[Geoserver-users] Problem with WMS virtual service
Dear all,
I have a problem with virtual services (geoserver 2.6.0):
If I use: http://<GEOSERVER_URL>/<workspace>/wfs?request=GetCapabilities I correctly see only the layers within the selected workspace
otherwise if I do http://<GEOSERVER_URL>/<workspace>/wms?request=GetCapabilities I see all the layers.
I try with enable/disable "global services" but do not change nothing...
Any idea about error?
Thanks in advanced,
Roberto
Eng. Roberto Marzocchi, PhD
R&D coordinator
Gter srl Innovazione in Geomatica, Gnss e Gis
Spin-off Progetto Uni.T.I. promoted by UNIGE
Via Greto di Cornigliano 6r - 16152 Genova
P.IVA/CF 01998770992
ph: 010-8694830 Fax: 010-8694737
mob: 349-8786575
E-mail: roberto.marzocchi@anonymised.com
skype: roberto.marzocchi84
www.gter.it
Gter social
www.twitter.com/Gteronline - www.facebook.com/Gteronline - https://plus.google.com/+GterIt/posts
www.linkedin.com/company/gter-srl-innovazione-in-geomatica-gnss-e-gis
Please consider the environment before printing this email!
On Tue, Feb 17, 2015 at 11:31 AM, Roberto Marzocchi <
roberto.marzocchi@anonymised.com> wrote:
Dear all,
otherwise if I do
the layers.
None, but please test the last releases, 2.6.0 is a few months old and the
issue
might have been fixed in the meantime. At the very least try 2.6.2, best if
you can
test 2.7-beta too.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Dear all,
we try with geoserver 2.6.2 (we are in a production environment, e do not like to use not stable version), but do not change the behaviour.
Virtual service do not works for WMS layers, only for WFS
Any suggestions?
R
Il 17/02/2015 12:17, Andrea Aime ha scritto:
On Tue, Feb 17, 2015 at 11:31 AM, Roberto Marzocchi <roberto.marzocchi@anonymised.com> wrote:
Dear all,
If I use: http://<GEOSERVER_URL>//wfs?request=GetCapabilities
otherwise if I do
http://<GEOSERVER_URL>//wms?request=GetCapabilities I see all
the layers.
I try with enable/disable “global services” but do not change nothing…
None, but please test the last releases, 2.6.0 is a few months old and the issue
might have been fixed in the meantime. At the very least try 2.6.2, best if you can
test 2.7-beta too.
Ing. Andrea Aime
@geowolf
Technical Lead
R&D coordinator
mob: 349-8786575
E-mail: [roberto.marzocchi@anonymised.com](mailto:roberto.marzocchi@anonymised.com)
[www.gter.it](http://www.gter.it)
Gter social
[www.twitter.com/Gteronline](http://www.twitter.com/Gteronline) - [www.facebook.com/Gteronline](http://www.facebook.com/Gteronline) - [https://plus.google.com/+GterIt/posts](https://plus.google.com/+GterIt/posts)
[www.linkedin.com/company/gter-srl-innovazione-in-geomatica-gnss-e-gis](http://www.linkedin.com/company/gter-srl-innovazione-in-geomatica-gnss-e-gis)
On Mon, Feb 23, 2015 at 9:51 AM, Roberto Marzocchi <
Dear all,
It would seem it is something specific to your setup, I've just tried with
a standard GeoServer 2.6.2 and using:
http://localhost:8080/geoserver/sf/wms?service=wms&request=GetCapabilities
http://localhost:8080/geoserver/topp/wms?service=wms&request=GetCapabilities
I only get back layers in the respective workspaces.
To help you we first need to understand what makes your installation
different.
Is it happening only with particular workspaces for example? Did you change
anything in the
wms configuration or security subsystem?
Ing. Andrea Aime
@geowolf
Technical Lead
Many thanks Andrea!
With “sf” and “topp” workspaces it works, but we encountered the problem with a workspace that we have defined, but the workspace options are the same. Cheers, Roberto
Il 23/02/2015 10:03, Andrea Aime ha scritto:
On Mon, Feb 23, 2015 at 9:51 AM, Roberto Marzocchi <roberto.marzocchi@anonymised.com> wrote:
Dear all,
It would seem it is something specific to your setup, I’ve just tried with a standard GeoServer 2.6.2 and using:
To help you we first need to understand what makes your installation different.
Is it happening only with particular workspaces for example? Did you change anything in the
Ing. Andrea Aime
@geowolf
Technical Lead
R&D coordinator
mob: 349-8786575
Gter social
Many thanks Andrea!
Dear all,
Ing. Andrea Aime
@geowolf
Technical Lead
R&D coordinator
mob: 349-8786575
Gter social
On Mon, Feb 23, 2015 at 10:23 AM, Roberto Marzocchi <
With "sf" and "topp" workspaces it works, but we encountered the problem
same.
I've just tried creating a new workspace "test" with a single store and
layer in it, the caps for it only list that layer,
plus the global layer groups (which is normal).
So... not sure what's going on in your case. Maybe shows us the list of
layers, the workspace definition, and the urls you're using.
Ing. Andrea Aime
@geowolf
Technical Lead
Yes, I’ve found the problem. The layer group do not have a workspace defined… If I assign a workspace I see only the layer of my workspace. It is not a problem of getCapabilities service, but only of the group configuration! Tanks! Cheers, R
Il 23/02/2015 10:30, Andrea Aime ha scritto:
On Mon, Feb 23, 2015 at 10:23 AM, Roberto Marzocchi <roberto.marzocchi@anonymised.com> wrote:
I’ve just tried creating a new workspace “test” with a single store and layer in it, the caps for it only list that layer,
So… not sure what’s going on in your case. Maybe shows us the list of layers, the workspace definition, and the urls you’re using.
Ing. Andrea Aime
@geowolf
Technical Lead
R&D coordinator
mob: 349-8786575
Gter social
