Why to wait for a proper fix if there is a simple workaround ? Create a normal view on top of your materialized view and publish that with Geoserver. I tested that it works and it must be just as fast as direct connection to the materialized view.
-Jukka Rahkonen-
dkuenzel wrote:
Hey Andrea,
the description from Jukka Rahkonen doesn't fit my problem because I am able to publish the materialized view. I am running Geoserver V 2.6.0. But thanks for the notice that there might be something wrong with the materialized view. At the Moment it is not possible to work with a normal view instead because it would impair the performance a lot.
I think I will just have to wait for the driver to be reworked to see if it works then. In the meantime I will try to work around the problem with direct DB-Interface instead and wait for the new Geoserver Version.
Thanks for your help anyways.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-creating-a-Geoserver-Layer-on-a-PostGIS-View-tp5194895p5195401.html
Dive into the World of Parallel Programming The Go Parallel Website, sponsored by Intel and developed in partnership with Slashdot Media, is your hub for all things parallel software development, from weekly thought leadership blogs to news, videos, case studies, tutorials and more. Take a look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
