[Geoserver-users] Problems creating a new H2 datastore (v 2.3.1)
I’m trying to figure out how to create a new H2 datastore to store from vectors to be served out through WFS.
I’ve gone to Add New Store (H2 Embedded)
I put in a Data Source Name, however, I’m not sure what to put in for any of the connection parameters. I always receive this error with the defaults:
Error creating data store, check the parameters. Error message: Unable to obtain connection: Cannot create PoolableConnectionFactory (Connection is broken [90067-119])
Since this is an embedded H2 instance, what would the connection parameters be?
Please CC directly as well.
Thanks.
– James
Hey James,
There is an issue with the default parameters, the way they are set up the connection tries to set up a TCP connection, rather than a direct connection. You can simply remove the “host” parameter and it should work.
If you want to file a bug report in jira i’ll fix the default parameters.
-Justin
On Wed, Apr 24, 2013 at 3:34 PM, James Lamanna <jlamanna@anonymised.com> wrote:
Thanks.
– James
Try New Relic Now & We’ll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_apr
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
