what do you think about ? .. or have you other tips ?
I just give it a try with last GeoServer trunk and is working:
I have two possible differences from your setup, I'm using Oracle JDK 8
and I have spatialite Ubuntu packages installed (this should not make
any difference):
ii libspatialite-dev:amd64 4.3.0a-5 amd64 Geospatial
extension for SQLite - development files
ii libspatialite7:amd64 4.3.0a-5 amd64
Geospatial extension for SQLite - libraries
ii python-pyspatialite 3.0.1-10 amd64 Python
interface to Spatialite
ii spatialite-bin 4.3.0-2 amd64
Geospatial extension for SQLite - tools
ii spatialite-gui 2.0.0~devel2-2 amd64
user-friendly graphical user interface for SpatiaLite
If you are curious the code that checks if the JDBC driver and natives
libraries are available:
https://github.com/nmco/geotools/blob/7d4dcbfba9b67ab6aae0b5b65f5366
334249147b/modules/library/jdbc/src/main/java/org/geotools/jdbc/
JDBCDataStoreFactory.java#L402-L410
https://github.com/nmco/geotools/blob/bd04ccd3f3b7f633f596f3ff93464a
8d4a13853c/modules/plugin/jdbc/jdbc-spatialite/src/main/
java/org/geotools/data/spatialite/SpatiaLiteDataStoreFactory.java#L74-L80
Hope this helps.
On 07/12/2017 02:40 PM, nino formica wrote:
Yes, I already did . but It does'nt change anything!
I guess that the indications:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
java -Djava.library.path=/usr/local/lib
are incorrect or ambiguous !
Nino
Il 12 lug 2017 9:47 AM, "Nuno Oliveira" <nuno.oliveira@anonymised.com>
ha scritto:
I remember vaguely that you may need to define this variable too on Linux:
On 07/10/2017 07:27 PM, nformica wrote:
geowolf wrote
Brad is giving you good questions, please share the logs, from the
description it seems that GeoServer is not finding the native library
it's looking for.
This is my system configuration:
- Ubuntu 16.04
- Tomcat 8
- Java 8 openjdk
- Geoserver 2.10.3
I have downloaded native library from:
http://docs.geotools.org/latest/userguide/library/jdbc/spati
alite.html#native-libraries
precisely the linux 64 bit version:
http://ares.boundlessgeo.com/geotools/spatialite-libs-linux-x86_64.zip
Then I have extracted lib (in zip file) in a folder named
"spatialite-libs"
and I put it in /usr/local/lib/ folder.
I restart Tomcat 8 and run Geoserver; this is the log file:
https://drive.google.com/open?id=0B5Doub2YiDSednFrUGVoVm9Cc1E
... thanks!
Nino
View this message in context: http://osgeo-org.1560.x6.nabbl
e.com/Problem-with-GeoServer-2-8-SpatiaLite-extension-tp5253
443p5327285.html
Check out the vibrant tech community on one of the world's most
Geoserver-users mailing list
Please make sure you read the following two resources before posting to
this list:
- Earning your support instead of buying it, but Ian Turton:
http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines:
http://geoserver.org/comm/userlist-guidelines.html
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be confidential
or proprietary in nature or covered by the provisions of privacy act
this list:
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
@nmcoliveira
Software Engineer
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
http://www.geo-solutions.ithttp://twitter.com/geosolutions_it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
