[Geoserver-users] Problem serving WMS requests
Hello,
I’m new to Geoserver but I found it a very interesting mapserver solution. We’ve done many tests and found a problem when serving WMS requests that ask for PNG8 images:
1st. We serve two layers, one containing point data and the other linear, both shapefiles.
2nd We make WMS requests specifying PNG8 as response.
3rd The delivered PNG8 images have a grey background (instead of a transparent one) when there’s no data in the area. For instance, in the case of the point data, if no point is covered by the bounding box specified, a grey image is returned. Instead, if a point (or points) is inside the bounding area, a well done image is generated.
We haven’t experienced the same problem when serving PNG (24 bits) or GIF images. In these cases everything works fine.
Anyone else has noticed this? Do you know how to solve it?
Thaks in advance and best regards,
Juan Carlos González
Catalonian Cartographic Institute
I created the GEOS-1855 issue at jira.codehaus [1] stating this.
–Hope this is the correct thing to do, we’re just starting seriously with FOSS :slight_smile:
Any quick hack or advise to solve the issue would be greatly apreciated, though.
Oscar Fonts.
Troublemaker @ Institut Cartogràfic de Catalunya.
[1] http://jira.codehaus.org/browse/GEOS-1855
2008/4/7, Gonzalez, Juan Carlos juan_carlos.gonzalez@anonymised.com:
Hello,
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Register now and save $200. Hurry, offer ends at 11:59 p.m.,
Monday, April 7! Use priority code J8TLD2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
Geoserver-users@anonymised.comt
Check (in the JavaScript) whether you're dealing with IE6, if so use GIF ?
-Arne
Oscar Fonts wrote:
--Hope this is the correct thing to do, we're just starting seriously with FOSS :slight_smile:
Oscar Fonts.
2008/4/7, Gonzalez, Juan Carlos <juan_carlos.gonzalez@anonymised.com>:
    Hello,
    I'm new to Geoserver but I found it a very interesting mapserver
    solution. We've done many tests and found a problem when serving
    1^st . We serve two layers, one containing point data and the
    2^nd We make WMS requests specifying PNG8 as response.
    3^rd The delivered PNG8 images have a grey background (instead of
    a transparent one) when there's no data in the area. For instance,
    is generated.
    We haven't experienced the same problem when serving PNG (24 bits)
    <mailto:Geoserver-users@lists.sourceforge.net>
!DSPAM:4038,47fa797a96991637810514!
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Register now and save $200. Hurry, offer ends at 11:59 p.m., Monday, April 7! Use priority code J8TLD2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Hi Arne,
Thanks for your quick reply, but we already know that’s an IE6 issue. The problem is that some developers made a third party application for us and this application expects for PNG as the incoming image format. We can not change this thing on this application.
Cheers!
Juan Carlos
De: Arne Kepp [mailto:ak@anonymised.com]
Enviado el: lun 07/04/2008 22:03
Para: Oscar Fonts
CC: geoserver-users@lists.sourceforge.net; Gonzalez, Juan Carlos
Asunto: Re: [Geoserver-users] Problem serving WMS requests
Check (in the JavaScript) whether you’re dealing with IE6, if so use GIF ?
-Arne
Oscar Fonts wrote:
apreciated, though.
Oscar Fonts.
Hello,
is generated.
<mailto:Geoserver-users@anonymised.comurceforge.net>
Made some more testing, and we’re getting corrupt PNGs (see issue tracker).
Not IE’s fault, this time.
Oscar.
