hello everyone:
I have tried to build GeoServer1.5 under the steps in the doucuments.
first :check out from https://svn.codehaus.org/geoserver/trunk
then :mvn install (the client terminal showed all the moudles were
successfully builded)
mvn eclipse:eclipse;
set the variarable M2_REPO
after import existing projects into the workspace there are server projects
not only one in the workspace,and there are errors like Project Issues is
missing required library: 'C:\Documents and
Settings\Administrator\.m2\repository\antlr\antlr\2.7.6\antlr-2.7.6.jar'
I tried to setup a new project first and then import all the source code but
i got more errors.
I am expecting your help thank you !
View this message in context: http://www.nabble.com/problems-in-building-GeoServer1.5-in-eclipse-tf3610699.html#a10090052
