[Geoserver-users] problem with view on oracle
I have table that create from shp2sdo and migrate to oracle
and add featuretype and display correctly.
then that I add table not spatial data and create view in oracle and add
this is my sql that create view
create or replace view cw_sale_indust_c02 as
select emp.data,
       ch.prov_name,
       clust.value clustname,
       boundary.geom
  from changwat_sale emp,
       changwat_cluster clust,
       changwat ch,
       changwat_boundary boundary
where emp.cluster_id = clust.id
       and type = 1
       and emp.cluster_id=2
       and emp.prov_id = ch.prov_code
       and emp.prov_id = boundary.prov_code
and this is sql that insert user_sdo_geom_metadata
INSERT INTO user_sdo_geom_metadata
  (table_name, column_name, diminfo, srid)
  SELECT 'cw_sale_indust_c02', column_name, diminfo, srid
    FROM user_sdo_geom_metadata WHERE table_name = 'CHANGWAT_BOUNDARY'
then I want another featuretype so I created view with same sql by changed
view name and use same sld
but It don't display correctly by show blank screen.
Did I make something wrong and how do I solve?
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4205915
Sent from the GeoServer - User forum at Nabble.com.
<cut/>
Could you post the "describe" of your view and the relevant row in the sdo_geom_metadata table ?
    Luca Morandini
www.lucamorandini.it
This is some data in my view(in csv format)
"DATA","PROV_NAME","CLUSTNAME","GEOM.SDO_GTYPE","GEOM.SDO_SRID","GEOM.SDO_POINT.X","GEOM.SDO_POINT.Y","GEOM.SDO_POINT.Z","GEOM.SDO_ELEM_INFO","GEOM.SDO_ORDINATES"
"333.7","TRAT","Food","2003","","","","","<Collection>","<Collection>"
"5984.55","PRACHUAPKHILIKHAN","Food","2003","","","","","<Collection>","<Collection>"
"5926.03","CHUMPHON","Food","2003","","","","","<Collection>","<Collection>"
"2528.47","RANONG","Food","2003","","","","","<Collection>","<Collection>"
"5559.21","SURATTHANI","Food","2003","","","","","<Collection>","<Collection>"
"211.22","CHIANG
RAI","Food","2003","","","","","<Collection>","<Collection>"
and sdo_geom(csv)
"TABLE_NAME","COLUMN_NAME","DIMINFO","SRID"
"K250_CHANGWAT_BOUNDARY","GEOM","<Collection>",""
"CW_SALE_INDUST_C02","GEOM","<Collection>",""
"CW_SALE_INDUST_C01_LABEL","GEOM","<Collection>",""
"CW_SALE_INDUST_C01","GEOM","<Collection>",""
"CHANGWAT_BOUNDARY","GEOM","<Collection>",""
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4207000
No no, I wanted just the output of "DESCRIBE <table_name>", in order to spot some column names GeoServer may choke on.
    Luca Morandini
create table CHANGWAT_BOUNDARY
  AREA NUMBER,
  PERIMETER NUMBER,
  THAI_BND_ NUMBER not null,
  THAI_BND_I NUMBER,
  PROV_CODE VARCHAR2(2),
  PROV_NAME VARCHAR2(50),
  PROV_THAI VARCHAR2(50),
  PART_CODE VARCHAR2(2),
  GEOM MDSYS.SDO_GEOMETRY
tablespace USERS
  pctfree 10
  initrans 1
  maxtrans 255
  storage
    initial 64K
    minextents 1
    maxextents unlimited
-- Create/Recreate primary, unique and foreign key constraints
alter table CHANGWAT_BOUNDARY
  add constraint PK_CHANGWAT primary key (THAI_BND_)
  using index
  tablespace USERS
  pctfree 10
  initrans 2
  maxtrans 255
  storage
    initial 64K
    minextents 1
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4208483
No, I meant the describe of the view, just type (at the SQL*Plus or SQLWorksheet prompt):
DESCRIBE cw_sale_indust_c02;
    Luca Morandini
SQL> DESCRIBE cw_sale_indust_c02;
Name Null? Type
DATA NUMBER
PROV_NAME VARCHAR2(30)
CLUSTNAME VARCHAR2(50)
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4209086
Name Null? Type
DATA NUMBER
Well, everything seems to be fine here... would you mind setting the logging level to "FiNE" or "FINER" and scan the logs for anything related to this FeatureType ?
One question: has the FeatureType been created successfully ?
    Luca Morandini
sorry where can I set log level?
.Featuretype created sucessfully not have any exception or error.
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4209668
Use the Geoserver administration application, select there Config - Server - Logging Level.
-Jukka-
Lähettäjä: geoserver-users-admin@lists.sourceforge.net puolesta: worr
Lähetetty: ke 3.5.2006 16:01
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] problem with view on oracle
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
when I click "generate" button on featuretype configuration page.
I'm got exception.
