On Wed, Oct 22, 2014 at 8:15 PM, Stephen Brooke <sbrooke@anonymised.com>
wrote:
If updating the bbox of the layer allows WMS requests to see the newly
harvested granules then my answer is yes, it doesn’t update the bbox
advertised in GetCapabilities.
No, it's unrelated to WMS actually displaying the granule, if the client
makes are request covering the new granule, it should show.
But it can be a factor if you are using a client that won't allow you to
zoom out enough to see the new granule, or won't allow you to pan to the
area where the granule is (and most clients drive this by reading the caps
document).
Should it work if I just specify the whole globe as the bbox, for example
if the WMS GetCapabilities for my ImageMosaic layer has:
<CRS>EPSG:4326</CRS>
<CRS>CRS:84</CRS>
<EX_GeographicBoundingBox>
<westBoundLongitude>-180.0</westBoundLongitude>
<eastBoundLongitude>180.0</eastBoundLongitude>
<southBoundLatitude>-90.0</southBoundLatitude>
<northBoundLatitude>90.0</northBoundLatitude>
</EX_GeographicBoundingBox>
<BoundingBox CRS="CRS:84"
minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/>
<BoundingBox CRS="EPSG:4326"
minx="-90.0" miny="-180.0" maxx="90.0" maxy="180.0"/>
You might want to try it, it would help understanding if the issue is in
the granule not being harvested, or because the bbox is not updated and the
client just won't show it out as a result
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
