Hello everyone
I have a problem with uploading files to PostGIS shape.
Loading my shape files directly on Geoserver see that as using openlayer wms layer on a base map for google maps, it is exactly superimposed coordinates in value;
var myBaseLayer = new OpenLayers.Layer.Google(“Google”,
‘sphericalMercator’: true,
‘maxExtent’: new OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34)
unesco = new OpenLayers.Layer.WMS(
“TOPP unesco”,
“http://localhost:8080/geoserver/wms?”,
layers: ‘topp:unesco’,
styles: ‘’,
srs: ‘EPSG:4326’,
format: ‘image/png’,
tiled: ‘true’,
tilesOrigin : “143.60260815000004,-43.851764249999995”,
transparent: true
‘opacity’: 0.75, ‘isBaseLayer’: false, ‘wrapDateLine’: true,
hand, if the shape file on the first load PostGIS
with this sintax : shp2pgsql shape\unesco.shp unesco > unesco.sql
then the levy should Geoserver, the wms layer no longer appears in the same coordinates but is translated into another coordinate and shown only at a low level of zoom
I can not understand why each of the two wms layer (that is loaded from PostGIS, either directly shp files) are displayed in the DEMO of Geoserver with the same coordinates and the same scale
Marcello Brunaldi ha scritto:
Hello everyone
var myBaseLayer = new OpenLayers.Layer.Google("Google",
'sphericalMercator': true,
'maxExtent': new OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34)
"TOPP unesco",
"http://localhost:8080/geoserver/wms?",
layers: 'topp:unesco',
styles: '',
srs: 'EPSG:4326',
format: 'image/png',
tiled: 'true',
tilesOrigin : "143.60260815000004,-43.851764249999995",
transparent: true
'opacity': 0.75, 'isBaseLayer': false, 'wrapDateLine': true, }
with this sintax : **shp2pgsql shape\unesco.shp unesco > unesco.sql**
First off, remove tilesOrigin, as that is no more a valid value
for the origins of one of the displayed tiles, since you changed
the projection.
Second, I don't think you're reprojecting the unesco layer.
Try setting srs: 'EPSG:900913' among its parameters
Andrea Aime
OpenGeo - http://opengeo.org
Marcello Brunaldi wrote:
Hello everyone
wms
coordinates
in value;
'maxExtent': new
"TOPP unesco",
styles: '',
srs: 'EPSG:4326',
tiled: 'true',
transparent: true
true,
with this sintax : *shp2pgsql shape\unesco.shp unesco > unesco.sql*
I think you shoud use the -s flag with shp2pgsql to specify your SRID. ( i.
-s 4326).
Is the postgis data woking using a Desktop Client ?
Bye
Luca Casagrande
View this message in context: http://www.nabble.com/Problem-with-shape-loaded-from-postgis-tp21996921p21997922.html
