I’m using GeoTools 2.6.1 and GeoServer 2.1.0. For some reason, when I try and access my WMS (located at http://li199-25.members.linode.com:8080/geoserver/) GeoTools throwns a load of errors (shown below). The strange thing is, when I try my local version of GeoServer (also 2.1.0) it works fine. The server is running on Ubuntu 10.10 while my local machine is Windows 7, if that’s relevant.
The Error:
09-Jun-2011 12:31:47 org.geotools.xml.XMLSAXHandler fatalError
SEVERE: FATAL The processing instruction target matching “[xX][mM][lL]” is not allowed.
SEVERE: col 17, line 4716
This is repeated four times. When I try a GetCapabilities requesting using my browser it seems ok.
It has given you a line number; I suspect you should look at your capabilities file and check that line…
(when I look at that capabilities file it is all on one line).
Perhaps you could do a diff between your local capabilities and that produced by the remote service?
Jody Garnett
On Thursday, 9 June 2011 at 9:58 PM, Jon Britton wrote:
The Error:
Any idea what’s happening here?
Jon
EditLive Enterprise is the world’s most technically advanced content
authoring tool. Experience the power of Track Changes, Inline Image
Editing and ensure content is compliant with Accessibility Checking. http://p.sf.net/sfu/ephox-dev2dev
I think I’ve found the problem. I thought it was working using the browser but it isn’t. It returns a partial response ending with:
EPSG:62666405
EPSG:62676405
EPSG:62686405
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
javax.xml.transform.TransformerException: Translator error
Translator error
Error occurred trying to write out metadata for layer: Pk50095
Unable to acquire a reader for this coverage with format: WorldImage
Any ideas? This is a clean GeoServer install, by the way.
Jody Garnett
The Error:
Jon
On Thu, Jun 9, 2011 at 3:56 PM, Jon Britton <jonbritton3@anonymised.com> wrote:
I think I've found the problem. I thought it was working using the browser
but it isn't. It returns a partial response ending with:
<SRS>EPSG:62666405</SRS>
<SRS>EPSG:62676405</SRS>
<SRS>EPSG:62686405</SRS>
<SRS><?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://li199-25.members.linode.com:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
Translator error
</ServiceException></ServiceExceptionReport>
EPSG:62666405
EPSG:62676405
EPSG:62686405
Translator error
EPSG:62666405
EPSG:62676405
EPSG:62686405
Translator error
