On Wed, Oct 8, 2014 at 7:17 PM, Erik Näsström <erik.nasstrom@anonymised.com715...>
wrote:
Ah indeed, it seems that CMDBuild that I'm running only can use Java 1.6
so that's the reason I get the problems. Will Geoserver 2.4.8 run on older
java or do I have to go even further back?
The 2.5.x series is the last one supporting java 6, you should probably use
that one, 2.4.x is no longer supported
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
