I have problems! When put in the Geoserver in JBoss, my application gives an error (500).
Someone has been there?
Best Regards,
Fernando Quadro
fsquadro@anonymised.com
Diversão em dobro: compartilhe fotos enquanto conversa usando o Windows Live Messenger.
Fernando Quadro ha scritto:
That's internal server error if my memory serves me right.
Could really be anything, no way to tell what without more information.
Do you have the jboss startup logs and/or the geoserver own logs
(data_directory/logs/geoserver.log)
Andrea Aime
OpenGeo - http://opengeo.org
Andrea,
See the log:
2009-01-28 10:25:48,947 ERROR [rules.FacesConfigRuleSet] - Cannot configure DescriptionTextRule for pattern ‘faces-config/managed-bean/description’
java.lang.ClassCastException: org.apache.xerces.jaxp.DocumentBuilderFactoryImpl
at javax.xml.parsers.DocumentBuilderFactory.newInstance(DocumentBuilderFactory.java:29)
at org.apache.commons.digester.NodeCreateRule.(NodeCreateRule.java:363)
at com.sun.faces.config.rules.DescriptionTextRule.(DescriptionTextRule.java:42)
at com.sun.faces.config.rules.FacesConfigRuleSet.addFeatureRules(FacesConfigRuleSet.java:376)
at com.sun.faces.config.rules.FacesConfigRuleSet.addRuleInstances(FacesConfigRuleSet.java:200)
at org.apache.commons.digester.Digester.addRuleSet(Digester.java:1663)
at com.sun.faces.config.ConfigureListener.digester(ConfigureListener.java:973)
at com.sun.faces.config.ConfigureListener.contextInitialized(ConfigureListener.java:270)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3854)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4361)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:761)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:741)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:553)
at sun.reflect.GeneratedMethodAccessor199.invoke(Unknown Source)
2009-01-28 10:25:48,947 ERROR [[localhost].[/cmrMap]] - Exception sending context initialized event to listener instance of class com.sun.faces.config.ConfigureListener
java.lang.IllegalStateException: Cannot configure DescriptionTextRule for pattern ‘faces-config/managed-bean/description’
at com.sun.faces.config.rules.FacesConfigRuleSet.addFeatureRules(FacesConfigRuleSet.java:382)
at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:297)
at org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
Best Regards,
Fernando Quadro
Date: Wed, 28 Jan 2009 15:26:43 +0100
To: fsquadro@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Problem with JBoss
That’s internal server error if my memory serves me right.
Andrea Aime
Looks like a conflict with some XML libraries. I would check that your app server does not have any xml libraries in "global" locations. Global meaning that they are visible to deployed applications. An example in tomcat is the "common/lib" directory, i am not sure if there is an equivalent in jboss.
-Justin
Fernando Quadro wrote:
Andrea,
See the log:
2009-01-28 10:25:48,947 ERROR [rules.FacesConfigRuleSet] - Cannot configure DescriptionTextRule for pattern 'faces-config/managed-bean/description'
at org.apache.commons.digester.NodeCreateRule.<init>(NodeCreateRule.java:363)
at com.sun.faces.config.rules.DescriptionTextRule.<init>(DescriptionTextRule.java:42)
java.lang.IllegalStateException: Cannot configure DescriptionTextRule for pattern 'faces-config/managed-bean/description'
Best Regards,
Fernando Quadro
> From: aaime@anonymised.com
> > Hi,
> Cheers
> Andrea
> Andrea Aime
Diversão em dobro: compartilhe fotos enquanto conversa usando o Windows Live Messenger. <http://www.microsoft.com/windows/windowslive/messenger.aspx>
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
Justin Deoliveira
Fernando,
which JBoss version are you using?
You might want to tweak the JBoss classloader.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, Jan 28, 2009 at 4:43 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Andrea,
See the log:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Fernando Quadro
> > Hi,
> Cheers
> Andrea
> Andrea Aime
Live Messenger.
Justin Deoliveira
Hi Simone,
I’m using version 4.2.0.CR1
Best Regards,
Fernando Quadro
Date: Wed, 28 Jan 2009 16:49:44 +0100
To: jdeolive@anonymised.com
CC: fsquadro@anonymised.com; geoserver-users@lists.sourceforge.net
Fernando,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Wed, Jan 28, 2009 at 4:43 PM, Justin Deoliveira jdeolive@anonymised.com wrote:
app server does not have any xml libraries in “global” locations. Global
tomcat is the “common/lib” directory, i am not sure if there is an
-Justin
Andrea,
See the log:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Fernando Quadro
To: fsquadro@anonymised.com5…
Andrea Aime
Live Messenger.
Justin Deoliveira
Geoserver-users@anonymised.comceforge.net
Notícias direto do New York Times, gols do Lance, videocassetadas e muitos outros vídeos no MSN Videos! Confira já!
