find symbol
symbol : class EFactory
location: class org.geoserver.ows.kvp.EMFKvpRequestReader
geoserver/ows/kvp/EMFKvpRequestReader.java:[39,50] cannot find symbol
geoserver/ows/xml/v1_0/OWSConfiguration.java:[11,25] package org.picocontainer d
oes not exist
geoserver/ows/xml/v1_0/OWSConfiguration.java:[30,36] cannot find symbol
symbol : class MutablePicoContainer
location: class org.geoserver.ows.xml.v1_0.OWSConfiguration
geoserver/ows/xml/v1_0/OWSConfiguration.java:[84,36] cannot find symbol
geoserver/ows/util/NumericKvpParser.java:[8,25] cannot find symbol
geoserver/ows/Ows11Util.java:[15,28] package org.geotools.feature does not exist
geoserver/ows/Ows11Util.java:[17,32] package org.opengis.feature.type does not e
xist
geoserver/ows/Ows11Util.java:[18,24] package org.opengis.util does not exist
geoserver/ows/Ows11Util.java:[34,53] cannot find symbol
symbol : class InternationalString
geoserver/ows/Ows11Util.java:[62,32] cannot find symbol
symbol : class Name
geoserver/ows/Ows11Util.java:[62,27] code(java.lang.String) is already defined i
n org.geoserver.ows.Ows11Util
geoserver/ows/Ows11Util.java:[71,18] cannot find symbol
symbol : class Name
geoserver/ows/Ows11Util.java:[132,65] cannot find symbol
geoserver/ows/util/EMFLogger.java:[34,12] cannot find symbol
geoserver/ows/util/EMFLogger.java:[39,40] cannot find symbol
geoserver/ows/util/EMFLogger.java:[40,35] cannot find symbol
geoserver/ows/util/EMFLogger.java:[61,12] cannot find symbol
symbol : class EStructuralFeature
geoserver/ows/util/EMFLogger.java:[61,43] cannot find symbol
geoserver/ows/util/EMFLogger.java:[71,33] cannot find symbol
geoserver/ows/util/EMFLogger.java:[73,21] cannot find symbol
geoserver/ows/KvpRequestReader.java:[176,39] cannot find symbol
symbol : variable Converters
geoserver/ows/xml/v1_0/SectionsTypeBinding.java:[69,27] cannot access org.eclips
e.emf.common.util.EList
file org\eclipse\emf\common\util\EList.class not found
        sections.getSection().addAll(node.getChildValues("Section"));
geoserver/ows/xml/v1_0/AcceptVersionsTypeBinding.java:[42,8] cannot find symbol
symbol : constructor AbstractComplexEMFBinding(net.opengis.ows10.Ows10Factory)
location: class org.geotools.xml.AbstractComplexEMFBinding
geoserver/ows/kvp/EMFKvpRequestReader.java:[43,13] cannot find symbol
geoserver/ows/kvp/EMFKvpRequestReader.java:[75,8] cannot find symbol
geoserver/ows/kvp/EMFKvpRequestReader.java:[75,27] cannot find symbol
geoserver/ows/DefaultServiceExceptionHandler.java:[110,19] cannot access org.ecl
ipse.xsd.XSDNamedComponent
file org\eclipse\xsd\XSDNamedComponent.class not found
            encoder.encode(report, org.geoserver.ows.xml.v1_0.OWS.EXCEPTIONREPOR
T,
geoserver/ows/Dispatcher.java:[568,35] cannot find symbol
geoserver/ows/Dispatcher.java:[568,60] cannot find symbol
geoserver/ows/Dispatcher.java:[571,12] cannot find symbol
geoserver/ows/Dispatcher.java:[571,31] cannot find symbol
geoserver/ows/util/NumericKvpParser.java:[40,15] cannot find symbol
location: class org.geoserver.ows.util.NumericKvpParser
geoserver/ows/Ows11Util.java:[74,23] cannot find symbol
symbol : class NameImpl
geoserver/ows/Ows11Util.java:[78,27] cannot find symbol
geoserver/ows/Ows11Util.java:[80,27] cannot find symbol
geoserver/ows/xml/v1_0/GetCapabilitiesTypeBinding.java:[64,8] cannot find symbol
[INFO] Total time: 1 minute 57 seconds
[INFO] Finished at: Tue Dec 16 10:05:09 CET 2014
[INFO] Final Memory: 24M/43M
C:\Datos\Proyectos\35_geoserver\geoserver-2.0.2\2.0.x\src>
I'm using maven 2.0.9, as suggested in the instructions.
C:\Datos\Proyectos\35_geoserver\geoserver-2.0.2\2.0.x\src>mvn -version
Maven version: 2.0.9
Java version: 1.5.0_18
OS name: "windows xp" version: "5.1" arch: "x86" Family: "windows"
Any ideas how to solve this?
Thanks in advance.
Agur bero bat,
dalda@...6818... | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
De: Jody Garnett [mailto:jody.garnett@…84…]
Enviado el: miércoles, 17 de diciembre de 2014 7:09
Para: David Alda Fernandez de Lezea
CC: geoserver-users@lists.sourceforge.net
Asunto: Re: [Geoserver-users] RV: Problem regarding WFS-T
It looks like from the code snippet that a WFSException is thrown with the details of the failed action. So the exception returned should provide some information...
Jody Garnett
On 12 December 2014 at 04:12, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Thanks.
Agur bero bat,
De: David Alda Fernandez de Lezea [mailto:dalda@…6818…]
Hi again,
.next();
Any ideas?
Agur bero bat,
On Wed, Dec 17, 2014 at 8:41 AM, David Alda Fernandez de Lezea <
Hi Jody,
That GeoServer version is too old, and I believe there are jars missing
from the maven repositories in order to build it.
You should try with 2.6.x
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
I know it's an old version but I thought I had to download that version because that's the version I have in my server. Should I go for 2.6.x? With the same maven version?
Thanks .
Agur bero bat,
De: andrea.aime@...84... [mailto:andrea.aime@…84…] En nombre de Andrea Aime
Enviado el: miércoles, 17 de diciembre de 2014 9:27
CC: Jody Garnett; geoserver-users@lists.sourceforge.net
On Wed, Dec 17, 2014 at 8:41 AM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Hi Jody,
That GeoServer version is too old, and I believe there are jars missing from the maven repositories in order to build it.
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Wed, Dec 17, 2014 at 10:00 AM, David Alda Fernandez de Lezea <
Hi Andrea,
Yeah, it is a good idea, however some of those old jars might be missing
from the repos now, making it difficult to
build GeoServer.
GeoServer 2.6.x is the current stable and it's at least supported by the
community.
You should use Maven 3.x
Ing. Andrea Aime
@geowolf
Technical Lead
