[Geoserver-users] Problems migrating geoserver data directory: validatejarfile servlet-api-2.5.jar
Hi Simon,
Have you turned up the GeoServer error reporting level to GeoTools Developer Logging (or one of the other non-default/production profiles)? http://docs.geoserver.org/stable/en/user/webadmin/server/globalsettings.html#logging-profile
Also remember that setting may be changed when you load your new directory.
Jonathan
On 29 April 2013 12:53, Simon Johnson <SJohnson@anonymised.com5…> wrote:
Hi list,
I am trying to migrate a data directory from 2.1.2/tomcat6/fedora to 2.3.1/tomcat7/ubuntu. The install works and tests fine, but when I copy in my own data directory geoserver fails to start and tomcat throws the error message at the bottom of this email. I tried with 2.3.0 and 2.2.5 and experienced the same problem. Nothing shows in the geoserver log for the failed start-up. Any suggestions on how to fix?
Thanks
Simon
INFO: Deploying web application archive /var/lib/tomcat7/webapps/geoserver.war
29-Apr-2013 12:19:27 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
29-Apr-2013 12:19:33 org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
SEVERE: Context [/geoserver] startup failed due to previous errors
Refusing to ignore people in crisis
JOIN OUR NETWORK:
This email is for the intended recipient only. It may contain information that is privileged, confidential and/or subject to copyright. If you are not the intended recipient, please delete this email and any attachments immediately. You may not present this message or any part of it to another party without consent from the sender.
Although the British Red Cross has taken steps to ensure this email and any attachments are virus-free, we do not accept any responsibility for viruses, or for inaccurate or incomplete information or failure to deliver information. It is your responsibility to scan the email and any attachments to ensure they are virus-free.
The British Red Cross may monitor the content of emails sent or received by its employees.
The British Red Cross Society, incorporated by Royal Charter 1908, is a charity registered in England and Wales (220949) and Scotland (SC037738).
The red cross emblem is a protective symbol, the use of which is restricted by international and national law. It may not be reproduced without prior authorisation. For more information, about the emblem, please go to www.redcross.org.uk/About-us/Who-we-are/The-international-Movement/The-emblem.
If you need to contact the British Red Cross, please go to www.redcross.org.uk/About-us/Contact-and-help/Contact-us and select the best option for you.
Try New Relic Now & We’ll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_apr
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Mon, Apr 29, 2013 at 1:53 PM, Simon Johnson <SJohnson@anonymised.com>wrote:
  <http://rocketseed.redcross.org.uk/rs/ExFRX.&gt;
Hi list,
Thanks
Simon
*INFO: Deploying web application archive
validateJarFile
INFO:
This one is annoying but innocuous, you can see it on every successful
startup as well.
It's an old issue, we should just stop bundling servlet.jar in the .war
file:
http://jira.codehaus.org/browse/GEOS-4014
*29-Apr-2013 12:19:33 org.apache.catalina.core.StandardContext
startInternal
SEVERE: Context [/geoserver] startup failed due to previous errors*
I believe you configured your GeoServer not to log on the standard output?
I bet geoserver.log contains more useful information, look in your data
directory, logs/geoserver.log
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