4 ¾.¤. 2549 12:04:16
org.vfny.geoserver.action.data.DataFeatureTypesSelectAction execute
INFO: setting session and user ftConfig to : FeatureTypeConfig[name:
CW_EMP_INDUST_C01 schemaName: null SRS: 4326 schemaAttributes: null
schemaBase null]
4 ¾.¤. 2549 12:04:16 DefaultFactory isReady
FINE: Unavailable factory: European Petroleum Survey Group
org.opengis.referencing.FactoryException: Failed to connect to the EPSG
database
  at
org.geotools.referencing.factory.epsg.DefaultFactory.createBackingStore(DefaultFactory.java:316)
  at
org.geotools.referencing.factory.DeferredAuthorityFactory.getBackingStore(DeferredAuthorityFactory.java:127)
  at
org.geotools.referencing.factory.BufferedAuthorityFactory.isReady(BufferedAuthorityFactory.java:194)
  at
org.geotools.referencing.factory.DeferredAuthorityFactory.isReady(DeferredAuthorityFactory.java:115)
  at org.geotools.factory.FactoryRegistry$1.filter(FactoryRegistry.java:81)
  at javax.imageio.spi.FilterIterator.advance(Unknown Source)
  at javax.imageio.spi.FilterIterator.next(Unknown Source)
  at org.geotools.resources.LazySet.addNext(LazySet.java:72)
  at org.geotools.resources.LazySet.get(LazySet.java:121)
  at org.geotools.resources.LazySet$Iter.next(LazySet.java:140)
  at org.geotools.referencing.CRS.decode(CRS.java:218)
  at
org.vfny.geoserver.form.data.TypesEditorForm.setSRS(TypesEditorForm.java:612)
  at
org.vfny.geoserver.form.data.TypesEditorForm.reset(TypesEditorForm.java:218)
  at org.apache.struts.taglib.html.FormTag.initFormBean(FormTag.java:560)
  at org.apache.struts.taglib.html.FormTag.doStartTag(FormTag.java:520)
  at
org.apache.jsp.WEB_002dINF.pages.data.featureTypes.Editor_jsp._jspService(Editor_jsp.java:112)
  at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:133)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
  at
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:311)
  at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:301)
  at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:248)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:284)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:204)
  at
org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:750)
  at
org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:636)
  at
org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:546)
  at
org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:1002)
  at
org.apache.jasper.runtime.PageContextImpl.include(PageContextImpl.java:626)
  at org.apache.struts.tiles.TilesUtilImpl.doInclude(TilesUtilImpl.java:137)
  at org.apache.struts.tiles.TilesUtil.doInclude(TilesUtil.java:177)
  at org.apache.struts.taglib.tiles.InsertTag.doInclude(InsertTag.java:756)
  at
org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag(InsertTag.java:881)
  at org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag.java:473)
  at
org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspx_meth_tiles_insert_6(mainLayout_jsp.java:1353)
  at
org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspService(mainLayout_jsp.java:539)
  at
  at
  at
  at
  at
org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:510)
  at
org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:445)
  at
org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:359)
  at
org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1069)
  at
org.apache.struts.tiles.TilesRequestProcessor.doForward(TilesRequestProcessor.java:274)
  at
org.apache.struts.tiles.TilesRequestProcessor.processTilesDefinition(TilesRequestProcessor.java:254)
  at
org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:309)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:279)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
  at
  at
  at
  at
  at
  at
  at
  at
  at
org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:455)
  at
org.apache.struts.tiles.TilesRequestProcessor.proces.LazySet$Iter.next(LazySet.java:140)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:320)
  at
  at
  at
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:233)
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:257)
  at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:151)
  at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:567)
  at
org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:245)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:199)
  at
  at
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:184)
  at
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:164)
  at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:149)
  at
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:156)
  at
  at
  at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:972)
  at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:206)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:833)
  at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:732)
  at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:619)
  at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:688)
  at java.lang.Thread.run(Unknown Source)
Caused by: java.sql.SQLException: No data source found.
  at
org.geotools.referencing.factory.epsg.DefaultFactory.createFactory(DefaultFactory.java:264)
  at
org.geotools.referencing.factory.epsg.DefaultFactory.createBackingStore(DefaultFactory.java:308)
  ... 98 more
4 ¾.¤. 2549 12:04:16 org.geotools.data.jdbc.ConnectionPool getConnection
FINE: Getting available connection.
org.geotools.data.jdbc.ConnectionPool$ConnectionListManager connectionClosed
FINE: Connection closed - adding to available connections.
4 ¾.¤. 2549 12va:520)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 98 more
and after I clicked save on geoserver I got exception like this
4 ¾.¤. 2549 12:08:37 org.geotools.styling.SLDParser parseExternalGraphic
FINE: Looks like grass_fill.png is a relative path..
