On Wed, Oct 28, 2015 at 2:54 PM, chadi jaber <chadijaber986@anonymised.com>
wrote:
Hello,
I have installed the geoserver wps extension and developped a custom wps
processing:
import org.geotools.util.logging.Logging;
import java.util.logging.Logger;
@DescribeProcess(title = "geosigwebndvi", description = "Compute the NDVI for a given image")
public class NDVIProcessing implements GeoServerProcess {
private static final Logger LOGGER = Logging
.getLogger(NDVIProcessing.class);
Everything is working fine but no logging can be found in the logs folder of geoserver. Is there anything else we need to add to the jar created from the code above in order to generate my wps processing logs.
I guess your process is not in a org.geoserver package right? If that's the
case, you have to
modify the log4j logging profiles in order to include your package too.
You can find them in the $GEOSERVER_DATA_DIR/logs directory, change them,
then switch
back and forth the profile in the UI to make GeoServer reload your new
config.
Or create a custom one with a name of yours, the UI allows to read any
property file found
in the logs directory
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
