[Geoserver-users] Problem with image mosaic plugin anf geotiff images
HI all,
I have problem with image mosaic plugin using geotiff.
The geoserver version is 2.8.1.
The same configurartion works with tiff copied from snow time series examples.
in the page “Add Raster Data Source” I saw the following error:
“Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:workspaces/… and hints null”
I think there’s a problem involving geotiff data tags.
This is the exception encoutered
2016-04-12 12:27:37,001 ERROR [imagemosaic.Utils] -
java.lang.NullPointerException
at org.geotools.gce.imagemosaic.RasterManager$SpatialDomainManager.prepareCoverageSpatialElements(RasterManager.java:203)
at org.geotools.gce.imagemosaic.RasterManager$SpatialDomainManager.(RasterManager.java:178)
at org.geotools.gce.imagemosaic.RasterManager.initialize(RasterManager.java:1472)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.indexingPostamble(ImageMosaicConfigHandler.java:410)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:132)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196)
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:359)
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1237)
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:516)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:468)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1441)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1369)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
this is the listgeo output for the tif file
Geotiff_Information:
Version: 1
Key_Revision: 1.2
Tagged_Information:
ModelTransformationTag (4,4):
7.80859375 0 0 981591
0 -6.51432291666667 0 5538963
0 0 0 0
0 0 0 1
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeProjected
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
GeographicTypeGeoKey (Short,1): GCS_WGS_84
ProjectedCSTypeGeoKey (Short,1): User-Defined
PCSCitationGeoKey (Ascii,24): “WGS84 / Google Mercator”
ProjectionGeoKey (Short,1): User-Defined
ProjCoordTransGeoKey (Short,1): CT_Mercator
ProjLinearUnitsGeoKey (Short,1): Linear_Meter
ProjLinearUnitSizeGeoKey (Double,1): 1
ProjNatOriginLongGeoKey (Double,1): 0
ProjNatOriginLatGeoKey (Double,1): 0
ProjFalseEastingGeoKey (Double,1): 0
ProjFalseNorthingGeoKey (Double,1): 0
ProjScaleAtNatOriginGeoKey (Double,1): 1
End_Of_Keys.
End_Of_Geotiff.
Projection Method: CT_Mercator
ProjNatOriginLatGeoKey: 0.000000 ( 0d 0’ 0.00"N)
ProjNatOriginLongGeoKey: 0.000000 ( 0d 0’ 0.00"E)
ProjScaleAtNatOriginGeoKey: 1.000000
ProjFalseEastingGeoKey: 0.000000 m
ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4326/WGS 84
Ellipsoid: 7030/WGS 84 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0’ 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left ( 981591.000, 5538963.000) ( 8d49’ 4.02"E, 44d39’55.73"N)
Lower Left ( 981591.000, 5533960.000) ( 8d49’ 4.02"E, 44d38’ 0.24"N)
Upper Right ( 989587.000, 5538963.000) ( 8d53’22.60"E, 44d39’55.73"N)
Lower Right ( 989587.000, 5533960.000) ( 8d53’22.60"E, 44d38’ 0.24"N)
Center ( 985589.000, 5536461.500) ( 8d51’13.31"E, 44d38’57.99"N)
Thanks
Hi Franco,
Do you have any chance to run gdalinfo on that file and report back the output?
(I wonder if there is an issue with the CoordinateReferenceSystem, such as some missing elements defining it).
Please, let us know.
