[Geoserver-users] Problem with style for wind direction data
I’m using GeoServer 2.8.4, with JVM version 1.7.0_80 (Java HotSpot™ 64-Bit Server VM). I’m also using Postgresql server version 9.4.0.
I have published raster data representing wind direction like Image Mosaics. They are in EPSG:4285 with a BBOX [-16.058210564139415,32.96955965348397,39.2896078071642,80.02803653793978]
I create a style that represents the wind direction with arrows, in function of the pixel values.
Here the style:
Wind Direction
<ogc:Function name=“gs:RasterAsPointCollection”>
<ogc:Function name=“parameter”>
ogc:Literaldata</ogc:Literal>
</ogc:Function>
</ogc:Function>
ogc:Filter
ogc:PropertyIsGreaterThan
ogc:PropertyNameGRAY_INDEX</ogc:PropertyName>
ogc:Literal0</ogc:Literal>
</ogc:PropertyIsGreaterThan>
</ogc:Filter>
extshape://narrow
#2d5da1
#2d5da1
1.5
true
In a geoserver version 2.7.1 that I use for other projects it works properly.
When i call the layer with this WMS:
127.0.0.1/geoserver/wind/wms?port=8181&LAYERS=id1359s011011r000-europe&TRANSPARENT=TRUE&VERSION=1.1.0&TIME=2016-04-29T10%3A06%3A00.000Z&TILED=true&SERVICE=WMS&REQUEST=GetMap&STYLES=&FORMAT=image%2Fpng&SRS=EPSG%3A4258&BBOX=29,33,74,78&WIDTH=256&HEIGHT=256
I have this error:
http://paste.ubuntu.com/17849610/
and in wms file i see
Does anyone has suggestions about this problem?
Thank you for your help.
Best regards.
93978]
That is well outside the valid range for EPSG 4285:
http://spatialreference.org/ref/epsg/4285/
says:
50.7500, 24.4800, 51.6400, 26.1800
Brad
Sorry, my fault. The EPSG I used is 4258 http://www.spatialreference.org/ref/epsg/4258/.
I know that my BBOX is a bit larger but it is not a problem for wind products in geoserver 2.7.1. The error comes out only in geoserver 2.8.4.
2016-06-26 2:42 GMT+02:00 Brad Hards <bradh@anonymised.com>:
93978]
says:
Brad
On Sat, Jun 25, 2016 at 12:57 PM, matteo rivola <mrganesh86@anonymised.com>
wrote:
I have this error:
Ciao Matteo,
the stack trace appears to be cut, do you have a full version of it?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ciao Andrea,
I set logging level in VERBOSE mode.
Here the new stack trace: http://paste.ubuntu.com/17960269/
And here the xml with error response: http://paste.ubuntu.com/17960366/
Matteo
2016-06-27 10:03 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Sat, Jun 25, 2016 at 12:57 PM, matteo rivola <mrganesh86@anonymised.com> wrote:
I have this error:
Ciao Matteo,
Ing. Andrea Aime
@geowolf
Technical Lead
Dear all,
I replaced in the style “TextSymbolizer” with “PointSymbolizer” like below:
Wind Direction
</ogc:Function>
</ogc:Function>
ogc:Filter
</ogc:Filter>
35000000
extshape://narrow
#2d5da1
#2d5da1
1.5
but the issue still remain.
In addition, I have no error for WMS like this http://paste.ubuntu.com/18092027/.
For the same product and different BBOX this WMS gives error http://paste.ubuntu.com/18092053/.
Best regards.
2016-06-27 11:32 GMT+02:00 matteo rivola <mrganesh86@anonymised.com>:
Ciao Andrea,
Matteo
2016-06-27 10:03 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com…>:
I have this error:
Ciao Matteo,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Matteo,
as far as I can see the reason is that there is no match for &TIME=2016-05-04T19%3A45%3A00.000Z in the database, at least in that bounding box.
The resulting exception should not be there, you should get an empty image instead, but I guess you were expecting to match data there?
Wondering if it might be related to timezone shifts… but looking at the query logs, it does not seem to be the case:
27 Jun 09:21:13 DEBUG [geotools.jdbc] - SELECT "fid",encode(ST_AsEWKB("the_geom"),'base64') as "the_geom","location","ingestion","published","width","height" FROM "public"."id11s011011r000-europe" WHERE  ("the_geom" && ST_GeomFromWKB(?, 4258) AND "ingestion" = ? AND "ingestion" IS NOT NULL )
27 Jun 09:21:13 DEBUG [geotools.jdbc] - 1 = POLYGON ((6.341155153396195 32.9433639560844, 6.341155153396195 33.09067219516419, 28.965640124374357 33.09067219516419, 28.965640124374357 32.9433639560844, 6.341155153396195 32.9433639560844))
27 Jun 09:21:13 DEBUG [geotools.jdbc] - 2 = 2016-05-04 19:45:00.0
27 Jun 09:21:13 DEBUG [geotools.jdbc] - CLOSE CONNECTION
So hmm... unless you were actually expecting a empty map/tile there, there might be some data related problem?
On Mon, Jun 27, 2016 at 11:32 AM, matteo rivola <mrganesh86@anonymised.com> wrote:
Ciao Andrea,
Matteo
On Sat, Jun 25, 2016 at 12:57 PM, matteo rivola <mrganesh86@anonymised.com…> wrote:
I have this error:
Ciao Matteo,
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
I expect to get an empty image for that BBOX and for that TIME.
I publish the tiles above an Openlayer maps, thus get empty images is exactly what I want. But like you say there is an unexpected exception.
The problem happen only for the style linked. If I use a style with the RULE “RasterSymbolizer” I have no exception for the same layer.
Matteo.
2016-06-29 17:18 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Matteo,
Ciao Andrea,
Matteo
Ing. Andrea Aime
@geowolf
Technical Lead
2016-06-27 10:03 GMT+02:00 Andrea Aime <andrea.aime@…1107…>:
I have this error:
Ciao Matteo,
Ing. Andrea Aime
@geowolf
Technical Lead
Ah ok,
then I’ve already seen this issue, but had no time to investigate.
Could you open a bug report at https://osgeo-org.atlassian.net/projects/GEOS ?
On Thu, Jun 30, 2016 at 10:28 AM, matteo rivola <mrganesh86@anonymised.com> wrote:
Hi Andrea,
Matteo.
Hi Matteo,
Ciao Andrea,
Matteo
Ing. Andrea Aime
@geowolf
Technical Lead
I have this error:
Ciao Matteo,
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I have created the bug https://osgeo-org.atlassian.net/browse/GEOS-7610, with medium Priority.
Please tell me If I have to increase the priority or modify something else.
Thank you
Matteo
2016-06-30 10:34 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Ah ok,
Hi Andrea,
Matteo.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Matteo,
Ciao Andrea,
Matteo
Ing. Andrea Aime
@geowolf
Technical Lead
I have this error:
Ciao Matteo,
Ing. Andrea Aime
@geowolf
Technical Lead
