[Geoserver-users] Problems installing arcSDE extension in geoserver 2.5.1 - icu4j issue??
Just working with a fresh install of geoserver 2.5.1. Put in the arcSDE extension, and also the two sde92.jar files.
Restart. then when I try to add an SDE store, I get the error:
java.lang.NoClassDefFoundError: com/ibm/icu/text/UnicodeDecompressor
which looks like problem with icu4j. However icu4j-3.4.4 is present in the lib. Is there a compatibility issue between this and the arcsde92 jars?
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Should say that is a default installation on window 7, with jetty. I can see from logs that it connects with arcSdE okay - just crashes at some point after that. Have tried icuj default (supplied with the arcsdE plugin), the older 3.2 version that 92 used to use, and the icu4.6 version. All for the same result. jre7
On Mon, Jul 28, 2014 at 4:40 AM, Phil Scadden <p.scadden@anonymised.com> wrote:
I see there is a known incompatibility between java7 and icu4j, but
the error it should cause is different:
http://bugs.icu-project.org/trac/ticket/8734
Maybe try downloading a more recent version:
http://site.icu-project.org/download
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Got it. Switching to the 64bit jre7 did the trick.
On Tue, Jul 29, 2014 at 3:24 AM, Phil Scadden <p.scadden@anonymised.com> wrote:
Hum... weird? Do you have an idea of why it works with it (or why it did not
before?)
Ing. Andrea Aime
@geowolf
Technical Lead
