[Geoserver-users] problem rendering labels
I use GeoServer 2.5.1.
I am rendering layers stored in shape files.
In one of my layer, I want to use the TextSymbolizer style element to render label just near items based on one of property.
Style if well configured because I can pre-visualize the shape in GeoServer…
But, the program that make requests based on mapsui library displays the rendered layer using tiles….and in this case, labels are not displayed every time (depending of zoom, label placement, etc…)
So I want to know if there is a way to have all my labels correctly displayed every time ? Is there some hidden configuration in GeoServer or WMS configuration to avoid that. I noticed that this also had an impact of rendering the item itself. By example, an item is rendered with a circle, and I see only half of the circle on the final display, probably because the point is near a tile boundary and is not displayed in one of the rendered tile…
By evidence, I know that the final solution is to change my code so that a single tile would be rendered…but it is hard to implement quickly because it is requiring changing code and redeploying solution…
Regards.
Eric DUCOS
Information System Engineer
Port. + 33 6 15 83 03 56
LOGO-DEXIP(r)
10 quai Émile Cormerais
44800 SAINT-HERBLAIN
Tél. + 33 2 40 58 26 28
www.dexip.com
BANDEAU
Hi Eric,
you can use ‘partials’ as a VendorOption in your style as described at the link below:
http://docs.geoserver.org/latest/en/user/styling/sld-reference/labeling.html#partials
but I think this is available only from v2.6.x, and if needed also ‘conflictResolutions’
http://docs.geoserver.org/2.5.x/en/user/styling/sld-reference/labeling.html#conflictresolution
Maybe you can also use the meta-tiling as described here:
http://docs.geoserver.org/2.5.x/en/user/services/wms/vendor.html#tiled
Tobia Di Pisa
Dott. Ing. Tobia Di Pisa
Software Engineer
Via Poggio alle Viti 1187
Call
Send SMS
Add to Skype
You’ll need Skype CreditFree via Skype
2014-10-22 8:49 GMT+02:00 Eric DUCOS <Eric.DUCOS@anonymised.com>:
Regards.
Eric DUCOS
LOGO-DEXIP(r)
www.dexip.com
BANDEAU
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-users mailing list
