[Geoserver-users] Problem with GetCapabilites request
Hi All,
I’m running GeoServer 1.7.2 on MS Windows Server 2003 R2 Standard Edition using the standard Windows installer (i.e. Jetty as my servlet). I’m hoping someone can point me in the direction of a fix to my problem. I’ve got a number of layers loaded into GeoServer, limited my list of available projections, etc. and at some point (I didn’t notice when) GeoServer has stopped serving back a capabilities document. Instead it gives me the following information:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Translator error
Translator error
null
I have no problem adding or deleting Coverages or FeatureTypes, or otherwise interacting through the web interface. Any ideas?
Steve
Stephen Mather, GIS Manager
Metroparks
svm@anonymised.com
Phone: (216) 635-3243
FAX: (216) 635-3286
Stephen V. Mather ha scritto:
Hi All,
    I'm running GeoServer 1.7.2 on MS Windows Server 2003 R2 Standard Edition using the standard Windows installer (i.e. Jetty as my servlet). I'm hoping someone can point me in the direction of a fix to my problem. I've got a number of layers loaded into GeoServer, limited my list of available projections, etc. and at some point (I didn't notice when) GeoServer has stopped serving back a capabilities document. Instead it gives me the following information:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt; <ServiceExceptionReport version="1.1.1" > <ServiceException>
      Translator error
Translator error
null
</ServiceException></ServiceExceptionReport>
There is an error occurring early in the capabilities
documente generation. Enable "verbose exceptions" under
config/server, apply, generate the caps document
again, report the full result to this list
Andrea Aime
OpenGeo - http://opengeo.org
Below is the log of the exception thrown by GeoServer:
24 Mar 10:44:26 DEBUG [geoserver.filters] - filtering
http://cmac-srv-gis:8080/geoserver/ows
24 Mar 10:44:26 DEBUG [responses.helpers] - producing a capabilities
document for GetCapabilities [service: WMS, version: 1.1.1]
24 Mar 10:44:26 DEBUG [responses.helpers] - Collecting summarized latlonbbox
and common SRS...
24 Mar 10:44:26 DEBUG [responses.helpers] - Summarized LatLonBBox is
Env[-84.9220090931308 : -62.4217683165105, 38.36722121151361 :
44.292230522337206]
24 Mar 10:44:26 DEBUG [responses.helpers] - Adding GetLegendGraphic call as
LegendURL
LegendURL
LegendURL
24 Mar 10:44:26 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Translator error
        at
org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSCapabili
tiesResponse.java:143)
        at
org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:
48)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:698)
        at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
        at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abstrac
tController.java:153)
        at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(Si
mpleControllerHandlerAdapter.java:48)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServl
et.java:875)
        at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServle
t.java:809)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkSer
vlet.java:571)
        at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java
:501)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler
.java:1093)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterE
ncodingFilter.java:108)
        at
.java:1084)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterCh
ainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecur
ityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSec
urityInterceptor.java:72)
        at
ainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslatio
nFilter.java:110)
        at
ainProxy.java:274)
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(Ano
nymousProcessingFilter.java:125)
        at
ainProxy.java:274)
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessin
gFilter.java:178)
        at
ainProxy.java:274)
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpS
essionContextIntegrationFilter.java:229)
        at
ainProxy.java:274)
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at
.java:1084)
        at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at
.java:1084)
        at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:16
3)
        at
.java:1084)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
        at
.java:1084)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
        at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerColl
ection.java:206)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:11
4)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
        at org.mortbay.jetty.Server.handle(Server.java:324)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnectio
n.java:828)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:4
50)
Caused by: javax.xml.transform.TransformerException: Translator error
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:13
3)
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:10
8)
        at
tiesResponse.java:141)
        ... 52 more
Caused by: java.lang.NullPointerException
        at
org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTran
slator.handleFeatureType(WMSCapsTransformer.java:730)
        at
slator.handleFeaturesTree(WMSCapsTransformer.java:648)
        at
slator.handleLayers(WMSCapsTransformer.java:514)
        at
slator.handleCapability(WMSCapsTransformer.java:331)
        at
slator.encode(WMSCapsTransformer.java:215)
        at
org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(Transforme
rBase.java:714)
        at
org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerId
entityImpl.java:484)
        at
org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:12
9)
        ... 54 more
Cleveland Metroparks
4101 Fulton Pkwy
Cleveland, OH 44144
svm@anonymised.com
FAX: (216) 635-3286
-----Original Message-----
Sent: Tuesday, March 24, 2009 9:31 AM
To: svm@anonymised.com
Subject: Re: [Geoserver-users] Problem with GetCapabilites request
Hi All,
      Translator error
Translator error
null
documente generation. Enable "verbose exceptions" under config/server,
apply, generate the caps document again, report the full result to this list
Andrea Aime
hi Stephen,
The error indicates that there is a problem with the style for that layer, no default style has been set, or the one that has been set does not exist, etc...
Andrea: when was the fix that throw better exceptions when styles were not set up added? Was that post 1.7.2?
-Justin
and common SRS...
44.292230522337206]
LegendURL
LegendURL
LegendURL
        at
        at
48)
        at
        at
        at
        at
et.java:875)
        at
t.java:809)
        at
vlet.java:571)
        at
:501)
        at
        at
.java:1093)
        at
        at
.java:1084)
        at
ainProxy.java:264)
        at
        at
        at
ainProxy.java:274)
        at
nFilter.java:110)
        at
ainProxy.java:274)
        at
        at
ainProxy.java:274)
        at
gFilter.java:178)
        at
ainProxy.java:274)
        at
        at
ainProxy.java:274)
        at
        at
        at
.java:1084)
        at
        at
.java:1084)
        at
3)
        at
.java:1084)
        at
.java:1084)
        at
        at
        at
        at
        at
        at
ection.java:206)
        at
4)
        at
        at
        at
n.java:828)
        at
        at
50)
        at
3)
        at
8)
        at
        ... 52 more
        at
        at
        at
        at
        at
        at
rBase.java:714)
        at
        at
        at
9)
        ... 54 more
4101 Fulton Pkwy
Cleveland, OH 44144
svm@anonymised.com
FAX: (216) 635-3286
From: Andrea Aime [mailto:aaime@anonymised.com] Sent: Tuesday, March 24, 2009 9:31 AM
Hi All,
      Translator error
Translator error
null
Justin Deoliveira
