[Geoserver-users] Problem with image mosaic and WGS84
Hello,
i have a problem with my image mosaic in WGS84 and hope you can help me.
I have several jpeg images with worldfiles. Using the Coveragetools from
geotools i created a shapefile for these images and created a new coverage
store in geoserver. This works fine.
But the output of geoserver looks very wrong. I attached a jpeg of the
result: http://www.nabble.com/file/p16930966/geoserver_output.jpg
The blue outlines are from the shapefile.
As you can see the images are not in these lines as i expect them to be.
Instead the images have the wrong size and overlap each other.
What can i do to solf my problem?
Thanks in advance,
Dirk
View this message in context: http://www.nabble.com/Problem-with-image-mosaic-and-WGS84-tp16930966p16930966.html
dwilhelm ha scritto:
Hello,
I don't really know... have you tried building the index and property
file using the GDAL based approach instead?
