Hi list,
using 1.6RC3 I cannot use a non-spatial Oracle table. This worked okay in
the 1.3 series. I can create the featuretype, but when I try and apply the
configuration I get:
GeoServer - Exception
The following exception was thrown:
java.lang.NullPointerException
The log file says:
27 Sep 09:27:44 WARN [action.RequestProcessor] - Unhandled Exception thrown:
class java.lang.NullPointerException
27 Sep 09:27:44 ERROR [[/geoserver].[action]] - Servlet.service() for
servlet action threw exception
at com.vividsolutions.jts.geom.Envelope.init(Envelope.java:254)
at com.vividsolutions.jts.geom.Envelope.<init>(Envelope.java:186)
at
org.vfny.geoserver.global.dto.CloneLibrary.clone(CloneLibrary.java:140)
at
org.vfny.geoserver.config.FeatureTypeConfig.toDTO(FeatureTypeConfig.java:354)
at org.vfny.geoserver.config.DataConfig.toDTO(DataConfig.java:366)
at
org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:66)
at
org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at javax.servlet.http.HttpServlet.service(HttpServlet.java(Compiled
Code))
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java(Compiled
Code))
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java(Compiled
Code))
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java(Compiled
Code))
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at
Code))
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at
Code))
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at
Code))
at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at
Code))
at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at
Code))
at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at
Code))
at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at
Code))
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at
Code))
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at
Code))
at
Code))
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
Code))
at
Code))
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:526)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:856)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:744)
at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:568)
Is this a known issue?
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
