[Geoserver-users] problem running Geoserver using maven
I get the following error when trying to run geoserver using maven, i.e. mvn
jetty:run. However, I was able to complile and build geoserver using maven,
i.e. using mvn compile and mvn install successfully. Please help.
Thanks
Arif
31 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
raster
2008-01-07 18:09:16.968::WARN: failed jsp
ContextHandler@anonymised.com{/geoserver,file:/D
:/1.5.x/geoserver/web/src/main/webapp/}
2008-01-07 18:09:16.968::WARN: failed ContextHandlerCollection@anonymised.com
2008-01-07 18:09:16.968::WARN: failed HandlerCollection@anonymised.com
2008-01-07 18:09:17.015::INFO: Started SelectChannelConnector @
0.0.0.0:8080
2008-01-07 18:09:17.015::WARN: failed Server@anonymised.com
[INFO] Jetty server exiting.
[INFO]
[ERROR] FATAL ERROR
[INFO]
[INFO] javax/servlet/jsp/JspFactory
[INFO]
[INFO] Trace
java.lang.NoClassDefFoundError: javax/servlet/jsp/JspFactory
        at org.apache.jasper.servlet.JspServlet.init(JspServlet.java:118)
        at
org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.jav
a:400)
        at
org.mortbay.jetty.servlet.ServletHolder.doStart(ServletHolder.java:25
4)
        at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
38)
        at
org.mortbay.jetty.servlet.ServletHandler.initialize(ServletHandler.ja
va:569)
        at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1133)
        at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
420)
        at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:457
        at
38)
        at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:156)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:120)
        at
38)
        at
.java:156)
        at
38)
        at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
119)
        at org.mortbay.jetty.Server.doStart(Server.java:210)
        at
38)
        at
org.mortbay.jetty.plugin.Jetty6PluginServer.start(Jetty6PluginServer.
java:134)
        at
org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMo
jo.java:327)
        at
org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.
java:272)
        at
org.mortbay.jetty.plugin.AbstractJettyRunMojo.execute(AbstractJettyRu
nMojo.java:177)
        at
org.mortbay.jetty.plugin.Jetty6RunMojo.execute(Jetty6RunMojo.java:183
        at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPlugi
nManager.java:447)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(Defa
ultLifecycleExecutor.java:539)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeStandalone
Goal(DefaultLifecycleExecutor.java:493)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(Defau
ltLifecycleExecutor.java:463)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHan
dleFailures(DefaultLifecycleExecutor.java:311)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegmen
ts(DefaultLifecycleExecutor.java:278)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLi
fecycleExecutor.java:143)
        at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:333)
        at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:126)
        at org.apache.maven.cli.MavenCli.main(MavenCli.java:282)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at
org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
        at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
        at
org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
        at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO]
[INFO] Total time: 3 minutes 56 seconds
[INFO] Finished at: Mon Jan 07 18:09:17 GMT 2008
[INFO] Final Memory: 14M/26M
[INFO]
2008-01-07 18:09:17.250::INFO: Shutdown hook executing
2008-01-07 18:09:17.250::INFO: Shutdown hook complete
View this message in context: http://www.nabble.com/problem-running-Geoserver-using-maven-tp14689820p14689820.html
Which version of java are you using? mnv jetty:run is known not to be working with java 4.
I haven't used that way of starting up geoserver since months ago thought, the more handy way being to start geoserver right
within the developer environment (the Start class in the web module).
