[Geoserver-users] Problem with filter in getFeature request (geoserver 1.6.0)
Hello,
When executing the following request i get a service exception
request:
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.0.0&typeName=Ind_Atlasbladen&outputFormat=json&filter=(WIJKCODE1</Filter
exception:
<?xml version="1.0" ?>
**org.xml.sax.SAXParseException: Content is not allowed in prolog. Content is not allowed in prolog.**
I tried to put a xml header in the filter definition (something like <?xml version='1.0' encoding='UTF-8'?>) but that doesnt help.
In geoserver 1.5.4 this worked well
Anybody knows a solution to this xml parsing problem?
Thanks in advance
Greetings Kris
any
De disclaimer van toepassing op e-mail van de gemeente Den Haag vindt u op:
http://www.denhaag.nl/disclaimer
Hi Kris,
I think if you remove the parentheses around the xml it will work. However this seems to be a bug. The parentheses should be stripped off as delimiters and that does not appear to happen in this case. Creating a jira for it:
http://jira.codehaus.org/browse/GEOS-1745
-Justin
K Geusebroek wrote:
Hello,
request:
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.0.0&typeName=Ind_Atlasbladen&outputFormat=json&filter=(<Filter><PropertyIsEqualTo><PropertyName>WIJKCODE</PropertyName><Literal>1</Literal></PropertyIsEqualTo></Filter <http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.0.0&typeName=Ind_Atlasbladen&outputFormat=json&filter=(&lt;Filter&gt;&lt;PropertyIsEqualTo&gt;&lt;PropertyName&gt;WIJKCODE&lt;/PropertyName&gt;&lt;Literal&gt;1&lt;/Literal&gt;&lt;/PropertyIsEqualTo&gt;&lt;/Filter&gt;&gt;\)
exception:
* * <?xml version="1.0" ?>
     <ServiceExceptionReport version="*1.2.0*" xmlns=*http://www.opengis.net/ogc*
                                          xmlns:xsi=*http://www.w3.org/2001/XMLSchema-instance*
                                          xsi:schemaLocation="*http://www.opengis.net/ogc *
* http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd*&quot;&gt;
* * <ServiceException locator="*org.vfny.geoserver.util.requests.readers.XmlRequestReader*">
* org.xml.sax.SAXParseException: Content is not allowed in prolog. Content is not allowed in prolog.*
* *</ServiceException>
* * </ServiceExceptionReport>
Thanks in advance
Greetings Kris
any
!DSPAM:4007,47b2edba8222092453641!
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