Daniele
On Tue, Apr 12, 2016 at 12:32 PM, Franco Minutiello <franco.minutiello@anonymised.com> wrote:
HI all,
Version: 1
Key_Revision: 1.2
Tagged_Information:
0 0 0 0
0 0 0 1
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
GCS: 4326/WGS 84
Datum: 6326/World Geodetic System 1984
Corner Coordinates:
Thanks
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
here is the gdalinfo output
Size is 1024, 768
Coordinate System is:
PROJCS["WGS84 / Google Mercator",
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
             SPHEROID["WGS 84",6378137,298.257223563,
                 AUTHORITY["EPSG","7030"]],
             AUTHORITY["EPSG","6326"]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433],
         AUTHORITY["EPSG","4326"]],
     PROJECTION["Mercator_1SP"],
     PARAMETER["central_meridian",0],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]]]
Origin = (981591.000000000000000,5538963.000000000000000)
Pixel Size = (7.808593750000000,-6.514322916666667)
Metadata:
   AREA_OR_POINT=Area
   TIFFTAG_RESOLUTIONUNIT=1 (unitless)
   TIFFTAG_XRESOLUTION=1
   TIFFTAG_YRESOLUTION=1
Image Structure Metadata:
   INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 981591.000, 5538963.000) ( 8d49' 4.02"E, 44d39'55.73"N)
Lower Left ( 981591.000, 5533960.000) ( 8d49' 4.02"E, 44d38' 0.24"N)
Upper Right ( 989587.000, 5538963.000) ( 8d53'22.60"E, 44d39'55.73"N)
Lower Right ( 989587.000, 5533960.000) ( 8d53'22.60"E, 44d38' 0.24"N)
Center ( 985589.000, 5536461.500) ( 8d51'13.31"E, 44d38'57.99"N)
Band 1 Block=1024x8 Type=Byte, ColorInterp=Red
   NoData Value=0
Band 2 Block=1024x8 Type=Byte, ColorInterp=Green
   NoData Value=0
Band 3 Block=1024x8 Type=Byte, ColorInterp=Blue
   NoData Value=0
Band 4 Block=1024x8 Type=Byte, ColorInterp=Alpha
   NoData Value=0
Franco
On 12/04/2016 14:11, Daniele Romagnoli wrote:
Hi Franco,
Daniele
On Tue, Apr 12, 2016 at 12:32 PM, Franco Minutiello <franco.minutiello@anonymised.com <mailto:franco.minutiello@anonymised.com>> wrote:
    HI all,
    series examples.
    in the page "Add Raster Data Source" I saw the following error:
    "Could not list layers for this store, an error occurred
    retrieving them: Failed to create reader from file:workspaces/....
    and hints null"
    I think there's a problem involving geotiff data tags.
            at
            at
    org.geotools.gce.imagemosaic.RasterManager$SpatialDomainManager.<init>(RasterManager.java:178)
            at
            at
            at
    org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.<init>(ImageMosaicDirectoryWalker.java:132)
            at
            at
            at
            at
            at
    org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:468)
            at
            at
            at
            at
            at
            at
            at
            at
       Version: 1
       Key_Revision: 1.2
       Tagged_Information:
             0 0 0 0
             0 0 0 1
          End_Of_Tags.
       Keyed_Information:
          PCSCitationGeoKey (Ascii,24): "WGS84 / Google Mercator"
          End_Of_Keys.
       End_Of_Geotiff.
       ProjNatOriginLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
       ProjNatOriginLongGeoKey: 0.000000 ( 0d 0' 0.00"E)
    GCS: 4326/WGS 84
    Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
    Corner Coordinates:
    44d39'55.73"N)
    0.24"N)
    44d39'55.73"N)
    0.24"N)
    44d38'57.99"N)
    Thanks
    multiple tiers of
    quickly and
    <mailto:Geoserver-users@lists.sourceforge.net>
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Franco Minutiello - dartsengineering srl
Tel: +39 010 0980171 Fax:+39 010 0980184
s-mail: Piazza della Vittoria, 9/3 16121 Genova (Italy)
e-mail: franco.minutiello@anonymised.com <mailto:franco.minutiello@anonymised.com>
AVVERTENZE AI SENSI DEL D.LGS 196/2003 <http://www.darts.it/DARTS-Mail-Disclaimer.html&gt;
Any news about geotiff tags? I found a possible workaround using gldal_translate using png formato plus pgw file, but it's a workaround...
geotiff files are creted by geoserver using Google mercator as coordinate system.
Thanks
  Franco
Size is 1024, 768
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
  NoData Value=0
  NoData Value=0
  NoData Value=0
  NoData Value=0
Franco
Hi Franco,
Daniele
    HI all,
    series examples.
    file:workspaces/.... and hints null"
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
    Method)
            at
            at
            at
       Version: 1
       Key_Revision: 1.2
       Tagged_Information:
             0 0 0 0
             0 0 0 1
          End_Of_Tags.
