[Geoserver-users] Problem with timestamps and Oracle datastore
we are having problems retrieving data using WFS from a oracle datastore, specifically related to dates and timestamps. We have read other posts in which other people had similar problems, but not found response.
Our WFS filters are similar to:
<Ogc:Filter xmlns:ogc = “http://www.opengis.net/ogc”>
Ogc:PropertyIsBetween
Ogc:PropertyNameFH_TIMESTAMP</ogc:PropertyName>
Ogc:LowerBoundary
Ogc:Literal2015-06-08 12:00:00</ogc:Literal>
</Ogc:LowerBoundary>
Ogc:UpperBoundary
Ogc:Literal2015-06-08 13:00:00</ogc:Literal>
</Ogc:UpperBoundary>
</Ogc:PropertyIsBetween>
Here in Spain, we work in GMT+1. The FH_TIMESTAMP field is defined as TIMESTAMP in the related table. Tomcat where GeoServer is deployed is set as defaulta to GMT.
This query must return a single result with date/time 2015-06-08 12:12:01. Indeed it is recovering, but the response shows 10:12:01 instead of 12:12:01. Also, the date field (Date type in BD … ), from which the timestamp is generated, is one day late:
Xxx:FH_FECHA2015-06-07Z</xxx:FH_FECHA>
xxx:FH_TIMESTAMP2015-06-08T10:12:01Z</xxx:FH_TIMESTAMP>
Geoserver The log shows the following information for this request:
03/07/2016 13: 58: 27.468 DEBUG [geotools.jdbc] - SELECT * FROM (? SELECT FH_FECHA, FH_TIMESTAMP, …, as GEOM GEOM FROM … WHERE (FH_TIMESTAMP BETWEEN ? AND ?)) WHERE ROWNUM <= 2000
03/07/2016 13: 58: 27.468 DEBUG [geotools.jdbc] - 1 = 2015-06-08 12:00:00.0
07/03/2016 13: 58: 27.468 DEBUG [geotools.jdbc] - 2 = 2015-06-08 13:00:00.0
07/03/2016 13: 58: 27.503 DEBUG [geotools.jdbc] - 2015-06-08 12: 12:01.0 is not of type java.sql.Timestamp, attempting conversion
We have tried to make the same request with “geoserver” format. In this case, we have to decrease the range of timestamp in two hours in order to recover the same data:
Ogc:LowerBoundary
Ogc:Literal2015-06-08T10:00:00Z</ogc:Literal>
Ogc:UpperBoundary
Ogc:Literal2015-06-08T11:00:00Z</ogc:Literal>
Result is the same: hour late and erroneous date:
Same as for the previous query.
What should we do to show to avoid previous day’s date and time with two hours late?
Any help is welcome.
Thank you very much, greetings
any help on this, please? We fail to understand why the date is sent with a day less than that stored in BD and time to two hours before.
Thanks
2016-03-11 12:21 GMT+01:00 DGIS Devels <webgisdesarrollo@anonymised.com>:
Ogc:LowerBoundary
Ogc:UpperBoundary
Ogc:LowerBoundary
Ogc:UpperBoundary
The quick answer to why there is a 2 hour difference is daylight savings (or summer) time. You are actually in GMT+2 in June.
The simple answer is for your client to convert all your timestamps to GMT before any interaction with the data base if that is what you have the database set to.
Ian
On 16 March 2016 at 08:34, DGIS Devels <webgisdesarrollo@anonymised.com> wrote:
Thanks
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-users mailing list
Ogc:LowerBoundary
Ogc:UpperBoundary
Ogc:LowerBoundary
Ogc:UpperBoundary
Ian Turton
We had not thought it was a problem related to the time change. We haveconsidered it and and that Geoserver returns results in GMT, and no problem with the hour.
However, we still find answers to the date indicated with a day less than stored in BD.
Thank you very much for your response.
2016-03-16 10:06 GMT+01:00 Ian Turton <ijturton@anonymised.com>:
Ian
Thanks
Ian Turton
Ogc:LowerBoundary
Ogc:UpperBoundary
Ogc:LowerBoundary
Ogc:UpperBoundary
The day change occurs because your time stamp was truncated to a date at some point and then moved back by an hour (or two) which moves it into the previous day and then it got truncated again.
Ian
On 17 March 2016 at 11:09, DGIS Devels <webgisdesarrollo@anonymised.com…> wrote:
Ian
Thanks
Ian Turton
Ogc:LowerBoundary
Ogc:UpperBoundary
Ogc:LowerBoundary
Ogc:UpperBoundary
Ian Turton
On Thu, Mar 17, 2016 at 12:09 PM, DGIS Devels <webgisdesarrollo@anonymised.com>
Dates are also converted to GMT, there is an interesting discussion on the
geotools-devel list for that,
and I believe a new flag is being introduced for those that want dates not
to be considered a concept
related to timezone
I believe it's this one:
http://osgeo-org.1560.x6.nabble.com/GEOT-5329-Proposal-to-avoid-Date-shifting-due-to-Timezones-td5241912.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
All right! We will consider it when showing the return date field. Thanks to all, again
2016-03-17 12:25 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
On Thu, Mar 17, 2016 at 12:09 PM, DGIS Devels <webgisdesarrollo@anonymised.com> wrote:
Dates are also converted to GMT, there is an interesting discussion on the geotools-devel list for that,
and I believe a new flag is being introduced for those that want dates not to be considered a concept
related to timezone
I believe it’s this one: http://osgeo-org.1560.x6.nabble.com/GEOT-5329-Proposal-to-avoid-Date-shifting-due-to-Timezones-td5241912.html
Ing. Andrea Aime
@geowolf
Technical Lead
