[Geoserver-users] Problems deploying Geoserver WAR
I deleted the servlet api from the WEB-INF/lib and it has now got past this point in the deployment but, it now has a new error;
INFO: Deploying web application archive geoserver.war
Sep 27, 2010 8:42:14 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Any ideas on how to address this problem?
Thanks for your help
Justin Deoliveira 09/27/10 2:59 PM >>>
I did not think geoserver was supposed to ship with a servlet api jar...
maybe i am wrong. You can simply try to remove it from WEB-INF/lib since
those libs are provided via the servlet container.
On Mon, Sep 27, 2010 at 6:36 AM, Steven Reid wrote:
I have being running Geoserver 2.02 and Tomcat version 6.0.28 successfully
on my local machine, but have recently installed the applications on a
server, Tomcat seems to be working fine, but when it tries to deploy the
Geoserver WAR file it states the following error in the log file:
appservers\apache-tomcat-6x\webapps\geoserver\WEB-INF\lib\servlet-api-2.4.jar)
- jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class:
javax/servlet/Servlet.class
Does anyone have any ideas how to fix it?
cheers
Steve
________________________________________________________________________
Please consider the environment before printing this e-mail
MVA Consultancy Limited is a limited liability Company registered in
England and Wales, registration number: 3383212, registered address: First
Floor, Dukes Court, Duke Street, Woking, Surrey, GU21 5BH, United Kingdom.
The information transmitted in this e-mail and any attached files is
intended only for the person or entity to which it is addressed and may
contain confidential and/or privileged material. Any opinions expressed in
the e-mail are those of the individual and not necessarily the Company. Any
review, retransmission, dissemination or other use of or taking of any
action in reliance upon, this information by persons or entities other than
the intended recipient is prohibited. If you received this in error you
should not copy it,
disclose its contents to anyone else or take any action based on it, please
contact the sender and delete the material from any computer.
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
This e-mail has been scanned for all viruses by Star. The
service is powered by MessageLabs. For more information on a proactive
anti-virus service working around the clock, around the globe, visit:
http://www.star.net.uk
MVA Consultancy Limited is a limited liability Company registered in England and Wales, registration number: 3383212, registered address: First Floor, Dukes Court, Duke Street, Woking, Surrey, GU21 5BH, United Kingdom.
The information transmitted in this e-mail and any attached files is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any opinions expressed in the e-mail are those of the individual and not necessarily the Company. Any review, retransmission, dissemination or other use of or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error you should not copy it,
disclose its contents to anyone else or take any action based on it, please contact the sender and delete the material from any computer.
It is a warning so you can ignore it (unless you planned on using the
GDAL extension - in which case install that extension).
Ian
