[Geoserver-users] Problem with Oracle data store on session startup sql script
Hi everyone,
I want to create an Oracle data store with defining Session startup SQL parameter.
For example, when I set this parameter with the following PL/SQL bloc :
begin
fdp.trace_geoserver(‘Session startup’);
end;
I have this message : Error creating data store, check the parameters. Error message: Unable to obtain Oracle Connection require for SDO Geometry access).Check connection pool implementation to unsure unwrap is available
My environment is :
  • Windows 2008 R2 x64
  • Oracle 11g R2 x64
  • Geoserver 2.61
  • Apache 7.0.47 x64
  • Java 1.7
Thanks for your help.
Best regards,
Kamardine
please share the full stack trace, to be found in the logs
On Wed, Dec 31, 2014 at 9:41 AM, Kamardine YOUSSOUFA <Kamardine.YOUSSOUFA@anonymised.com> wrote:
Hi everyone,
begin
end;
My environment is :
  • Oracle 11g R2 x64
  • Geoserver 2.61
  • Apache 7.0.47 x64
  • Java 1.7
Best regards,
Kamardine
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Geoserver-users mailing list
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