       Keyed_Information:
          End_Of_Keys.
       End_Of_Geotiff.
    GCS: 4326/WGS 84
    Corner Coordinates:
    44d39'55.73"N)
    44d38' 0.24"N)
    44d39'55.73"N)
    0.24"N)
    44d38'57.99"N)
    Thanks
    multiple tiers of
    quickly and
Hi Franco,
On Thu, Apr 14, 2016 at 4:00 PM, Franco Minutiello <franco.minutiello@anonymised.com> wrote:
Any news about geotiff tags? I found a possible workaround using gldal_translate using png formato plus pgw file, but it’s a workaround…
You may also consider adding a .prj file beside your geotiff file containing the WKT definition of your CRS. Note that the name of that prj file should match the name of your geotiff beside the different extension.
It seems you are using an EPSG:3857 right? (You can paste the WKT from here: http://epsg.io/3857)
Could you clarify this statement? Are you saying that the GeoTiff you are trying to configure has been previously created by a GeoServer request asking for GeoTIFF output format?
Daniele
Thanks
Franco
Size is 1024, 768
PROJCS[“WGS84 / Google Mercator”,
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Mercator_1SP”],
PARAMETER[“central_meridian”,0],
PARAMETER[“scale_factor”,1],
PARAMETER[“false_easting”,0],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]]]
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
NoData Value=0
NoData Value=0
NoData Value=0
NoData Value=0
Franco
Hi Franco,
Daniele
Franco Minutiello - darts engineering srl
[https://ad.doubleclick.net/ddm/clk/302982198;130105516;z](https://ad.doubleclick.net/ddm/clk/302982198;130105516;z)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
HI all,
Version: 1
Key_Revision: 1.2
Tagged_Information:
0 0 0 0
0 0 0 1
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
Thanks
Is there any tool ti create prj file> Yes thats’s true. Here is an example of the getMap parameters Request: getMap Format = image/geotiff Crs = PROJCS[“WGS84 / Google Mercator”, GEOGCS[“WGS 84”, DATUM[“World Geodetic System 1984”, SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]], AUTHORITY[“EPSG”,“6326”]], PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]], UNIT[“degree”, 0.017453292519943295], AXIS[“Longitude”, EAST], AXIS[“Latitude”, NORTH], AUTHORITY[“EPSG”,“4326”]], PROJECTION[“Mercator_1SP”], PARAMETER[“semi_minor”, 6378137.0], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“900913”]] Bbox = SRSEnvelope[981591.0 : 989587.0, 5533960.0 : 5538963.0] RemoteOwsType = null RemoteOwsURL = null Env = {} FormatOptions = {} Angle = 0.0 CQLFilter = null Elevation = FeatureId = null StartIndex = null ViewParams = null Width = 1024 Height = 768 Palette = null BgColor = java.awt.Color[r=255,g=255,b=255] Tiled = false FeatureVersion = null SRS = EPSG:900913 Styles = [StyleImpl[ name=srs_rainfall]] MaxFeatures = null Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com] Transparent = true StyleFormat = sld Interpolations = SldBody = null ValidateSchema = false Sld = null StyleUrl = null TilesOrigin = null Exceptions = SE_XML StyleBody = null SldVersion = null StyleVersion = null ScaleMethod = null Buffer = 0 Time = Filter = null Filters = null RawKvp = {TRANSPARENT=TRUE, BBOX=981591,5533960,989587,5538963, VERSION=1.1.1, FORMAT=image/geotiff, SERVICE=WMS, HEIGHT=768, REQUEST=GetMap, LAYERS=srs:srs_layer, STYLES=, SRS=EPSG:900913, WIDTH=1024} Get = true BaseUrl = RequestCharset = UTF-8 Version = 1.1.1 Request = GetMap
On 14/04/2016 16:14, Daniele Romagnoli wrote:
Hi Franco,
It seems you are using an EPSG:3857 right? (You can paste the WKT from here: http://epsg.io/3857) yes. the request is made with reference system EPSG:900913, that is an alternatice code of EPSG:3857
http://vsrs-01:8080/geoserver/
Daniele
Thanks
Franco
Size is 1024, 768
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
NoData Value=0
NoData Value=0
NoData Value=0
NoData Value=0
Franco
Hi Franco,
Daniele
On Tue, Apr 12, 2016 at 12:32 PM, Franco Minutiello <franco.minutiello@anonymised.com…> wrote:
HI all,
Version: 1
Key_Revision: 1.2
Tagged_Information:
0 0 0 0
0 0 0 1
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
Thanks
Geoserver-users@anonymised.comrceforge.net
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.come.net)
Hi Franco,
at the end, the prj file is nothing more than a txt file with .prj extension.
