-----Original Message-----
Sent: Thursday, March 12, 2009 2:53 PM
To: Kris Geusebroek
Cc: geoserver-users
Subject: Re: [Geoserver-users] Problem with OracleNG and Loose BBOX
Kris Geusebroek ha scritto:
I think I found a bug in the OracleNG plugin.
When the parameter Loose bbox is set to true and a bbox filter is used
the method doSDOFilter is called.
This results in the following query:
SELECT column1, GEOMETRY as GEOMETRY from table1 WHERE
SDO_FILTER(GEOMETRY, ?) = ' TRUE'
Which is an invalid query.
SDO_FILTER uses 3 parameters so it should be:
SDO_FILTER(GEOMETRY, ?, 'querytype=WINDOW') = ' TRUE'
Workaround is to set the loose bbox parameter to false so the plugin
creates an SDO_RELATE version of the query like this:
SDO_RELATE(GEOMETRY, ?, 'mask=anyinteract querytype=WINDOW') = ' TRUE'
I think you work with an old Oracle release (pre 10.1). In previous releases, the SDO_FILTER operator required three parameters. Effective with Oracle Spatial release 10.1, the operator has only two parameters: a geometry_column and geometry from a table or a transient SDO_GEOMETRY object.
In newer versions any keywords for the third parameter that were supported in the previous release will still work (for backward compatibility); but the use of those keywords is deprecated.
To: Kris Geusebroek
Cc: geoserver-users
SDO_FILTER(GEOMETRY, ?) = ’ TRUE’
SDO_FILTER(GEOMETRY, ?, ‘querytype=WINDOW’) = ’ TRUE’
SDO_RELATE(GEOMETRY, ?, ‘mask=anyinteract querytype=WINDOW’) = ’ TRUE’
Andrea Aime
OpenGeo - http://opengeo.org
Apps built with the Adobe(R) Flex(R) framework and Flex Builder™ are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse™based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Aaah, this would explain why it works for my Oracle XE, it's a
reduced functionality version of 10.2 afaik.
Anyways, if having three params works for all Oracle versions,
let's change it.
Andrea Aime
I agree with you, but I think it’s better to code Oracle support distinguishing specific versions. It’s more clear and simpler to mantain. Finally, this helps to code specific query, as SDO_FILTER and SDO_RELATE in Oracle prior 10.1 with the sdo_cs.viewport_transform function.
Aaah, this would explain why it works for my Oracle XE, it’s a
let’s change it.
Andrea Aime
