[Geoserver-users] Problem with WFS addFeatures
Hi, We’re working with Geoserver 1.7.3 and Geotools 2.5.5.
We are trying to insert features in a Geoserver layer trough WFS transactions (like says at http://docs.codehaus.org/display/GEOTDOC/07+FeatureStore) but We have the next exception:
org.geotools.data.DataSourceException: Exception Report Could not determine geoserver request
from http request org.apache.catalina.connector.RequestFacade@anonymised.com Exception Code:MissingParameterValue Locator: request
executing this code:
public static void addFeatures(String layer, List<Map<String, Object>> featAttribs) {
Transaction insert = new DefaultTransaction(“insert”);
map = new HashMap();
map.put(WFSDataStoreFactory.URL.key, geoServerConfig.getWFSServerUrl());
map.put(WFSDataStoreFactory.TIMEOUT.key, new Integer(10000));
wfsDataStore = (new WFSDataStoreFactory()).createDataStore(map);
featStore = (FeatureStore<SimpleFeatureType, SimpleFeature>) wfsDataStore.getFeatureSource( layer );
featStore.setTransaction(insert);
featBuilder = new SimpleFeatureBuilder(featStore.getSchema());
collection = FeatureCollections.newCollection();
for(Map<String, Object> featAttribsMap : featAttribs){
for(String key : featAttribsMap.keySet()){
featBuilder.set(key, featAttribsMap.get(key));
//null para que genere un id por defecto
feat = featBuilder.buildFeature(null);
collection.add(feat);
featStore.addFeatures( collection );
insert.commit();
Any advice please? (Thank you very much, this is my presentation message!)
What is the value of geoServerConfig.getWFSServerUrl()?
My guess is that it is incomplete, and does not include the "&request=GetCapabilities" parameter. Just a guess based on the error, and i tried a quick test using your code and when i left it off I indeed replicated the error message.
-Justin
Juan Manuel Sánchez Martagón wrote:
Hi, We're working with Geoserver 1.7.3 and Geotools 2.5.5.
  Transaction insert = new DefaultTransaction("insert");
                       map = new HashMap(); map.put(WFSDataStoreFactory.URL.key, geoServerConfig.getWFSServerUrl());
                       wfsDataStore = (new WFSDataStoreFactory()).createDataStore(map); featStore = (FeatureStore<SimpleFeatureType, SimpleFeature>) wfsDataStore.getFeatureSource( layer );
            featBuilder = new SimpleFeatureBuilder(featStore.getSchema()); collection = FeatureCollections.newCollection();
                    featBuilder.set(key, featAttribsMap.get(key)); }
            insert.commit();
OpenSolaris 2009.06 is a cutting edge operating system for enterprises looking to deploy the next generation of Solaris that includes the latest innovations from Sun and the OpenSource community. Download a copy and enjoy capabilities such as Networking, Storage and Virtualization. Go to: http://p.sf.net/sfu/opensolaris-get
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin, I have found that debugging SchemaFactory class, we obtain a null schena
private synchronized Schema getRealInstance(URI targetNamespace) {
Schema r = (Schema) schemas.get(targetNamespace); // r is null
so WFSTransactionComplexTypes.encode return a NullException
public void encode(Element element, Object value, PrintHandler output, Map hints) throws IOException, OperationNotSupportedException {
Schema schema = SchemaFactory.getInstance( name.getNamespaceURI() ); //schema is null
Element els = schema.getElements(); //NullException
Is there any problem with the tagetNameSpace URI? It works registering the URI with next code, before making the commit.
URI uri = new URI(store.getSchema().getName().getNamespaceURI());
Schema schema = SchemaFactory.getInstance(uri ,uri, Level.FINE );
insert.commit();
PD: I think that you could invoke this method
instead of:
at
WFSTransactionComplexTypes.encode;
Excuse my English,
Thank you very much
El 9 de junio de 2009 8:16, Juan Manuel Sánchez Martagón <peruxho@anonymised.com> escribió:
Hi, you are absolutely right, I realized yesterday that problem but I had to put the attribute ’ version=1.0.0’
to get the class instance of WFSFactoryStore and now I have another problem and the jvm throw this Exception in line ‘insert.commit();’.
java.lang.NullPointerException
at org.geotools.xml.wfs.WFSTransactionComplexTypes$InsertElementType.encode(WFSTransactionComplexTypes.java:922)
at org.geotools.xml.wfs.WFSTransactionComplexTypes$TransactionType.encode(WFSTransactionComplexTypes.java:306)
at org.geotools.xml.DocumentWriter.writeFragment(DocumentWriter.java:316)
Excuse my English,
Thank you very much
El 9 de junio de 2009 5:50, Justin Deoliveira <jdeolive@anonymised.com> escribió:
My guess is that it is incomplete, and does not include the “&request=GetCapabilities” parameter. Just a guess based on the error, and i tried a quick test using your code and when i left it off I indeed replicated the error message.
