[Geoserver-users] Problem with Geoserver, PostGIS data, 900913 projection?
I have installed GeoServer 1.6.4 and have LINESTRING data in a a
Postgres/PostGIS database.
I added the database to GeoServer and confirmed that the data is active and
the map is available. On the OpenLayers map test page, it works beautifully
with the generated code below. (Making requests with the BBOX in lat/long
format.)
            tiled = new OpenLayers.Layer.WMS(
                "lake:segments_geom - Tiled",
"http://localhost:8080/geoserver/wms",
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    layers: 'lake:segments_geom',
                    format: 'image/png',
                    tiled: 'true',
                    tilesOrigin : "42.14712219238278,-88.12725982666012"
                {buffer: 0}
            // setup single tiled layer
            untiled = new OpenLayers.Layer.WMS(
                "lake:segments_geom - Untiled",
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    format: 'image/png'
                {singleTile: true, ratio: 1}
For the OpenLayers demo, the topp:states tiles work in the default code. But
trying to add my Layer above to the demo has been a total failure. All I
ever get returned from the wms is blank tiles. Trying to work without
OpenLayers (using the various JS scripts out there to do a custom map
overlay on Google Maps) has also been a total failure--again, only blank
tiles are received.
I am very new to this, and concerned that perhaps I have somehow
misconfigured my datasource so that it does not work with the 900913
projection? I am looking for any suggestions here, I have been pounding my
head against a brick wall with this.
DHall
View this message in context: http://www.nabble.com/Problem-with-Geoserver%2C-PostGIS-data%2C-900913-projection--tp18642192p18642192.html
I had a similar problem. I had to ensure that the geometry_columns entry for the table had the correct SRID as well as the geometries stored in the table. Hope this helps. David
format.)
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    tiled: 'true',
                {buffer: 0} );
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    format: 'image/png'
                {singleTile: true, ratio: 1} );
tiles are received.
DHall
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
This e-mail communication (including any attachments) may contain confidential and/or privileged material intended solely for the individual or entity to which it is addressed. If you are not the intended recipient, you should immediately stop reading this message and delete it from all computers that it resides on. Any unauthorized reading, distribution, copying or other use of this communication (or its attachments) is strictly prohibited. If you have received this communication in error, please notify us immediately.
I had hoped it would be so easy a solution, but the SRID for my table is set
to 4326 in geometry_columns.
DHall
and
beautifully
lat/long
format.)
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    tiled: 'true',
                {buffer: 0}
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    format: 'image/png'
But
tiles are received.
my
DHall
David R Robison
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Problem-with-Geoserver%2C-PostGIS-data%2C-900913-projection--tp18642192p18653498.html
I also had to make sure that when I inserted the records into the table that the geometry has the SRID explicitly set to 4326. By default it was going in as (-1). David
DHall wrote:
David R Robison
e-mail: [drrobison@anonymised.com](mailto:drrobison@anonymised.com)
web: [http://openroadsconsulting.com](http://openroadsconsulting.com)
blog: [http://therobe.blogspot.com](http://therobe.blogspot.com)
book: [http://www.xulonpress.com/book_detail.php?id=2579](http://www.xulonpress.com/book_detail.php?id=2579)
Try http://localhost:8080/geoserver/wms/reflect?layers=lake:segments_geom&srs=EPSG:900913 ?
and also check the geoserver logs, in the <data directory>/logs ?
-Arne
DHall
and
beautifully
lat/long
format.)
"http://localhost:8080/geoserver/wms&quot;,
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    tiled: 'true',
                {buffer: 0} );
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    format: 'image/png'
But
tiles are received.
my
DHall
David R Robison
challenge
prizes
world
That URL did return something for me--it shows me my line segments returned
in a 17px by 549px image, so stretched out vertically.
In the request.log, I see the various GET requests, no errors.
DHall
Arne Kepp-2 wrote:
Try
-Arne
set
DHall
and
beautifully
lat/long
format.)
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    tiled: 'true',
                    tilesOrigin :
                {buffer: 0}
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    format: 'image/png'
code.
But
I
blank
tiles are received.
pounding
my
DHall
David R Robison
individual
it
challenge
prizes
world
challenge
prizes
world
View this message in context: http://www.nabble.com/Problem-with-Geoserver%2C-PostGIS-data%2C-900913-projection--tp18642192p18653781.html
So then your layer is probably reprojecting correctly (EPSG:900913 does stretch things quite a bit).
Your problem appears to be the way you configure your JavaScript client. You can append &format=application/openlayers to the URL below to get a sample client in EPSG:900913. If you look at the requests it sends to the backend (use something like firebug) and compare that to what the client you have made does, you may be able to figure it out.
Note that OpenLayers default to 4326, so you should define the projection on the Map object and similarly for all layers you add to this map.
-Arne
DHall
-Arne
set
DHall
and
beautifully
lat/long
format.)
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    tiled: 'true',
                    tilesOrigin :
                {buffer: 0} );
                    srs: 'EPSG:4326',
                    width: '529',
                    styles: '',
                    height: '550',
                    format: 'image/png'
code.
But
I
blank
tiles are received.
pounding
my
DHall
David R Robison
individual
it
challenge
prizes
world
challenge
prizes
world
