[Geoserver-users] problems with geoserver trunk and 1.7.3 data directory
sure:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0],UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
2009-03-26 10:39:32,450 WARN [geoserver.confg] - Error occured loading service: wms
2009-03-26 10:39:34,971 WARN [support.DisposableBeanAdapter] - Couldn’t find a destroy method named ‘destroy’ on bean with name ‘gwcDefaultStorageFinder’
2009-03-26 10:39:34,982 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘wmsConfig’ defined in URL [jar:file:/usr/local/apache-tomcat-5.5.25/webapps/geoserver-devel/WEB-INF/lib/wms-1.7.3-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3764)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4216)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:760)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:740)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:544)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:825)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:714)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:120)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1022)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
… 41 more
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.global.Service.toDTO(Service.java:177)
at org.vfny.geoserver.global.WMS.toDTO(WMS.java:285)
at org.vfny.geoserver.config.WMSConfig.(WMSConfig.java:144)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
… 43 more
2009-03-26 10:39:34,984 ERROR [[localhost].[/geoserver-devel]] - Exception sending context initialized event to listener instanceof class org.springframework.web.context.ContextLoaderListener
… 41 more
… 43 more
Stefan
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet am: Donnerstag, 26. März 2009 16:30
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: [Geoserver-users] problems with geoserver trunk and 1.7.3
data directory
Hi Stefan,
Can you include the entire stack trace from the log. The one below is
cut off and we are unable to tell where the error is
occurring. Thanks.
-Justin
Ziegler Stefan wrote:
Hi
I’m running into problems with todays trunk version and
with an existing
data directory which worked with GS 1.7.3.
catalina.out:
WARNUNG: Native library load
failed.java.lang.UnsatisfiedLinkError: no
gdaljni in java.library.path
26.03.2009 10:39:34 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/geoserver-devel] startup failed
due to previous
errors
26.03.2009 10:39:35 org.apache.catalina.startup.HostConfig deployWAR
geoserver.log:
occured loading
service: wms
Error creating
at
at
Factory.java:925)
Any hints why this happens and what the errors exactly mean are
appreciated!
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Is there going to be support added for WKB and spatial indexing with the SQL Server 2008 datasource (or has this already been implemented)? SQL server has the .STAsBinary ( ) function call on the geometry type. We have been running into serious scalability problems with large vector datasets with geoserver and am wondering if it has do with the lack of the datasources ability to utilize WKB and spatial indexes?
Rob
Hi Stephan,
So you say you are running on trunk? I guess you are running the legacy module? Unfortunately the old web module on trunk right now is pretty much broken... and only functions read only.
I just started up the legacy web module on trunk and it started up ok. But after shutting down and starting up again it does not start up properly. I will look into it a bit deeper.
-Justin
sure:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0],UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2009-03-26 10:39:34,971 WARN [support.DisposableBeanAdapter] - Couldn't find a destroy method named 'destroy' on bean with name 'gwcDefaultStorageFinder'
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wmsConfig' defined in URL [jar:file:/usr/local/apache-tomcat-5.5.25/webapps/geoserver-devel/WEB-INF/lib/wms-1.7.3-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.WMSConfig]: Constructor threw exception; nested exception is java.lang.NullPointerException
... 41 more
at org.vfny.geoserver.config.WMSConfig.<init>(WMSConfig.java:144)
... 43 more
... 41 more
... 43 more
Stefan
An: Ziegler Stefan
Cc: geoserver-users
data directory
Hi Stefan,
occurring. Thanks.
-Justin
> Hi
> I'm running into problems with todays trunk version and
with an existing
> catalina.out:
due to previous
> errors
> geoserver.log:
occured loading
> service: wms
Error creating
> at
> at
Factory.java:925)
> appreciated!
> regards
> Stefan
> Stefan Ziegler
> Leiter Aufsicht
> Kanton Solothurn
> Rötistrasse 4
> 4501 Solothurn
> http://www.so.ch
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
Justin Deoliveira