Therefore you can create it simply using any text editor you have (as an instance, notepad on windows or vi, nano, gedit, … on linux) and paste the WKT content on it.
The prj you need may looks like the attached file.
Supposing your geotiff file is called “mygeotiff.tif” just make sure to rename “sample.prj” to “mygeotiff.prj” and put it beside “mygeotiff.tif”.
Hope this helps.
Daniele
sample.prj (615 Bytes)
On Thu, Apr 14, 2016 at 5:16 PM, Franco Minutiello <franco.minutiello@anonymised.com32…> wrote:
Hi Franco,
Request: getMap
GEOGCS[“WGS 84”,
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH],
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Width = 1024
Height = 768
Palette = null
Tiled = false
SRS = EPSG:900913
MaxFeatures = null
Transparent = true
StyleFormat = sld
Interpolations =
SldBody = null
Sld = null
StyleUrl = null
TilesOrigin = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
ScaleMethod = null
Buffer = 0
Time =
Filter = null
Filters = null
Get = true
BaseUrl = http://vsrs-01:8080/geoserver/
Version = 1.1.1
Request = GetMap
Daniele
Thanks
Franco
Size is 1024, 768
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
NoData Value=0
NoData Value=0
NoData Value=0
NoData Value=0
Franco
Hi Franco,
Daniele
HI all,
Version: 1
Key_Revision: 1.2
Tagged_Information:
0 0 0 0
0 0 0 1
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
Thanks
Hi Daniele,
it Works! I have performance problem.
Geoserver needs more than 10 seconds to create animated gif with only 4 geotiff. is it right?
Franco
On 14/04/2016 17:39, Daniele Romagnoli wrote:
Hi Franco,
Therefore you can create it simply using any text editor you have (as an instance, notepad on windows or vi, nano, gedit, ... on linux) and paste the WKT content on it.
Supposing your geotiff file is called "mygeotiff.tif" just make sure to rename "sample.prj" to "mygeotiff.prj" and put it beside "mygeotiff.tif".
Hope this helps.
Daniele
On Thu, Apr 14, 2016 at 5:16 PM, Franco Minutiello <franco.minutiello@anonymised.com <mailto:franco.minutiello@anonymised.com>> wrote:
    Hi Franco,
    EPSG:3857
    Yes thats's true. Here is an example of the getMap parameters
    Request: getMap
            Crs = PROJCS["WGS84 / Google Mercator",
      GEOGCS["WGS 84",
        DATUM["World Geodetic System 1984",
          SPHEROID["WGS 84", 6378137.0, 298.257223563,
        PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
        UNIT["degree", 0.017453292519943295],
        AXIS["Longitude", EAST],
        AXIS["Latitude", NORTH],
      PARAMETER["semi_minor", 6378137.0],
      PARAMETER["latitude_of_origin", 0.0],
      PARAMETER["central_meridian", 0.0],
      PARAMETER["scale_factor", 1.0],
      PARAMETER["false_easting", 0.0],
      PARAMETER["false_northing", 0.0],
      UNIT["m", 1.0],
      AXIS["x", EAST],
      AXIS["y", NORTH],
      AUTHORITY["EPSG","900913"]]
            RemoteOwsURL = null
            Env = {}
            FormatOptions = {}
            Angle = 0.0
            CQLFilter = null
            Elevation =
            FeatureId = null
            StartIndex = null
            ViewParams = null
            Width = 1024
            Height = 768
            Palette = null
            Tiled = false
            SRS = EPSG:900913
            MaxFeatures = null
            Transparent = true
            StyleFormat = sld
            Interpolations =
            SldBody = null
            Sld = null
            StyleUrl = null
            TilesOrigin = null
            Exceptions = SE_XML
            StyleBody = null
            SldVersion = null
            StyleVersion = null
            ScaleMethod = null
            Buffer = 0
            Time =
            Filter = null
            Filters = null
            Get = true
            Version = 1.1.1
            Request = GetMap
    Daniele
        Thanks
         Franco
        Size is 1024, 768
            GEOGCS["WGS 84",
                DATUM["WGS_1984",
            UNIT["metre",1,
        Metadata:
          AREA_OR_POINT=Area
          INTERLEAVE=PIXEL
        Corner Coordinates:
        44d39'55.73"N)
        44d38' 0.24"N)
        44d39'55.73"N)
        44d38' 0.24"N)
        44d38'57.99"N)
          NoData Value=0
          NoData Value=0
          NoData Value=0
          NoData Value=0
        Franco
        Hi Franco,
        defining it).
