[Geoserver-users] Problem with geoserver1.6RC1+ArcSDE9.0
hi all,
I'm using Geoserver 1.6RC1 , ArcSDE9.0,JRE 1.5 (Sun), Tomcat 5.5. On the
client side, I have an
OpenLayers client.
When I create a FeatureType,I see this below:
22 十一月 11:45:19 ERROR [[/geoserverRC].[action]] - Servlet.service() for
servlet action threw exception
java.lang.NoSuchFieldError: NONE
  at
org.geotools.data.arcsde.ArcSDEAdapter.createAttributeTypes(ArcSDEAdapter.java:418)
  at
org.geotools.data.arcsde.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:287)
  at
org.geotools.data.arcsde.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:202)
  at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:84)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
  at
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
  at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
  at
org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
  at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
  at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
  at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
  at java.lang.Thread.run(Unknown Source)
Thanks in advance of any suggestion.
--minimeteor
View this message in context: http://www.nabble.com/Problem-with-geoserver1.6RC1%2BArcSDE9.0-tf4854289.html#a13890692
Apologies for the double post everyone, but this is the message from
Saul from a few days back to me. This setup works for me. Are you
sure you are using the latest ArcSDE plugin? See below...
Jason,
I'd suggest that you try the 1.6.x series of geoserver for it's
much-improved ArcSDE support.
Here's how to do that:
1) Download the latest geoserver beta (or nightly build, if you like).
2) Deploy it without adding anything ArcSDE related. Check that it's
working (say, with a shapefile). WFS should be good, and so should WMS.
3) Grab this file
http://lists.refractions.net/m2/org/geotools/gt2-arcsde/2.4-SNAPSHOT/gt2-arcsde-2.4-SNAPSHOT.jar
and put it into your geoserver/WEB-INF/lib directory
4) Put your two jsde_api91.jar and jsde_jpe91.jar files into the
geoserver/WEB-INF/lib directory as well.
5) Restart the whole she-bang and it should work much better.
Good luck!
--saul
- Show quoted text -
On Tue, 2007-11-13 at 17:46 +0100, Jason Pickering wrote:
Hi Everyone,
I am trying to get a ArcSDE datastore up and running and seem to be
running into some problems. I am not sure if it has anything to do
with the names of the feature classes, so I thought I would check here
first. I am able to create a new feature class in geoserver, and i am
able to get to it through a WFS connection but a lot of errors are
produced in the log. It does seem to work though. However, I cannot
get anything out of the WMS connection through even the most simple of
SLDs. I thought it might have to do with the styled layer descriptor,
but even the simple "polygon" does not work. The name of the layer is
OMS.OMS.WHO_REG, and I thought that the periods might cause a
problem.
I am using the latest 1.5.4 version with an ArcSDE 9.1 /MS-SQL setup.
I am using the 9.1 jars and the 1.5.4 version extension for geoserver.
Here is a typical snippet from the log when I make a WMS request to output KML.
Thanks for any tips.
Best regards,
Jason
Nov 13, 2007 5:34:00 PM org.vfny.geoserver.servlets.AbstractService doService
INFO: Service handled
Nov 13, 2007 5:34:20 PM
org.vfny.geoserver.wms.requests.GetMapKvpReader
parseOptionalParameters
INFO: Set KMScore: 50
Nov 13, 2007 5:34:20 PM org.vfny.geoserver.servlets.AbstractService doService
INFO: handling request:
GetMap Request
version: 1.1.1
output format: application/vnd.google-earth.kmz XML
width height: 1024,1024
bbox: Env[-50.81813868472601 : 93.77489215952886, -29.96974386011042
: 54.43714880180336]
layers: WHO:OMS.OMS.WHO_REG
styles: OMS.OMS.WHO_REG_style
Nov 13, 2007 5:34:29 PM org.geotools.data.arcsde.ArcSDEQuery getQueryColumns
INFO: No FID attribute was contained in your query. Appending the
discovered one to the list of columns to be fetched.
Nov 13, 2007 5:34:29 PM org.geotools.renderer.lite.StreamingRenderer
processStylers
SEVERE: Wrong number of attributes expected 2 got 3
IllegalAttribute: null , but got null
        at org.geotools.feature.DefaultFeature.setAttributes(DefaultFeature.java:263)
        at org.geotools.feature.DefaultFeature.<init>(DefaultFeature.java:97)
        at org.geotools.feature.DefaultFeatureType.create(DefaultFeatureType.java:171)
        at org.geotools.data.crs.ForceCoordinateSystemFeatureReader.next(ForceCoordinateSystemFeatureReader.java:144)
        at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1564)
        at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:715)
        at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:436)
        at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:238)
        at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:164)
        at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:495)
        at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:592)
        at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
        at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
        at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
        at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
        at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
        at java.lang.Thread.run(Thread.java:619)
Nov 13, 2007 5:34:30 PM org.geotools.renderer.lite.StreamingRenderer
processStylers
processStylers
Geoserver-users mailing list
On Nov 22, 2007 5:00 AM, minimeteor <fbli@...1429...> wrote:
hi all,
OpenLayers client.
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
--minimeteor
Defy all challenges. Microsoft(R) Visual Studio 2005.