4 ¾.¤. 2549 12:08:37 org.geotools.styling.SLDParser parsePointPlacement
FINE: setting anchorPoint org.geotools.styling.AnchorPointImpl@anonymised.com
FINE: seat
  at sun.reflect.GeneratedMethodAccessor174.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at
org.apache.commons.beanutils.PropertyUtils.setSimpleProperty(PropertyUtils.java:1789)
  at
org.apache.commons.beanutils.PropertyUtils.setNestedProperty(PropertyUtils.java:1684)
  at
org.apache.commons.beanutils.PropertyUtils.setProperty(PropertyUtils.java:1713)
  at org.apache.commons.beanutils.BeanUtils.setProperty(BeanUtils.java:1019)
  at org.apache.commons.beanutils.BeanUtils.populate(BeanUtils.java:808)
  at org.apache.struts.util.RequestUtils.populate(RequestUtils.java:1252)
  at
org.apache.struts.action.RequestProcessor.processPopulate(RequestProcessor.java:821)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:254)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 53 more
4 ¾.¤. 2549 12:05:12 org.vfny.geoserver.action.data.TypesEditorAction sync
FINE: config schema atts is null
and
4 ¾.¤. 2549 12:08:37 org.vfny.geoserver.global.DataStoreInfo getDataStore
FINE: connection established by DataStoreConfig[namespace=thai,
enabled=true, abstract=null, connection
parameters={namespace=http://localhost:8080/geoserver/wfs,
url=file:/C:/Program Files/Apache Software Foundation/Tomcat
5.0/webapps/geoserver/data/demo2/popup_map/thai/index_thailand_central.shp}]
4 ¾.¤. 2549 12:08:37 org.vfny.geoserver.global.Data loadFeatureTypes
FINE: loading datastore index_thailand_central
parametersNestedProperty(PropertyUtils.java:1684)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 53 more
4 ¾.¤. 2549 12:08:36 org.vfny.geoserver.global.xml.XMLConfigWriter store
FINE: In method store DataDTO
regards,
worr
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4223224
I'm got exception.
schemaBase null]
Excuse me, but this refers to CW_EMP_INDUST_C01, not CW_EMP_INDUST_C02... I was under the impression CW_EMP_INDUST_C02 was the view you were unable to see.
Try to keep the symbolization as simple as possible (using default_line, default_polygon, etc. styles), in order to minimize possible sources of errors.
<cut/>
Is this the datastore to which CW_EMP_INDUST_C02 belongs ?
    Luca Morandini
I'm got exception.
schemaBase null]
Sorry.CW_EMP_INDUST_C02 and CW_EMP_INDUST_C01 are the same sql script both
display incorrected.
errors.
Default polygon display conrrectly.But my sld displayed incorrect(don't
display anything) when I create first view it display correct but another
view don't dispaly anything.
<cut/>
Oracle same as other.
worr.
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4226719
Have you tried to display both FeatureTypes (the ones from Oracle views) with default_polygon as style ?
    Luca Morandini
Yes,both feature display can display with default_polygon.But when I use my
style ones display correct but other not display.
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4234132
Well, probably this is not a problem related to the DataStore.
Could you post the output of WFS DescribeFeature for both FeatureTypes ?
    Luca Morandini
This FeatureType can display.
<?xml version="1.0" encoding="UTF-8" ?>
- <xs:schema targetNamespace="http://localhost:8080/geoserver/wfs&quot;
xmlns:thai="http://localhost:8080/geoserver/wfs&quot;
xmlns:gml="http://www.opengis.net/gml&quot;
xmlns:xs="http://www.w3.org/2001/XMLSchema&quot; elementFormDefault="qualified"
attributeFormDefault="unqualified" version="1.0">
  <xs:import namespace="http://www.opengis.net/gml&quot;
schemaLocation="http://localhost:8080/geoserver/schemas/gml/2.1.2/feature.xsd&quot;
- <xs:complexType xmlns:xs="http://www.w3.org/2001/XMLSchema&quot;
name="CW_SALE_INDUST_C01_Type">
- <xs:complexContent>
- <xs:extension base="gml:AbstractFeatureType">
- <xs:sequence>
  <xs:element name="DATA" minOccurs="0" nillable="true" type="xs:decimal" />
  <xs:element name="PROV_NAME" minOccurs="0" nillable="true"
type="xs:string" />
  <xs:element name="VALUE" minOccurs="0" nillable="true" type="xs:string" />
  <xs:element name="GEOM" minOccurs="0" nillable="true"
type="gml:GeometryAssociationType" />
  </xs:sequence>
  </xs:extension>
  </xs:complexContent>
  </xs:complexType>
  <xs:element name="CW_SALE_INDUST_C01" type="thai:CW_SALE_INDUST_C01_Type"
substitutionGroup="gml:_Feature" />
  </xs:schema>
and this FeatureType can not display.
name="CW_EMP_INDUST_C01_Type">
- <xs:sequence>
type="xs:string" />
  <xs:element name="CLUSTNAME" minOccurs="0" nillable="true"
type="xs:string" />
  </xs:sequence>
  </xs:extension>
  </xs:complexType>
  <xs:element name="CW_EMP_INDUST_C01" type="thai:CW_EMP_INDUST_C01_Type"
  </xs:schema>
both created by same sql.
Look like both DescribeFeature are the same.
worr.
View this message in context: http://www.nabble.com/problem-with-view-on-oracle-t1548304.html#a4275784
