[Geoserver-users] Problem with YSLD ColorMapEntry from YAML file.
Dear List,
We are using Geoserver REST API to upload and attach yaml style files to layers. A sample yaml file looks like this:
title: Test Style title
abstract: Styling of Test layer
feature-styles:
  • rules:
  • title: raster
    symbolizers:
  • raster:
    opacity: 1.0
    color-map:
    type: values
    entries:
  • [‘#e20374’, 1.0, 1, Lorem Ipsum (magenta = covered)]
We use the following curl commands to upload the style:
Creating Style
curl -u “$credentials” -XPOST -H “Content-type: text/xml” -d “$style_nameysld$style_name.yaml1.0.0” http://host:8081/geoserver/rest/workspaces/$workspace_name/styles
Update the style with uploaded style info
curl -u $credentials -XPUT -H “Content-type: application/vnd.geoserver.ysld+yaml” --data-binary @$style_name.yaml http:// host:8081/geoserver/rest/workspaces/$workspace_name/styles/$style_name
Check result:
curl -u $credentials -XGET http:// host:8081/geoserver/rest/workspaces/$workspace_name/styles/$style_name.sld?pretty=true
<sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:sld=“http://www.opengis.net/sld” xmlns:gml=“http://www.opengis.net/gml” xmlns:ogc=“http://www.opengis.net/ogc” version=“1.0.0”>
sld:NamedLayer
sld:Nametest</sld:Name>
sld:UserStyle
sld:NameTest</sld:Name>
sld:TitleTest Style</sld:Title>
sld:AbstractStyling abstract desc.</sld:Abstract>
sld:FeatureTypeStyle
sld:Rule
sld:Titleraster</sld:Title>
sld:RasterSymbolizer
<sld:ColorMap type=“values”>
<sld:ColorMapEntry color=“java.awt.Color[r=226,g=3,b=116]” opacity=“1.0” quantity=“1” label=“lorem ipsum (magenta = covered)”/>
</sld:ColorMapEntry>
sld:ContrastEnhancement/
</sld:RasterSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
As can be seen, #e20374 is converted to java.awt.Color instead of the same ‘#e20374’ literal. When I manually edit the yaml file in geoserver (i.e replace java.awt.Color[r=226,g=3,b=116] with #e20374) , I get the correct styling.
However, if I use the the java color ( java.awt.Color[r=226,g=3,b=116]****), I get the following error
It seems that something goes wrong during conversion. Does anyone know the cause of this problem?
Moses
Hi Moses,
this is most likely a minor bug in the YSLD to SLD conversion.
SLD parser will not chew a Java color.
On Wed, Mar 15, 2017 at 11:03 AM, <Moses.Gone@anonymised.com> wrote:
Dear List,
feature-styles:
  • rules:
  • title: raster
    symbolizers:
  • raster:
    opacity: 1.0
    color-map:
    type: values
    entries:
Creating Style
Check result:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Moses
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Hi Simone,
Thanks a lot, I have raised an issue on this: https://osgeo-org.atlassian.net/browse/GEOS-8034?filter=-4
Moses
From: Simone Giannecchini [mailto:simone.giannecchini@…1107…]
Sent: Mittwoch, 15. März 2017 12:47
To: Gone, Moses
Cc: geoserver-users
Subject: Re: [Geoserver-users] Problem with YSLD ColorMapEntry from YAML file.
Hi Moses,
Simone Giannecchini
@simogeo
Founder/Director
On Wed, Mar 15, 2017 at 11:03 AM, <Moses.Gone@…3945…> wrote:
Dear List,
feature-styles:
  • rules:
  • title: raster
symbolizers:
  • raster:
opacity: 1.0
color-map:
type: values
entries:
Creating Style
Check result:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
However, if I use the the java color ( java.awt.Color[r=226,g=3,b=116]), I get the following error
Moses
Thanks, I have updated the formatting.
I had a look here and it kind of agreed with your email, let’s move discussion to the bug report.
String yaml =
“raster: \n” +
" color-map:\n" +
" type: values\n" +
" entries:\n" +
" - “+tuple(”#ff0000", “1.0”, “0”, “start”)+“\n” +
" - “+tuple(”#00ff00", “1.0”, “500”, “middle”)+“\n” +
" - “+tuple(”#0000ff", “1.0”, “1000”, “end”)+“\n” +
On 15 March 2017 at 08:21, <Moses.Gone@anonymised.com> wrote:
Hi Simone,
Moses
From: Simone Giannecchini [mailto:simone.giannecchini@geo-solutions.it]
To: Gone, Moses
Cc: geoserver-users
Hi Moses,
Simone Giannecchini
@simogeo
Founder/Director
Dear List,
feature-styles:
  • rules:
  • title: raster
symbolizers:
  • raster:
opacity: 1.0
color-map:
type: values
entries:
Creating Style
Check result:
sld:NamedLayer
sld:UserStyle
sld:Rule
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Moses
Geoserver-users@anonymised.comsourceforge.net
Jody Garnett
