I'm using the app-schema plugin for realizing a complex feature mapping. I
adapted the tutorial for the app-schema and want my data to be loaded from a
postgis database running on the same machine as the geoserver.
While geoserver is starting, Geoserver shows me an error:
My configuration is the following one:
folderpath inside workspaces-folder in geoserver's data_dir
snm
-namespace.xml
-workspace.xml
-snm_SpellingOfName
--snm_SpellingOfName
---featuretype.xml
--AppSchemaDataAccess.xsd
--datastore.xml
--snm_SpellingOfName.xml
The content of namespace.xml is:
The content of workspace.xml is:
The content of snm/snm_SpellingOfName/snm_SpellingOfName/featuretype.xml is:
The content of snm_SpellingOfName.xml is:
Instead of "XXXX", I have the correct value but for safety motives I've
preferred not putting them.
The file SpellingOfName.xsd is placed into the app-schema-cache folder of
data_dir (app-schema-cache/localhost/snm/SpellingOfName.xsd).
The content of this file is:
I know the problem is the SpellingOfName.xsd file but I don't know the
solution. Can somebody help me?
Thank you
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problems-in-App-Schema-plugin-tp5032014.html
