[Geoserver-users] Problem with the layer group on trunk version
Hi everyone,
I've created a layer group in the WMS configuration, and when I do a WMS request with the parameter "layers=bluemarblegroup", I get this error : http://rafb.net/p/1reNxb22.html.
Andrea has created a JIRA task GEOS-1181 at this subject, thanks :slight_smile:
A wms request with these eight coverages defined, using this syntax works : layers=geom:a1_tiled2,geom:a2_tiled2, ...
Here is the end of the service.xml file in my data dir :
<service type = "WMS" enabled = "true" >
        ServiceDTO elements, needed for the capabilities document
        Title and OnlineResource are the two required
      <name>OGC:WMS</name>
      <title>My GeoServer WMS</title>
      <abstract>
This is a description of your Web Map Server.
     </abstract>
      <metadataLink >null</metadataLink>
      <keywords >
        <keyword>WFS</keyword>
        <keyword>WMS</keyword>
        <keyword>GEOSERVER</keyword>
      </keywords>
      <onlineResource>http://localhost:8080/geoserver/wms&lt;/onlineResource&gt;
      <fees>NONE</fees>
      <accessConstraints>NONE</accessConstraints>
      <srsXmlStyle value = "false" />
      <maintainer>http://jira.codehaus.org/secure/BrowseProject.jspa?id=10311&lt;/maintainer&gt;
      <BaseMapGroups >
        <BaseMapGroup baseMapTitle = "bluemarblegroup" >
          <baseMapLayers>geom:a1_tiled2,geom:a2_tiled2,geom:b1_tiled2,geom:b2_tiled2,geom:c1_tiled2,geom:c2_tiled2,geom:d1_tiled2,geom:d2_tiled2</baseMapLayers>
          <baseMapStyles>raster,raster,raster,raster,raster,raster,raster,raster</baseMapStyles>
        </BaseMapGroup>
      </BaseMapGroups>
      <svgAntiAlias>true</svgAntiAlias>
      <allowInterpolation>Nearest</allowInterpolation>
    </service>
Cédric Briançon.
