[Geoserver-users] Problem using GeoTIFF width*height > Integer.MAX_VALUE
I’m getting the exception below when trying to render a GeoTiff. The image is 4500055000. Other GeoTiffs that I use that are slightly smaller works fine, it.e when widthheight is less than Integer.MAX_VALUE.
A similar report was posted in imageio user discussions, probably when used in another software… but from what I could understand it’s not necessarily a imageio bug, might be how the api is/can be used - that’s why I’m reporting this here.
A workaround would be to use ImageMosaic but I would rather use large GeoTiffs.
I’m running Geoserver 1.6.2 in tomcat with JRE 1.6.0 update 6 on windows, all 32-bit with native jai and imageio (latest versions).
/Björn
2008-04-17 01:35:19,922 WARN [geotools.rendering] - widthheight > Integer.MAX_VALUE!
java.lang.IllegalArgumentException: width
at javax.imageio.ImageReader.getDestination(Unknown Source)
at com.sun.media.imageioimpl.plugins.tiff.TIFFImageReader.read(TIFFImageReader.java:1154)
at com.sun.media.jai.imageioimpl.ImageReadOpImage.computeTile(ImageReadOpImage.java:697)
at com.sun.media.jai.util.SunTileScheduler.scheduleTile(SunTileScheduler.java:904)
at javax.media.jai.OpImage.getTile(OpImage.java:1129)
at com.sun.media.jai.opimage.CropOpImage.getTile(CropOpImage.java:122)
at javax.media.jai.PlanarImage.copyData(PlanarImage.java:2343)
at javax.media.jai.PlanarImage.copyExtendedData(PlanarImage.java:2398)
at javax.media.jai.PlanarImage.getExtendedData(PlanarImage.java:2459)
at javax.media.jai.ScaleOpImage.computeTile(ScaleOpImage.java:1255)
at javax.media.jai.RenderedOp.getTile(RenderedOp.java:2257)
at com.sun.media.jai.iterator.RectIterCSM.setDataBuffer(RectIterCSM.java:70)
at com.sun.media.jai.iterator.RectIterFallback.(RectIterFallback.java:147)
at com.sun.media.jai.iterator.RectIterCSM.(RectIterCSM.java:36)
at com.sun.media.jai.iterator.RectIterCSMByte.(RectIterCSMByte.java:25)
at javax.media.jai.iterator.RectIterFactory.create(RectIterFactory.java:72)
at org.geotools.coverage.grid.Grid2DSampleDimension.create(Grid2DSampleDimension.java:144)
at org.geotools.coverage.grid.GridCoverage2D.(GridCoverage2D.java:251)
Ciao Bjorn,
in order to help you out I'd need a few information about your data as
well as about the version of geotools you are using.
is you tiff tiled? (a gdalinfo on it migt help out)
which version of geotools are you using?
Ciao,
Simone.
On Thu, Apr 17, 2008 at 2:12 AM, Björn Harrtell
<bjorn.harrtell@anonymised.com> wrote:
I'm getting the exception below when trying to render a GeoTiff. The image
is 45000*55000. Other GeoTiffs that I use that are slightly smaller works
fine, it.e when width*height is less than Integer.MAX_VALUE.
in another software... but from what I could understand it's not necessarily
a imageio bug, might be how the api is/can be used - that's why I'm
GeoTiffs.
I'm running Geoserver 1.6.2 in tomcat with JRE 1.6.0 update 6 on windows,
/Björn
2008-04-17 01:35:19,922 WARN [geotools.rendering] - width*height >
Integer.MAX_VALUE!
java.lang.IllegalArgumentException: width*height > Integer.MAX_VALUE!
at
at
at
at
at
at
com.sun.media.jai.iterator.RectIterFallback.<init>(RectIterFallback.java:147)
at com.sun.media.jai.iterator.RectIterCSM.<init>(RectIterCSM.java:36)
at
com.sun.media.jai.iterator.RectIterCSMByte.<init>(RectIterCSMByte.java:25)
at
at
org.geotools.coverage.grid.GridCoverage2D.<init>(GridCoverage2D.java:251)
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
Ok thanks!
The image is a GeoTIFF that I have made with gdal_translate. It’s indexed colored and LZW packed with inner tiling (default 256x256 blocks) and overviews 2 4 8 16
I’m running an unmodified deployment of geoserver 1.6.2 so it should be geotools 2.4.1.
Below is gdalinfo output of the mentioned image that causes the exception and the same for another slightly smaller image that does work.
