[Geoserver-users] Problem uploading shapefile via rest
I am attempting to upload a shapefile via the rest configuration tool and it
is failing to configure the map's feature types. I am putting the zip file
to /geoserver/rest/workspaces/SCAMBS/datastores/UploadTest/file.shp but this
is producing the following error message:
11 May 08:47:41 ERROR [geoserver.global] - Could not load feature type
SCAMBS:Fh_apr_09_comp_region java.lang.NullPointerException
        at org.geotools.referencing.CRS.decode(CRS.java:419)
        at org.geotools.referencing.CRS.decode(CRS.java:348)
        at
org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:1008)
        at
org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:522)
        at org.vfny.geoserver.global.Data.toDTO(Data.java:1604)
        at
org.geoserver.catalog.rest.CatalogResourceBase.saveCatalog(CatalogResourceBase.java:69)
        at
org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:285)
I had a search for this error in these forums and found a similar post which
was solved by adding the prj file to the shapefile zip, however the zip that
I am using already contains a prj file. Does anyone know what may be causing
this?
View this message in context: http://www.nabble.com/Problem-uploading-shapefile-via-rest-tp23478734p23478734.html
Hmmm... can you include the .prj file that is being used? Actually if you could make th entire zip available it would make figuring out the issue much easier rather than guessing.
Also, are you using cURL to do the upload?
-Justin
dk80 wrote:
        at
        at
        at
        at
this?
Justin Deoliveira
OpenGeo - http://opengeo.org