        Daniele
            HI all,
            following error:
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
               Version: 1
               Key_Revision: 1.2
               Tagged_Information:
            0 0 0 0
            0 0 0 1
                  End_Of_Tags.
               Keyed_Information:
            Mercator"
                  End_Of_Keys.
               End_Of_Geotiff.
            GCS: 4326/WGS 84
            Corner Coordinates:
            Thanks
        phone: +39 0584 962313 <tel:%2B39%200584%20962313>
        fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
        Le informazioni contenute in questo messaggio di posta
        elettronica e/o nel/i file/s allegato/i sono da
        considerarsi strettamente riservate. Il loro utilizzo è
        consentito esclusivamente al destinatario del messaggio,
        per le finalità indicate nel messaggio stesso. Qualora
        riceviate questo messaggio senza esserne il destinatario,
        Vi preghiamo cortesemente di darcene notizia via e-mail e
        di procedere alla distruzione del messaggio stesso,
        cancellandolo dal Vostro sistema. Conservare il messaggio
        stesso, divulgarlo anche in parte, distribuirlo ad altri
        soggetti, copiarlo, od utilizzarlo per finalità diverse,
        costituisce comportamento contrario ai principi dettati dal
        D.Lgs. 196/2003.
        -- Franco Minutiello - dartsengineering srl
        Tel: +39 010 0980171 <tel:%2B39%20010%200980171> Fax:+39 010
        0980184 <tel:%2B39%20010%200980184>
    elettronica e/o nel/i file/s allegato/i sono da considerarsi
    strettamente riservate. Il loro utilizzo è consentito
    esclusivamente al destinatario del messaggio, per le finalità
    indicate nel messaggio stesso. Qualora riceviate questo messaggio
    senza esserne il destinatario, Vi preghiamo cortesemente di
    darcene notizia via e-mail e di procedere alla distruzione del
    messaggio stesso, cancellandolo dal Vostro sistema. Conservare il
    messaggio stesso, divulgarlo anche in parte, distribuirlo ad
    altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
    D.Lgs. 196/2003.
Dear Franco,
you might want to start with something like this:
https://www.google.it/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=geoserver%20performance%20tuning
:slight_smile:
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
On Thu, Apr 21, 2016 at 2:48 PM, Franco Minutiello
Hi Daniele,
Franco
Hi Franco,
extension.
WKT content on it.
Hope this helps.
Daniele
Hi Franco,
system.
Request: getMap
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
        RemoteOwsURL = null
        Env = {}
        FormatOptions = {}
        Angle = 0.0
        CQLFilter = null
        Elevation =
        FeatureId = null
        StartIndex = null
        ViewParams = null
        Width = 1024
        Height = 768
        Palette = null
        Tiled = false
        SRS = EPSG:900913
        MaxFeatures = null
        Transparent = true
        StyleFormat = sld
        Interpolations =
        SldBody = null
        Sld = null
        StyleUrl = null
        TilesOrigin = null
        Exceptions = SE_XML
        StyleBody = null
        SldVersion = null
        StyleVersion = null
        ScaleMethod = null
        Buffer = 0
        Time =
        Filter = null
        Filters = null
        Get = true
        Version = 1.1.1
        Request = GetMap
Daniele
Thanks
Franco
Size is 1024, 768
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
  NoData Value=0
  NoData Value=0
  NoData Value=0
  NoData Value=0
Franco
Hi Franco,
output?
