I have 2 shapes for the point and name of factory location files. I can view
both of them on ArcView. When I import them to oracle 10g using shp2sdo
tool, I am able to migrate and create feature both of them. However, the
error did happened when I click the Generate button.
Display error below
* The FeatureType 'K50_FACTORY_LOCATION' has a NULL extent.
HINT: the dataset is empty or has no default geometry attribute.
After getting the errors, I try to click generate button serveral times.
Then, the error has gone. So, I went to see the preview feature in the map
preview. I cannot see the feature in the map preview everytime which it
should not happen like this. Anyway, my big problem I cannot see both layers
in the mapbuilder. It made my computer take a long time to calculate layers
with lots of exceptions.
If anyone want to see my shape file, please let me know.
worr
View this message in context: http://www.nabble.com/Problem-with-2-shape-file-t1749584.html#a4756371
Sent from the GeoServer - User forum at Nabble.com.
Did you make a spatial index for them? Not having a spatial index can lead to some problems. Or does shp2sdo do that automatically?
Chris
Display error below
worr
Geoserver-users mailing list
!DSPAM:1003,44870f12271721425493344!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
I created spatial index manually.
This is my sql
create index factory_spatial_index on K50_FACTORY_LOCATION (GEOM) indextype
is mdsys.spatial_index;
View this message in context: http://www.nabble.com/Problem-with-2-shape-file-t1749584.html#a4766345
Now. I can solved this problem when I click generate button It not show
error.
Problem is each layer can display in mapbuilder.But I got error when I show
both feature in same page by cannot display all feature or not show any
thing.One layer is boundary and another one is point.
Any suggestion?
View this message in context: http://www.nabble.com/Problem-with-2-shape-file-t1749584.html#a4949466
