Hello,
I’ve been using Geoserver for a project that serves PostGIS data using jsonp Web Feature Service. Recently, my network administrator ran some security updates for Java, and Geoserver broke. We reinstalled Java and Geoserver, and the server now appears to be running–except that it won’t actually serve any of the layers. They do not respond to the ajax call from my website, and if I go to “Layer Preview” and try to preview any of them, I get a 404:
Not Found
The requested URL /geoserver/ows was not found on this server.
Each time I try the preview, it prints this in the log about ten times:
2013-02-14 15:50:27,769 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/gml+xml; version=3.2’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
I’m kind of a noob at programming and don’t know my way around Java at all, so any help anyone could give me at the most basic and understandable level would be much appreciated.
-Carl
Hello Carl,
In my opinion it would be useful to know more about your system: What Operating system? What java version are you using? What GeoServer version are you using? Is it running in a Tomcat/Apache environment? In a jetty environment? The more details you give the higher the chance to get help.
Stefan
Sent: Thursday, February 14, 2013 11:04 PM
Subject: [bulk]: [Geoserver-users] Problems serving data
Hello,
Not Found
-Carl
Hi Carl,
There was a bug with Layer Preview for WFS using the GML3.2 which you seem to be using so it may be the same thing - http://jira.codehaus.org/browse/GEOS-5541
It should be fixed in 2.2.5 it seems.
Jonathan
On 14 February 2013 22:03, Carl Sack <northlandiguana@anonymised.com> wrote:
Hello,
Not Found
-Carl
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013
and get the hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
Geoserver-users mailing list
Geoserver-users@anonymised.comnet
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
