I have been struggling to generate a set of imagemosaics inside geoserver 2.5.1. The problem is the “java.io.IOException: Failed to create reader from file:data/subsmon/xxxxxx_xxxxxxxxxxxx_wgs84 and hints null”.
Given a set of say, 17 potential temporal imagemosaics, Geoserver only seems to allow 4 stores to be built at any given time. This problem exists using the gsconfig wrapper around the REST API and if I load the imagemosaics by hand through the web interface.
Of the 17 stores, I can load any four individually, but on load of a 5th, the “create reader” problem appears .
The imagemosaics are all configured against a PostGIS backend and the configuration properties files are not different from one potential mosaic to another. I am reasonably convinced there is not much wrong with the properties files
The raster granules are all GeoTIFFS that were generated by GDAL and are in EPSG:4326, ranging in size from ~ 1Mb to 40Mb; this is fine, since the different mosaics have different sized bounding boxes
Each imagemosiac needs to be created initially with one granule; spatially identical granules will be temporally mosaicked as data is acquired over time.
Is there some configurable limit on the number of imagemosaic datastores allowed in a given Geoserver instance?
Any help in trying to unpack this problem would be gratefully received
Regards
Graeme