Daniele
HI all,
examples.
"Could not list layers for this store, an error occurred retrieving
them: Failed to create reader from file:workspaces/.... and hints null"
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
   Version: 1
   Key_Revision: 1.2
   Tagged_Information:
         0 0 0 0
         0 0 0 1
      End_Of_Tags.
   Keyed_Information:
      End_Of_Keys.
   End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
44d39'55.73"N)
0.24"N)
44d39'55.73"N)
0.24"N)
44d38'57.99"N)
Thanks
Manager
tiers of
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
Manager
tiers of
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
of
Hi Simone,
  the optimization suggested are already done. Both container and geoserver optimization. T
The memory limit is set to 384M.
Here the tomcat7 parameters
/usr/lib/jvm/default-java/bin/java -Djava.util.logging.config.file=/var/lib/tomcat7/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.awt.headless=true -server -Xmx384M -Xms64m -XX:SoftRefLRUPolicyMSPerMB=36000 -XX:MaxPermSize=128m -XX:+UseParallelGC -Dorg.geotools.shapefile.datetime=true -Djava.endorsed.dirs=/usr/share/tomcat7/endorsed -classpath /usr/share/tomcat7/bin/bootstrap.jar:/usr/share/tomcat7/bin/tomcat-juli.jar -Dcatalina.base=/var/lib/tomcat7 -Dcatalina.home=/usr/share/tomcat7 -Djava.io.tmpdir=/tmp/tomcat7-tomcat7-tmp org.apache.catalina.startup.Bootstrap start
the web.xml for gestover is configured with serviceStategy SPEED
The geotiff size are 1024x768 pixel whith the following geotag
Size is 1024, 768
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=PIXEL
Corner Coordinates:
   NoData Value=0
   NoData Value=0
   NoData Value=0
   NoData Value=0
file size is 3147073 bytes.
thanks for your help
Ciao
Franco
On 21/04/2016 14:57, Simone Giannecchini wrote:
Dear Franco,
:slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Daniele,
Franco
Hi Franco,
extension.
WKT content on it.
Hope this helps.
Daniele
Hi Franco,
system.
Request: getMap
   GEOGCS["WGS 84",
   UNIT["m", 1.0],
   AXIS["x", EAST],
   AXIS["y", NORTH],
         RemoteOwsURL = null
         Env = {}
         FormatOptions = {}
         Angle = 0.0
         CQLFilter = null
         Elevation =
         FeatureId = null
         StartIndex = null
         ViewParams = null
         Width = 1024
         Height = 768
         Palette = null
         Tiled = false
         SRS = EPSG:900913
         MaxFeatures = null
         Transparent = true
         StyleFormat = sld
         Interpolations =
         SldBody = null
         Sld = null
         StyleUrl = null
         TilesOrigin = null
         Exceptions = SE_XML
         StyleBody = null
         SldVersion = null
         StyleVersion = null
         ScaleMethod = null
         Buffer = 0
         Time =
         Filter = null
         Filters = null
         Get = true
         Version = 1.1.1
         Request = GetMap
Daniele
Thanks
  Franco
Size is 1024, 768
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=PIXEL
Corner Coordinates:
   NoData Value=0
   NoData Value=0
   NoData Value=0
   NoData Value=0
Franco
Hi Franco,
output?
Daniele
HI all,
examples.
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
    Version: 1
    Key_Revision: 1.2
    Tagged_Information:
          0 0 0 0
          0 0 0 1
       End_Of_Tags.
    Keyed_Information:
       End_Of_Keys.
    End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
44d39'55.73"N)
0.24"N)
44d39'55.73"N)
0.24"N)
44d38'57.99"N)
Thanks
Manager
tiers of
Manager
tiers of
of
Dear Franco,
are you sure?
With 384M of heap I don't really think you optimized anything.
Overview and tiling on the geotiff data might help as well.
I would check the geoserver on steroids series:
https://vimeo.com/142335631
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Thu, Apr 21, 2016 at 5:25 PM, Franco Minutiello
Hi Simone,
optimization. T
Size is 1024, 768
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
  NoData Value=0
  NoData Value=0
  NoData Value=0
  NoData Value=0
Ciao
Franco
Dear Franco,
:slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Daniele,
Franco
Hi Franco,
extension.