Driver: GTiff/GeoTIFF
Files: vagkarta1.tif
Size is 45000, 55000
Coordinate System is:
PROJCS[“RT90 2.5 gon W”,
GEOGCS[“RT90”,
DATUM[“Rikets_koordinatsystem
_1990”,
SPHEROID[“Bessel 1841”,6377397.155,299.1528128000009,
AUTHORITY[“EPSG”,“7004”]],
AUTHORITY[“EPSG”,“6124”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4124”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,15.80827777777778],
PARAMETER[“scale_factor”,1],
PARAMETER[“false_easting”,1500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“2400”]]
Origin = (1200000.000000000000000,6650000.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 1200000.000, 6650000.000)
Lower Left ( 1200000.000, 6100000.000)
Upper Right ( 1650000.000, 6650000.000)
Lower Right ( 1650000.000, 6100000.000)
Center ( 1425000.000, 6375000.000)
Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
Overviews: 22500x27500, 11250x13750, 5625x6875, 2813x3438
Color Table (RGB with 256 entries)
0: 0,0,0,255
1: 16,16,16,255
… (the rest is palette values)
Next image:
Files: oversikt1.tif
Size is 44000, 44000
GEOGCS[“RT90”,
DATUM[“Rikets_koordinatsystem_1990”,
UNIT[“metre”,1,
Pixel Size = (12.500000000000000,-12.500000000000000)
Metadata:
AREA_OR_POINT=Area
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Right ( 1750000.000, 6650000.000)
Lower Right ( 1750000.000, 6100000.000)
Center ( 1475000.000, 6375000.000)
Overviews: 22000x22000, 11000x11000, 5500x5500, 2750x2750
0: 255,255,255,255
1: 255,255,255,255
On Mon, Apr 21, 2008 at 2:05 AM, Simone Giannecchini <simboss1@…84…> wrote:
Ciao Bjorn,
in order to help you out I’d need a few information about your data as
Ciao,
Simone.
GeoTiffs.
/Björn
Integer.MAX_VALUE!
at
at
at
at
at
at
at
at
at
Don’t miss this year’s exciting event. There’s still time to save $100.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ciao Bjorn,
I am sorry it has been a while since you uploaded the file.
I just tried it for geoserver trunk and it worked without problems.
I am rebuilding the 2.4.x branch in order to check things on that
branch, but meanwhile can you please tell me which versions of imageio
and jai you are using?
Simone.
On Mon, Apr 21, 2008 at 7:41 AM, Björn Harrtell
Ok thanks!
The image is a GeoTIFF that I have made with gdal_translate. It's indexed
overviews 2 4 8 16
I'm running an unmodified deployment of geoserver 1.6.2 so it should be
geotools 2.4.1.
PROJCS["RT90 2.5 gon W",
    GEOGCS["RT90",
        DATUM["Rikets_koordinatsystem
_1990",
            SPHEROID["Bessel 1841",6377397.155,299.1528128000009,
                AUTHORITY["EPSG","7004"]],
            AUTHORITY["EPSG","6124"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4124"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",15.80827777777778],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",1500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","2400"]]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
    0: 0,0,0,255
    1: 16,16,16,255
..... (the rest is palette values)
Next image:
    GEOGCS["RT90",
        DATUM["Rikets_koordinatsystem_1990",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
    0: 255,255,255,255
    1: 255,255,255,255
On Mon, Apr 21, 2008 at 2:05 AM, Simone Giannecchini <simboss1@anonymised.com>
wrote:
Ciao Bjorn,
Ciao,
Simone.
> image
> works
> used
> necessarily
> GeoTiffs.
> windows,
> /Björn
> Integer.MAX_VALUE!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ciao Bjorn I just tried the 2.4.x branch of geotools against 1.6.x
branch of geoserver and things worked fine as well.
Waiting for some feedback on jai and imageio in your configuration.
Simone.
On Thu, May 15, 2008 at 7:24 PM, Simone Giannecchini <simboss1@anonymised.com> wrote:
Ciao Bjorn,
Simone.
Ok thanks!
overviews 2 4 8 16
geotools 2.4.1.
    GEOGCS["RT90",
_1990",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
    0: 0,0,0,255
    1: 16,16,16,255
Next image:
    GEOGCS["RT90",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
    0: 255,255,255,255
    1: 255,255,255,255
wrote:
Ciao Bjorn,
Ciao,
Simone.
> image
> works
> used
> necessarily
> GeoTiffs.
> windows,
> /Björn
> Integer.MAX_VALUE!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
