The bug was marked as fixed yes, but the fix did not seem to work for Jean. Perhaps you can try and upgrade and let us know if you see it resolved.
Felipe Conter wrote:
I just wonder, was this problem fixed already?
i'm using 1.7.3 and have the same problem... i'm wondering if it's worth upgrading.
2009/4/2 Jean-Baptiste Raynaud <jb.raynaud@anonymised.com <mailto:jb.raynaud@anonymised.com>>
I downloaded the latest nightly build and tested it, but I have
still this bug. I work with the war version deployed into tomcat 6.
Thanks for your help.
Justin Deoliveira-6 wrote:
I was able to reproduce this one. I have filed a jira to be
fixed for 1.7.4: http://jira.codehaus.org/browse/GEOS-2820 The
fix is straight forward, i will commit it in a few minutes so if
you want to grab the next nightly build you should see this
fixed. -Justin JBRS34 wrote: > Hi, I have recently installed the
new Geoserver version 1.7.3a. and I > have a problem with layers
alias. I work with a PostGis database, the > version of
PostGreSQL is 8.3.5 and the version of PostGis is 1.3.5. In >
PostGis, the layer name is for example : my_layer, when I
configure it > in Geoserver I give it an alias name like My
Layer. The problem is when > I want to receive entity
information with getFeatureInfo request I > receive nothing.
Here my content.ftl wich is very simple /<#list > features as
feature> <#list feature.attributes as attribute> <#if >
!attribute.isGeometry> ${attribute.name <http://attribute.name>}
: ${attribute.value} > / In fact, it seems that the features
list is empty. If before the > <#list features as feature> tag I
write ${type.attributes} ${features} I > can read the
type.attributes but features list appears as an empty > array.
If I *do not give an alias to the layer the getFeatureInfo >
requesst works fine!* Is there any solution with this issue? Or
is it a > known bug and I have to downgrade to an old version to
geoserver. Thanks > in advance for anyone that have a response
or a solution. >
> View this message in context: problem with layer alias and >
getFeatureInfo request > > Sent from the GeoServer - User
mailing list archive > at Nabble.com. > > >
> > _______________________________________________ >
Geoserver-users mailing list >
<mailto:Geoserver-users@lists.sourceforge.net> >
https://lists.sourceforge.net/lists/listinfo/geoserver-users --
Justin Deoliveira OpenGeo - http://opengeo.org Enterprise
support for open source geospatial.
_______________________________________________ Geoserver-users
mailing list Geoserver-users@lists.sourceforge.net
View this message in context: Re: problem with layer alias and
<http://www.nabble.com/problem-with-layer-alias-and-getFeatureInfo-request-tp22830631p22843232.html>
Sent from the GeoServer - User mailing list archive
<http://www.nabble.com/GeoServer---User-f1194.html> at Nabble.com.
Felipe Pierre Conter
felipeconter.cc@anonymised.com <mailto:felipeconter.cc@anonymised.com>
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Justin Deoliveira