WKT content on it.
Hope this helps.
Daniele
Hi Franco,
system.
Request: getMap
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
        RemoteOwsURL = null
        Env = {}
        FormatOptions = {}
        Angle = 0.0
        CQLFilter = null
        Elevation =
        FeatureId = null
        StartIndex = null
        ViewParams = null
        Width = 1024
        Height = 768
        Palette = null
        Tiled = false
        SRS = EPSG:900913
        MaxFeatures = null
        Transparent = true
        StyleFormat = sld
        Interpolations =
        SldBody = null
        Sld = null
        StyleUrl = null
        TilesOrigin = null
        Exceptions = SE_XML
        StyleBody = null
        SldVersion = null
        StyleVersion = null
        ScaleMethod = null
        Buffer = 0
        Time =
        Filter = null
        Filters = null
        Get = true
        Version = 1.1.1
        Request = GetMap
Daniele
Thanks
Franco
Size is 1024, 768
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
  NoData Value=0
  NoData Value=0
  NoData Value=0
  NoData Value=0
Franco
Hi Franco,
output?
Daniele
HI all,
examples.
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
   Version: 1
   Key_Revision: 1.2
   Tagged_Information:
         0 0 0 0
         0 0 0 1
      End_Of_Tags.
   Keyed_Information:
      End_Of_Keys.
   End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
44d39'55.73"N)
0.24"N)
44d39'55.73"N)
0.24"N)
44d38'57.99"N)
Thanks
Manager
tiers of
Manager
tiers of
of
Hi Simone,
Do you think i need to increase the heap size?
I saw example with heap set to 256M.
Thanks
Franco
On 21/04/2016 17:31, Simone Giannecchini wrote:
Dear Franco,
are you sure?
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Simone,
optimization. T
Size is 1024, 768
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=PIXEL
Corner Coordinates:
   NoData Value=0
   NoData Value=0
   NoData Value=0
   NoData Value=0
Ciao
Franco
Dear Franco,
:slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Daniele,
Franco
Hi Franco,
extension.
WKT content on it.
Hope this helps.
Daniele
Hi Franco,
system.
Request: getMap
   GEOGCS["WGS 84",
   UNIT["m", 1.0],
   AXIS["x", EAST],
   AXIS["y", NORTH],
         RemoteOwsURL = null
         Env = {}
         FormatOptions = {}
         Angle = 0.0
         CQLFilter = null
         Elevation =
         FeatureId = null
         StartIndex = null
         ViewParams = null
         Width = 1024
         Height = 768
         Palette = null
         Tiled = false
         SRS = EPSG:900913
         MaxFeatures = null
         Transparent = true
         StyleFormat = sld
         Interpolations =
         SldBody = null
         Sld = null
         StyleUrl = null
         TilesOrigin = null
         Exceptions = SE_XML
         StyleBody = null
         SldVersion = null
         StyleVersion = null
         ScaleMethod = null
         Buffer = 0
         Time =
         Filter = null
         Filters = null
         Get = true
         Version = 1.1.1
         Request = GetMap
Daniele
Thanks
  Franco
Size is 1024, 768
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=PIXEL
Corner Coordinates:
   NoData Value=0
   NoData Value=0
   NoData Value=0
   NoData Value=0
Franco
Hi Franco,
output?
Daniele
HI all,
examples.
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
    Version: 1
    Key_Revision: 1.2
    Tagged_Information:
          0 0 0 0
          0 0 0 1
       End_Of_Tags.
    Keyed_Information:
       End_Of_Keys.
    End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
44d39'55.73"N)
0.24"N)
44d39'55.73"N)
0.24"N)
44d38'57.99"N)
Thanks
Manager
tiers of
Manager
tiers of
of
Dear Franco,
I think you are confusing heap and perm size.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Thu, Apr 21, 2016 at 5:43 PM, Franco Minutiello
Hi Simone,
Thanks
Franco
Dear Franco,
are you sure?
