[Geoserver-users] Problems creating a Geoserver Layer on a PostGIS View
I made a short test with GS 2.0-pre-release with these objects:
CREATE TABLE viewtest
“GEOMETRY” geometry(PointZ,3067),
attribute character varying
INSERT INTO viewtest (“GEOMETRY”, attribute)
VALUES ( ST_GeomFromText(‘POINTZ (640079 7002754 100)’,3067), ‘feature_1’);
CREATE MATERIALIZED VIEW view_viewtest
AS SELECT viewtest.“GEOMETRY”::GEOMETRY(PointZ,3067) AS geometry, attribute
from viewtest;
CREATE VIEW view_viewtest_2
from viewtest;
I could publish the table and the normal view fine, the admin utility shows geometry type as point and layer preview with OpenLayers is fine.
I could not publish the materialized view at all because it does not appear in the list of available layers when I open my PostGIS store.
There is a corresponding row in the geometry_columns
“gis9”;“public”;“view_viewtest”;“geometry”;3;3067;“POINT”
This makes me think that there is perhaps something that does not quite work with materialized views.
I have two suggestions:
  1. Have a try with a plain, non-materialized view.
  2. Consider if you could do the same as I did above and send complete SQL commands for reproducing test data and the issue. It would have a few good points:
a. It makes you to make another test with most simple schema and data and verify that issue does not come from the source data
b. It makes it possible for the reviewers to make an exact copy of your case
c. If it is fast and easy, more people may really make a test for helping you
This is something that I have not yet discussed with Geoserver developers but I have been reading a few hundred open tickets during past two months and found that the ones with SQL are quite nice to study. Perhaps we could write some Best Practice document about how to report about issues which are dealing with databases.
-Jukka Rahkonen-
Andrea Aime wrote:
On Mon, Mar 23, 2015 at 11:52 AM, dkuenzel <audiotecture@…157…> wrote:
Hi Stefano,
thanks for your reply.
The only difference between the two screenshots is the symbol at the
beginning of the line. The Original layer shows a point symbol while the
view shows a rectangle (polygon?), the weird thing is, that both layers
contain exactly the same type of data (the view is a subset).
Geoserver itself doesn’t give any error, but I can’t display the WFS in
Qgis. The Attribute table then shows all the features but there are no
objects shown on the map.
To add some more confusion: it is possible to preview the layer in the
Geoserver UI (Openlayers) but if I try to add it to my own openlayers map
there won’t be any objects on the map.
I suppose it might be a problem with Geoserver computing the Geometry from
the view correctly and sending it via WFS but I don’t see any reason why
that should be the case. The only difference between the original table and
the view is that symbol I mentioned at the beginning.
Did you ask GeoServer to try and figure out the geometry type and srid when
listing the sql view attributes?
Even in case GeoServer does not recognize them correctly, you can manually
fix them
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Mar 23, 2015 at 1:36 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
  "GEOMETRY" geometry(PointZ,3067),
INSERT INTO viewtest ("GEOMETRY", attribute)
  VALUES ( ST_GeomFromText('POINTZ (640079 7002754 100)',3067),
'feature_1');
AS SELECT viewtest."GEOMETRY"::GEOMETRY(PointZ,3067) AS geometry, attribute
from viewtest;
from viewtest;
"gis9";"public";"view_viewtest";"geometry";3;3067;"POINT"
Know issue: http://jira.codehaus.org/browse/GEOT-4635 , we have the code
fixes, but we still need to upgrade
the postgresql driver to complete the work, up until recently we could not
due to a bug in the postgresql driver
itself, right now it's only a matter of giving up a test that does not pass
anymore due to a change in behavior
in the latest version of the driver (in which the other bigger problem has
been solved).
We'll have the upgrade going for 2.8.0, not sure if we are going to
backport to 2.7.x (the 300+ tests
we have showed us two changes in behavior, there might be more that our
tests are not covering...
so I'd be cautious about an upgrade).
And oh, that said, you can manually remove the old postgresql driver from
web-in/lib and add the
latest one as a replacement, that should work fine, we have made no changes
in the actual
code to support the new driver, we'll only have to disable one test.
1) Have a try with a plain, non-materialized view.
2) Consider if you could do the same as I did above and send
your case
helping you
Yep, summarizing your experience in the bug tracker in a guide for people
reporting issues would certainly be quite valuable
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Andrea,
the description from Jukka Rahkonen doesn't fit my problem because I am able
to publish the materialized view. I am running Geoserver V 2.6.0. But thanks
for the notice that there might be something wrong with the materialized
view. At the Moment it is not possible to work with a normal view instead
because it would impair the performance a lot.
I think I will just have to wait for the driver to be reworked to see if it
works then. In the meantime I will try to work around the problem with
direct DB-Interface instead and wait for the new Geoserver Version.
Thanks for your help anyways. :wink:
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-creating-a-Geoserver-Layer-on-a-PostGIS-View-tp5194895p5195401.html
On Wed, Mar 25, 2015 at 4:02 PM, dkuenzel <audiotecture@anonymised.com> wrote:
Hey Andrea,
able
thanks
You can just pick the latest postgresql jdbc driver and replace the old one
in the GeoServer own WEB-INF/lib, it should work fine
Ing. Andrea Aime
@geowolf
Technical Lead
