Hi Everyone,
I am trying to get a ArcSDE datastore up and running and seem to be
running into some problems. I am not sure if it has anything to do
with the names of the feature classes, so I thought I would check here
first. I am able to create a new feature class in geoserver, and i am
able to get to it through a WFS connection but a lot of errors are
produced in the log. It does seem to work though. However, I cannot
get anything out of the WMS connection through even the most simple of
SLDs. I thought it might have to do with the styled layer descriptor,
but even the simple "polygon" does not work. The name of the layer is
OMS.OMS.WHO_REG, and I thought that the periods might cause a
problem.
I am using the latest 1.5.4 version with an ArcSDE 9.1 /MS-SQL setup.
I am using the 9.1 jars and the 1.5.4 version extension for geoserver.
Here is a typical snippet from the log when I make a WMS request to output KML.
Thanks for any tips.
Best regards,
Jason
Nov 13, 2007 5:34:00 PM org.vfny.geoserver.servlets.AbstractService doService
INFO: Service handled
Nov 13, 2007 5:34:20 PM
org.vfny.geoserver.wms.requests.GetMapKvpReader
parseOptionalParameters
INFO: Set KMScore: 50
Nov 13, 2007 5:34:20 PM org.vfny.geoserver.servlets.AbstractService doService
INFO: handling request:
GetMap Request
version: 1.1.1
output format: application/vnd.google-earth.kmz XML
width height: 1024,1024
bbox: Env[-50.81813868472601 : 93.77489215952886, -29.96974386011042
: 54.43714880180336]
layers: WHO:OMS.OMS.WHO_REG
styles: OMS.OMS.WHO_REG_style
Nov 13, 2007 5:34:29 PM org.geotools.data.arcsde.ArcSDEQuery getQueryColumns
INFO: No FID attribute was contained in your query. Appending the
discovered one to the list of columns to be fetched.
Nov 13, 2007 5:34:29 PM org.geotools.renderer.lite.StreamingRenderer
processStylers
SEVERE: Wrong number of attributes expected 2 got 3
IllegalAttribute: null , but got null
at org.geotools.feature.DefaultFeature.setAttributes(DefaultFeature.java:263)
at org.geotools.feature.DefaultFeature.<init>(DefaultFeature.java:97)
at org.geotools.feature.DefaultFeatureType.create(DefaultFeatureType.java:171)
at org.geotools.data.crs.ForceCoordinateSystemFeatureReader.next(ForceCoordinateSystemFeatureReader.java:144)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1564)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:715)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:436)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:238)
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:164)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:495)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:592)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
Nov 13, 2007 5:34:30 PM org.geotools.renderer.lite.StreamingRenderer
processStylers
processStylers