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Simone,
optimization. T
Size is 1024, 768
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
  NoData Value=0
  NoData Value=0
  NoData Value=0
  NoData Value=0
Ciao
Franco
Dear Franco,
:slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Daniele,
Franco
Hi Franco,
extension.
WKT content on it.
Hope this helps.
Daniele
Hi Franco,
system.
Request: getMap
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
        RemoteOwsURL = null
        Env = {}
        FormatOptions = {}
        Angle = 0.0
        CQLFilter = null
        Elevation =
        FeatureId = null
        StartIndex = null
        ViewParams = null
        Width = 1024
        Height = 768
        Palette = null
        Tiled = false
        SRS = EPSG:900913
        MaxFeatures = null
        Transparent = true
        StyleFormat = sld
        Interpolations =
        SldBody = null
        Sld = null
        StyleUrl = null
        TilesOrigin = null
        Exceptions = SE_XML
        StyleBody = null
        SldVersion = null
        StyleVersion = null
        ScaleMethod = null
        Buffer = 0
        Time =
        Filter = null
        Filters = null
        Get = true
        Version = 1.1.1
        Request = GetMap
Daniele
Thanks
Franco
Size is 1024, 768
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
  NoData Value=0
  NoData Value=0
  NoData Value=0
  NoData Value=0
Franco
Hi Franco,
output?
Daniele
HI all,
examples.
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
   Version: 1
   Key_Revision: 1.2
   Tagged_Information:
         0 0 0 0
         0 0 0 1
      End_Of_Tags.
   Keyed_Information:
      End_Of_Keys.
   End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
44d39'55.73"N)
0.24"N)
44d39'55.73"N)
0.24"N)
44d38'57.99"N)
Thanks
Manager
tiers of
Manager
tiers of
of
Hi Simone,
probably you're right.
In my opinion, I need to increase heap size to manage a large amounts of data. Is it Right?
In your presentation, the heap size is set to 2048m. In other example for optimization heap size varie from 256m to 512m.
The first test with 256m was very poor in performance, so I increase the value.
  Thank you for all your assistance
Franco
On 21/04/2016 17:45, Simone Giannecchini wrote:
Dear Franco,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Simone,
Thanks
Franco
Dear Franco,
are you sure?
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Simone,
optimization. T
Size is 1024, 768
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=PIXEL
Corner Coordinates:
   NoData Value=0
   NoData Value=0
   NoData Value=0
   NoData Value=0
Ciao
Franco
Dear Franco,
:slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Daniele,
Franco
Hi Franco,
extension.
WKT content on it.
Hope this helps.
Daniele
Hi Franco,
system.
Request: getMap
   GEOGCS["WGS 84",
   UNIT["m", 1.0],
   AXIS["x", EAST],
   AXIS["y", NORTH],
         RemoteOwsURL = null
         Env = {}
         FormatOptions = {}
         Angle = 0.0
         CQLFilter = null
         Elevation =
         FeatureId = null
         StartIndex = null
         ViewParams = null
         Width = 1024
         Height = 768
         Palette = null
         Tiled = false
         SRS = EPSG:900913
         MaxFeatures = null
         Transparent = true
         StyleFormat = sld
         Interpolations =
         SldBody = null
         Sld = null
         StyleUrl = null
         TilesOrigin = null
         Exceptions = SE_XML
         StyleBody = null
         SldVersion = null
         StyleVersion = null
         ScaleMethod = null
         Buffer = 0
         Time =
         Filter = null
         Filters = null
         Get = true
         Version = 1.1.1
         Request = GetMap
Daniele
Thanks
  Franco
Size is 1024, 768
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=PIXEL
Corner Coordinates:
   NoData Value=0
   NoData Value=0
   NoData Value=0
   NoData Value=0
Franco
Hi Franco,
output?
Daniele
HI all,
examples.
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
    Version: 1
    Key_Revision: 1.2
    Tagged_Information:
          0 0 0 0
          0 0 0 1
       End_Of_Tags.
    Keyed_Information:
       End_Of_Keys.
    End_Of_Geotiff.
GCS: 4326/WGS 84
Corner Coordinates:
44d39'55.73"N)
0.24"N)
44d39'55.73"N)
0.24"N)
44d38'57.99"N)
Thanks
Manager
tiers of
Manager
tiers of
of