-Justin
from http request org.apache.catalina.connector.RequestFacade@anonymised.com…2453… Exception Code:MissingParameterValue Locator: request
insert.commit();
Justin Deoliveira
Hi, I was able to replicate the issue, and I beleive the problem lies in the WFS_1_0_0_DataStore, lines 345-355:
try {
   URL url = protocolHandler.getDescribeFeatureTypeURLGet(typeName);
   if (url != null) {
     SimpleFeatureTypeBuilder build = new SimpleFeatureTypeBuilder();
     build.init(featureType);
     build.setNamespaceURI(url.toURI());
     featureType = build.buildFeatureType();
} catch (URISyntaxException e) {
    throw (RuntimeException) new RuntimeException(e);
Gabriel: This logic seems wrong, it sets the namespce URI to the describefeaturetype request url?
For what it's worth commenting out that entire block makes things work.
-Justin
            Schema r = (Schema) schemas.get(targetNamespace); // r is *null*
    //*schema is null*
    insert.commit();
         instead of:
             SchemaFactory.getInstance( name.getNamespaceURI() ); at
    Excuse my English,
    *Thank you very much*
        but I had to put the attribute ' version=1.0.0'
        'insert.commit();'.
        /java.lang.NullPointerException/
        / at
        org.geotools.xml.wfs.WFSTransactionComplexTypes$InsertElementType.encode(WFSTransactionComplexTypes.java:922)/
        / at
        org.geotools.xml.wfs.WFSTransactionComplexTypes$TransactionType.encode(WFSTransactionComplexTypes.java:306)/
        / at
        org.geotools.xml.DocumentWriter.writeFragment(DocumentWriter.java:316)/
        Excuse my English,
        <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> escribió:
            -Justin
                     from http request
                Integer(10000));
                                     wfsDataStore = (new
                           featBuilder = new
                featAttribs){
                           insert.commit();
                <mailto:Geoserver-users@lists.sourceforge.net>
            -- Justin Deoliveira
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing server and web deployment.
http://p.sf.net/sfu/businessobjects
Justin Deoliveira
try {
  if (url != null) {
I doubt that logic is new but standing on since gt-2.2 but I may be certainly wrong. It looks to me like a clear missconception 'cause what the DescribeFT URL is is the schemaLocation URL...
so if commenting out the whole block just works go for it and commit, I don't think the 1.0 DS cares about the actual namespace actually...
Gabriel
-Justin
    //*schema is null*
    insert.commit();
         instead of:
    Excuse my English,
        'insert.commit();'.
        / at
        / at
        / at
        Excuse my English,
            -Justin
                     from http request
                Integer(10000));
                                     wfsDataStore = (new
                           featBuilder = new
                featAttribs){
                           insert.commit();
Gabriel Roldan
Hi, First of all I have to say that I use Geotools and Geoserver a week ago and I may be wrong in my approach.
buscar
I’ve been debugged these lines (345-355) and I think the problem may be to record the URI of
targetNamespace (“http://127.0.0.1:8081/geoserver”)
and not
http://127.0.0.1:8081/geoserver/wfs?request=DescribeFeatureType&SERVICE=WFS&VERSION=1.0.0&TYPENAME=dap:PG_RECURSOS.
Then when prompted for the Scheme by SchemaFactory.getRealInstance(URI targetNamespace) is null because when it is invoke with other uri (http://127.0.0.1:8081/geoserver/wfs?request=DescribeFeatureType&SERVICE=WFS&VERSION=1.0.0&TYPENAME=dap:PG_RECURSOS. ).
I think there are two problems:
  1. You must register in SchemeFactory what you ask.
  2. You can avoid NullException using this method SchemaFactory.getInstance(uri ,uri, Level.FINE );
PD: I try with WFS_1_1_0_DataStore but throw UnsupportedOperationException in :
public FeatureWriter<SimpleFeatureType, SimpleFeature> getFeatureWriter(String typeName, Filter filter, Transaction transaction)
Excuse my English,
Thank you very much
try {
if (url != null) {
I doubt that logic is new but standing on since gt-2.2 but I may be certainly wrong. It looks to me like a clear missconception 'cause what the DescribeFT URL is is the schemaLocation URL…
so if commenting out the whole block just works go for it and commit, I don’t think the 1.0 DS cares about the actual namespace actually…
Gabriel
For what it’s worth commenting out that entire block makes things work.
-Justin
//schema is null
insert.commit();
instead of:
Excuse my English,
Thank you very much
<peruxho@anonymised.com…84… mailto:[peruxho@anonymised.com](mailto:peruxho@anonymised.com)> escribió:
‘insert.commit();’.
/ at
/ at
/ at
Excuse my English,
Thank you very much
<jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> escribió:
-Justin
from http request
Integer(10000));
wfsDataStore = (new
featBuilder = new
featAttribs){
insert.commit();
mailto:[Geoserver-users@anonymised.come.net](mailto:Geoserver-users@lists.sourceforge.net)
– Justin Deoliveira
Gabriel Roldan
