Hi
I’m running into problems with todays trunk version and with an existing data directory which worked with GS 1.7.3.
catalina.out:
WARNUNG: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
26.03.2009 10:39:34 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/geoserver-devel] startup failed due to previous errors
26.03.2009 10:39:35 org.apache.catalina.startup.HostConfig deployWAR
geoserver.log:
2009-03-26 10:39:32,450 WARN [geoserver.confg] - Error occured loading service: wms
2009-03-26 10:39:34,971 WARN [support.DisposableBeanAdapter] - Couldn’t find a destroy method named ‘destroy’ on bean with name ‘gwcDefaultStorageFinder’
2009-03-26 10:39:34,982 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘wmsConfig’ defined in URL [jar:file:/usr/local/apache-tomcat-5.5.25/webapps/geoserver-devel/WEB-INF/lib/wms-1.7.3-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
Any hints why this happens and what the errors exactly mean are appreciated!
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Hi Stefan,
Can you include the entire stack trace from the log. The one below is cut off and we are unable to tell where the error is occurring. Thanks.
-Justin
Ziegler Stefan wrote:
Hi
I'm running into problems with todays trunk version and with an existing data directory which worked with GS 1.7.3.
catalina.out:
geoserver.log:
2009-03-26 10:39:34,971 WARN [support.DisposableBeanAdapter] - Couldn't find a destroy method named 'destroy' on bean with name 'gwcDefaultStorageFinder'
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wmsConfig' defined in URL [jar:file:/usr/local/apache-tomcat-5.5.25/webapps/geoserver-devel/WEB-INF/lib/wms-1.7.3-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
regards
Stefan
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Rötistrasse 4
4501 Solothurn
http://www.so.ch
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
