[Geoserver-users] problem using different palettes
Hi list,
we have encountered a problem with Geoserver 2.5 using palette files.
It seems, that (after Tomcat restart) the first palette file to be used in a
wms getmap request, will be used in all other wms getmap requests, that have
&palette= defined, as well. To make it clear, even if we define another
palette in the wms getmap request, the one that has been used first (after
tomcat restart) will be called.
'Clear cache' or 'Reload configuration' does not help, the only way we have
found to define a new palette is to restart Tomcat.
This leads to the fact, that it is possible to use only one palette file in
Geoserver. Is this the intention, or does it sound like a bug?
(If no palette is defined, the output is a normal png without any palette
definitions)
best regards,
Jakob
View this message in context: http://osgeo-org.1560.x6.nabble.com/problem-using-different-palettes-tp5137653.html
That sounds like a bug :slight_smile: Are you comfortable reporting it to the geoserver issue tracker?
Jody Garnett
On 29 April 2014 at 3:44:34 pm, Jakob Ventin (jventin@anonymised.com) wrote:
Hi list,
‘Clear cache’ or ‘Reload configuration’ does not help, the only way we have
definitions)
best regards,
Jakob
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
Best Open Source Mac Front-Ends 2024
Geoserver-users mailing list
well, I am trying to learn...
I created this bug report: https://jira.codehaus.org/browse/GEOS-6474
-Jakob
Jody Garnett
jventin@
) wrote:
Hi list,
a
have
have
in
definitions)
best regards,
Jakob
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
available.
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
Geoserver-users@anonymised.com
available.
View this message in context: http://osgeo-org.1560.x6.nabble.com/problem-using-different-palettes-tp5137653p5138534.html
